Question about PNY Electronics - Others
Wanting to save images from my computer too my 64 gb
How do I do so
    Sergeant:
  • 376 Answers
Drag and drop is the easiest method. Or you can Copy then Paste if you prefer.
Posted on Jun 22, 2014
What cause dell to beep once and shut down
This is the bios - POST (Power On Start-up Test). Most likely your bios needs reset by using the jumper on the motherboard. If that don't work then the bios is not saving the right information. i would recommend to replace the motherboard.
Sep 02, 2014 | Dell OptiPlex 9020 Desktop Computer -...
Tip
How to recover SDXC Memory Card
Storage is getting cheaper, smaller while offering higher capacity every year. 64 GB memory cards are extremely common in today's smartphones, digital cameras, tablets and media players. Due to their sheer capacity, a single failure can cause a local catastrophe with that much information being gone.
http://www.fixya.comwrite_tip-wyytcj10vubwvpdmj0eoj2yx-1-0_0.jpg
Fortunately, the market offers numerous data recovery tools that can help you get your data back. But there is something about these cards you should know before you reach for a data recovery tool.
Flash Chips: Riddled with Defects
Can you believe you can buy the whole 64 gigabytes of fast, high-quality solid-state memory for as little as $20, or does it sound too good to be true? Why is an SSD drive of said capacity three to four times as expensive as a much smaller SD card with similar capacity? Isn't it using exactly the same type of memory, just in a different shell?
In fact, you can't really buy 64 gigs of high-quality flash memory for under $20, and there is a good reason why SSD drives are that much more expensive compared to SD or micro SD cards. The answer is buried in the question itself. Why you can buy a 64 GB microSDXC memory card off Amazon for not much more than $20, the actual flash memory the manufacturer puts in these cards is of a completely different quality compared to that of a typical SSD drive.
So how exactly are manufacturers able to achieve these unbelievably low memory prices? They do smart tricks to make the memory card appear as 64 GB of contiguous space while in fact the actual chip is riddled with defects.
Each memory card employs a tiny microcontroller that maps flash cells to logical addresses. The memory chips are manufactured with abundant capacity. During the manufacture, the chip is tested for defects. Unreadable blocks are simply mapped out and become non-addressable and inaccessible from the outside. Bingo! We've just turned an imperfect chip into a perfectly usable memory card. These tricks are nothing shoddy; they are used by all SD card manufacturers, and they are part of the published SD standard. If not for these tricks, SD memory would probably cost the same (or more) as today's SSD drives.
Now when you know the truth about today's flash chips... can you trust them your data? In fact, you can. Granted, SD cards can sustain a much more limited number of write cycles compared to an SSD drive. When one or more data blocks reach their end of life, the built-in microcontroller of said SD card is supposed to take them out of circulation and assign their logical address to another (working) cell. But what if that cell contained some system information such as a part of a file system? If this is the case, the memory card becomes corrupted, and you'll need to use special tools to extract information from that card.
Recovering Data from SD Cards
Luckily, we have a large number of data recovery tools available on the market that claim to recover the entire content of your memory card. But were they really tested with any of those memory cards in their compatibility lists, or do developers simply assume the recovery will work based on the same principle as traditional magnetic media? In fact, I've seen both and in between. Some products can recover all types of SD cards as they claimed, some other tools can't deal with SD cards at all, while some other tools can only recover SD cards up to 32 GB.
Wait a minute... Why the 32 GB limitation? Why some of the tools can recover 32 GB cards, but fail miserably when reading a 64 GB one? Should the tool either work or not? The reality is more complex than the numbers. While SD memory cards up to and including 32 GB conform to the SDHC standard, larger SD cards (64 and 128 GB) conform to a different standard called SDXC.
Recovering SD, SDHC and SDXC Memory Cards: Is There a Difference?
There is in fact a big difference between smaller (up to and including 32 GB) and larger (64 GB and up) SD cards. The former conform to the SDHC standard, while the latter use the newer SDXC standard.
For you as a user this can mean two things.
  • First, if you are using a 64 GB memory card, make sure that both your portable device and your computer's SD card reader advertise support for SDXC cards (or simply put, they explicitly state support for 64 GB SD cards). If your card reader is old and can only support SDHC cards, you won't be getting anything but errors if you try to read that card with your computer.
