Question about Toshiba 42HL196 42 in. LCD HDTV
Capacitors power board - Toshiba 42HL196 42 in. LCD HDTV
Where is capacitor located on TV
There are several.
You should be identifying the four large components
- Power board
- Logic board
- Timing Control (TCON) board
- LED inverter driver board
99% the capacitors you are looking to identify for a power related issue on the power board.
capacitors look like
26155016-a3z50hdvc01hdf5dkelcuavu-4-0.png hope the video below helps you identify the defective capacitors
Fixing the Blown Capacitor in Samsung TV Yourself
Apr 07, 2016 | Televison & Video
Tip
How To Repair LCD Monitor
The most common problems on Samsung LCD monitor/TV:
  • The power can not turn on, the red light flashing
  • the monitor on for a while and then turn off, then the red light flashing.
This is due to the weakening of the capacitor in the power supply module.
let's go hunting for bad capacitor.
I will explain how to:
  • Open the case of the LCD
basically in all LCD monitors have two circuit boards (power supply board and system board)
  • After you open you will see the two boards are
  • You see a board that has a socket for the power source. wrote that the board we're looking for (power supply board)
  • Remove all cables connected to the board and take out the board. (get noted before you unplug it)
  • Now you see it components on board, we looking for capacitor.(see picture below)
  • Looking for damaged capacitors, physically you will see a capacitor on the top like a bloated (see picture below)
  • Replace the damaged capacitor with the same value that you can see on the surface of the capacitor. (In this step you need any soldering tool)
My advice: replace capacitors with higher voltage, like 10V replace with 16V or 25V will be fine.
Have a Nice Repair :)
on Feb 12, 2010 | Computers & Internet
SAMSUNG PS42AS5 PLASMA TV POWER SUPPLY FAULT 470MFD CAPACITOR BLOWS NEAR POWER SUPPLY
First thing you should do is to invest in a really good surge protector for your TV. Then when you replace the capacitor again use a good capacitor. Cheaper is not always better. Rubycon seems to do the best for me. There may be other suggestions, however I have the best luck with them.
Apr 03, 2013 | Computers & Internet
Screen Philips 17 inches LCD doesn't react. Power LED stays off.
Check the tv power supply board,that board where the power a/c cord plug into it.Most common problems on these power supply board are dying and leakages capacitors components parts.Check the power supply board carefully,if u have dying or leakages capacitors parts,these capacitors parts will bulges ups,will not have a flat cylinder heads like the rest of the other capacitors coponents parts.Replaces all these dying and leakages capacitors parts with the same Miro fared and the voltages little higher like 5 to 10 volts higher,the power supply board should not have this problem again.U have all equipments to do basic soldering works and u understand basic electronic wright?Then u should have no problems by replacing all of these dying and leakages capacitors parts that are bulges ups onto it cylinder heads on the power supply board.If u can't do this,tries websites like Shopjimmy.com,eBay.com to by a whole new refurbish power supply board for the replacement.
Aug 22, 2012 | Computers & Internet
I have a panasonic TC-P42C1 blinks 10 times no picture no sound What is common to go on this model (which board)?
Check the tv power supply board.That the board where the tv power A/c plug into it.Check the tv power supply board carefully for dying components parts that are called capacitors parts.Bad or dying capacitors parts on the tv power supply board are alway causes this problems to the tv.Bad or dying capacitors parts are very easily to spots,all these capacitors parts are alway bulges up onto it tops.Never have plats round tops as they suppose too.U have all the tools and know basic electronic also can do basic soldering work,u should changes all these dying capacitors parts in the tv power supply board with no problems at all.If u check all over the tv power supply board and it have no dying and leaking capacitors parts to the tv power supply board all.Then the tv Y-Sustain main logic Tuner board it is the causes and the problems.The tv Y-Sustain main logic Tuner signal board that is the board that take in the tv imcomming tv broadcasting signal cable plug into it.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board and or the tv Y-Sustain main logic Tuner signal board for the replacement.
Nov 06, 2011 | Panasonic TCP42C1 Plasma TV
I have a phillips lcd hdtv. When I turn it on the light blinks 6 times. I'm sure its the power supply board, my question is how do i repair the power supply board without replacing it? I have a power...
look ON THE POWER SUPPLY FOR SWOLLEN CAPASITORS. usually 2 RIGHT BY HEAT SINK. VALUE VARIES... REPLACE ANY SWOLLEN CAPASITORS AND SHOULD SOLVE PROBLEM
Feb 17, 2011 | Philips 37PF9631D 37 in. LCD HDTV
Lg tv takes a long time to turn on. Flat panel 32" LCD 3 years old
Power supply board have those parts call capacitors are dying,have leakages gases capacitors parts.Take the tv aparts.The power supply board,that the board,where the power a/c cord plug into it.U know basic electronic,have all the tools?know basic soldering?Searches the power supply board for those dying capacitors,that have leakages of gases going to dead capacitors.These dying capacitors on the power supply board alway bulges up on it tops or puffing up on it tops.These dying capacitors,must be replaced.The tv power will power up as normal and faster.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Aug 04, 2010 | LG 32LG30 32 in. LCD HDTV
My Samsung 2493hm monitor quit working after a power surge. The power light flashes slowly but nothing else happens. Can it be repaired at a reasonable price?
Dear showmetoo99,
Surely favicon.icofavicon.icowiki-favicon-sharpened.pngoneriot-favicon.icoyou can fix it yourself with a very low cost.
Feb 02, 2010 | Samsung Computers & Internet
I have a Samsung LN40A450 LCD TV that is only a year and a half old. I am getting no power to the tv only a consistent blinking red light and a audible clicking/beeping noise. What needs to be replaced?
Feb 01, 2010 | Samsung LN40A450 LCD TV
TV power supply problem
.01 mf 2000 volt. in flyback circuit .it is a timing capacitor. the red high voltage block is bad and that took out the capacitor. also check the horizontal output transistor...it is probably shorted.
Aug 25, 2006 | Sony KV-27V26 27" TV
Toshiba 42HL196 42 in. LCD HDTV Logo
14 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
