Question about Maytag Atlantis MAV6000 Top Load Washer
Lint in the wash water/clothes
I have a maytag atlantis washer model MAV 755 1A WW and recently have been getting a lot of lint on the clothes. Is ther a filter that needs changing or do you know a possible cause and solution for this ? Thanks HerbH
  • 10,865 Answers
If you have a regular tub/agitator machine you can fill 1/2 with water, add two cups of white vinegar & allow it to agitate but not empty. Give the machine a break to 'soak', then agitate again. Allow the vinegar-water to sit in the tub between rounds. Do this for the whole day (on weekend?) to give the machine a good cleaning. Often soaking in vinegar will loosen trapped debris so it can go down the drain. It will clean the machine very well even if it does not stop your lint problem. Sounds like there must be some part in the machine that got clogged w/ lint or that there is a hidden lint trap. Read the instruction booklet or try to contact the manufacturer via toll free phone or internet for troubleshooting on the problem. Good Luck!
Posted on May 18, 2009
Where is the lint filter? Why does it put lint all over clothes?
lint is usually removed in the dryer. If you have lint on clothes after going through the wash, you probably left something in a pocket somewhere.
Sep 20, 2014 | Maytag Washing Machines
A co-worker sold me this washer: model MAV6250Aww, ser# 20480262zu; that had just sat in storage for a while. Washed clothes came out with a lot of lint- even after a repairman "cleaned" it out. Any...
These washer are notorious for linting, there is no real solution, reduce wash time to bare minimum, try sorting clothes into different categories, whites separate washed from dark clothes, use good quality detergent. The only way to fix this problem completely is a neutral drain kit, I do not believe Maytag sells one.
Oct 20, 2013 | Maytag Atlantis MAV7260B Top Load Washer
Excessive lint on washed clothes
Your washer does not have a lint filter, so it's very important to sort lint givers from the lint takers. Washers today to not have lint filters because we rely on the dryer to remove lint that does not get pump out with the wash water.
Below are tips taken directly out of the user's manual:
  • Did you sort properly? Sort lint givers (towels, chenille) from lint takers (corduroy, synthetics). Also sort by color.
  • Did you overload the washer? The wash load must be balanced and not overloaded. Clothes should move freely. Lint or powdered detergent can be trapped in the load if overloaded. Wash smaller loads.
  • Did you select the correct water level? The water level should be correct for the load size. The load should be under water.
  • Did you use enough detergent? Follow manufacturer's directions. Use enough detergent to hold the lint in the water.
  • Did you line dry your clothing? If so, you can expect some lint on the clothing. The air movement and tumbling of a dryer removes lint from the load.
  • Was paper or tissue left in the pockets?
  • Is your water colder than 60°F (15.6°C)? Wash water colder than 60°F (15.6°C) may not completely dissolve the detergent.
  • Did you use the proper cycle time and agitation speed for the load? Reducing wash time (duration) and agitation speed are ways to reduce lint.
Jan 10, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Hi I have a Maytag Atlantis MAV975OA top loader. I cannot find a lint filter anywhere and my washing is coming out covered in lint. Can you tell me where the lint filter is so I can clean it? Thankyou
Hi gmallard, it doesn't have a lint collector. This machine is a piece of junk. We're going out today to buy a new one after years of brushing down our clothes with lint brushes. I'll put the Maytag in the shed to wash my dogs pillows etc. (about all it's good for)
Jan 03, 2011 | Maytag Atlantis MAV9750A Top Load Washer
Clothes have lint on them when washed. my old washer had a lint filter, do not know where the lint filter is on the Maytag Atlantis. Help
The lint scree in inside the hose on the inlet side of the pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Sep 02, 2010 | Maytag Atlantis MAV6000 Top Load Washer
LINT LEFT OVER CLOTHES
It has a self cleaning lint filter. Front loaders call for "Special" HE detergent .....and I would only use about a table spoon..You may be Cloging the special self cleaning lint filter ,with extra soap .Top loaders use a lot of water compared to front loaders. Let me know ,If I could help Again! Thanks
Dec 14, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Lint on clothes
hi thanks for the question sometimes a lot of suds in tub will cause this cause lint and suds stick to the outer tub and is difficult to remove try filling the tub with hot water and use vinegar in the water half bottle let stand for 4or 5 hrs . now drain the tub should work thanks for the question the appliance doc
Sep 03, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Hi there, i have recently purchased a maytag atlantis washing machine 2nd hand model MAV7750BGW,great machine only its leaving lint on cloths and i dont have a manual for it,can you please...
To my knowledge, on most (but not all) washing machines, lint/fluff are collected on the wash cycle and flushed down with the water during drain cycle.
Since your machine is a Maytag, it is different. On most Maytag washing machines, lint/fluff is collected in the center tube of the agitator. It wold be necessary to lift out said tube and thereafter clean it on a regular basis. Some other models have a lint filter near the top of the tub, which you need to slide out, clean off, and reinsert. If for some reason there is no lint/fluff filter in your machine, this page shows how one can be made.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 24, 2008 | Maytag Washing Machines
Maytag Atlantis MAV6000 Top Load Washer Logo
809 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