  • Second, SDXC cards are formatted with a different file system. Let me explain. When SD cards initially appeared, they used FAT32 as a file system. FAT32 was good enough in the old days. However, this file system has inherent limitations, restricting maximum file size to 4 GB. Just a few years ago this would be a laughable limitation. Today, a typical HD video will already run you more than said 4 GB. If you try to save a large file onto a 32 GB memory card (formatted with FAT32), the write operation will fail.
This is why the SD consortium decided to use a different file system for the new generation of SD cards. 64 Gb, 128 GB and larger SD cards come formatted with exFAT.
exFAT is a new file system developed by Microsoft. exFAT is based loosely on the original FAT32. However, exFAT does not have the limitations of the older FAT/FAT32. exFAT is extensively used in portable electronic devices due to its lightweight design. This was one of the reasons exFAT was selected by the SD consortium as a standard file system for the SDXC format.
Are there downsides to exFAT? There's one, but it's a major one. While exFAT is designed and owned by Microsoft, it's not free. Microsoft requires manufacturers pay licensing fees for using exFAT in their devices. As a result, this has become a limiting factor for many portable electronic devices, especially inexpensive ones. This is one of the reasons why you can use 64 GB SD cards in some devices but not in others.
As a result, when recovering data from a 64 GB SD card, you'll need two things:
  • An SD card reader supporting SDXC (or stating explicitly that it can read 64 GB SD cards);
  • A data recovery tool that supports exFAT;
Not all data recovery tools can support exFAT because of the restrictive licensing model employed by Microsoft. Even if a tool advertises support for "all types of memory cards", it may or may not support exFAT. One of the tools known to support SDXC memory cards and exFAT file systems is Hetman Partition Recovery.
But I've Just Bought a 64 GB SDHC Card!
Sigh. This chapter is probably the most disturbing part of this article. Every other week, we receive an email from a customer describing a typical situation. Because there are so many reports, and because they all describe the same thing, let me just summarize it below.
A guy buys a 64 GB SD card for a price that's significantly below the market. When the memory card arrives, he tests it in his computer, discovering 64 gigabytes of usable capacity. Suspecting that 64 GB of flash memory for under $5 could be a scam, the guy tests the card by writing some data. The writes are extremely slow (3-7 MB/s), so testing the entire capacity would literally take the whole day. He writes some 1-4 GB of data and reads it back. All seems fine, so the guy formats the card and puts it into a phone, MP3 player, digital camera, or whatever portable device he bought it for.
Day after day, week after week the card is filling up with data. Pictures, music and videos are saved onto that memory card. 8 gigs, 16 gigs, 32 gigs, 64 gigs - the writes keep going, the memory card seems to be holding well. Then all of a sudden a photo won't show in a viewer, an MP3 file won't play, a video won't show up. The guy takes the card out and connects it to a PC in an attempt to save the rest of the data. But... oops! There are no photos, music or videos on that card, just garbage.
It is this moment the guy seeks for help and writes us an email. Sadly, in situations such as the one I described our hands are tied: that memory card was a fake. In fact, the "deal" advertises a 64 GB micro SD card for only $4.79. Yes, it's under five bucks for a 64 GB memory card. The description is Pidgin English and reads something like this: "New 64 GB Class 10 Micro SD HC Memory Card with Adapter Fast USA Shipping Dependable memory card for your favorite photos, videos, apps, and games Easily transfer files between phone, tablet and camera" blah, blah, blah.
Remember: if it seems too good to be true, it's probably not true. See that "Micro SD HC" designation? It's a dead giveaway. You can't buy 64 gigs of memory for $5. And, THERE ARE NO 64 GB SDHC CARDS, period. The SD standard dictates that all SD cards with capacities higher than 32 GB are made to conform to the newer SDXC standard. If you buy this card, you won't be getting anything but a fake.
Ditto. Do not buy these. Remember how the packaging looks, and ignore deals that seem too good to be true.
SDXC Recovering 64GB and 128GB Memory Cards Hetman Software
on Jun 06, 2016 | Hetman Partition Recovery - Recover...
Not booting ISO image
An ISO image needs to be burned to disk; you cannot boot from the image itself. A free program that can burn the image to a working file is called CDBurnerXP. It will burn CDs and DVDs.
Apr 21, 2014 | Lenovo ThinkCentre M93p 10AA - Tiny...
How to get a picture to come in on my built in webcam
Normally with a computer that has a built in camera it comes with the software, so try running that. On the other hand if it does not have one, try to download any free web cam image software so that you can try it out. After you have everything set up and installed, take a picture and when you save the pic, click save as so that you will know for sure where you images are going to on your hard drive.
Feb 28, 2011 | Computers & Internet
I have windows 7 home premuim can't load to my dell computer?
If you want to run Windows 7 on your PC, here's what it takes:
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
    if you fulfill above requirement then you will be able to run windows 7 on your system
    good luck
Nov 27, 2010 | HP LaserJet 1000 Printer
Want to upgrade e machines 1300g-02w
I have found that your built in graphics card can have a maximum of 128MBs of shared memory. Now your computer can only use a maximum of 4GBs on a 32-bit operating system but not all of it will show due to virtual address space http://www.microsoft.com/whdc/system/platform/server/pae/paemem.mspx/
if you want to get the full 4GBs you would need to get a new graphics card and disable the integrated card as well as get a 64-bit operating system as of now your processor suppots it. Since you are wanting to get a better faster processor it will need to be 64-bit if you are getting the 64-bit operating system. Here is where you can get a really good new processor: http://www.fadfusion.com/selection.php?product_item_number=10026806136 if you are wanting a faster one then I will look further.
May 20, 2010 | E-Machines eMachines Desktop PC
How to record music from the computer with a SA2325 MP3 Player. Send me the steps to follow. Thanks
Overview of online support for SA2325/02 ( GB ):
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA2325/02&slg=en&scy=GB
Link to the user manual:
http://www.p4c.philips.com/files/s/sa2325_02/sa2325_02_dfu_eng.pdf
Music files MP3 or WMA
Music transfer can be made seeing the player as a USB mass storage device in Windows Explorer, exploring the drives on "my computer": the player should show up as a drive letter with about 2 GB of memory.
The files must have the format and extension as shown on page 17 of the manual:
• Compression format: MP3 / mp3 (8-320 kbps
and VBR; Sample rate: 8, 11.025, 16,
22.050, 24, 32, 44.1, 48kHz),
WMA / wma (64-320kbps)
• ID3-tag support: Song title and artist name
Transferring songs from the computer to the player
After exploring the appropriate music files on the computer, the songs can be dragged and dropped to the memory of the player: read the blue
tips on page 11 of the manual.
Always disconnect the player safely after transfers, see point 3.4.1 of the manual on page 11.
Audio CD converting to mp3 / wma format: RIPPING
When wanting to convert audio CD's to files that can be played on the player, you could use Windows Media Player 11 or MusicMatch Jukebox using the RIP utility.
  • For WMP 11: update your Windows operating system.
  • When using XP MusicMatch Jukebox 10 can be downloaded from next site:
http://www.soft32.com/Download/Free/MusicMatch_Jukebox/4-277-1.html
Right click on the download file under Soft32 Mirrors and select "Save target as..." Rember the download location for executing the file later, having the MusicMatch Jukebox installed.
Need more help ? Just post a comment.
Oct 17, 2009 | Philips SA2325 (2 GB) MP3 Player
Processor to motherboard
yes, you can get a 64 dual core.
Feb 19, 2009 | Acer AOpen MX 3ZA (91.88110.101)...
Camera wont read SAVED SCANNED jpeg images on SD card
The reason is that the images were not created on the camera in question. Each camera model saves pictures on a card in a proprietary naming protocol, and if your images do not adhere to this, they cannot be recognised by the camera
Apr 07, 2017 | Canon PowerShot A710 IS Digital Camera
How to clear my Controler Memroy Pack
Put a game cartrage in, like Turok 1 go to load save data and it will give you the options of deleting other game data on the memoryPack. Note: Some games will not give you the options of deleting other games data.
Jun 01, 2008 | Nintendo 64 Console
Electronics - Others Logo
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
