Question about kawasaki Full Suspension Mountain Bike Men
Dim Outdoor Lights
We just put new wires on our outdoor lights and they are very dim. We also have a new generator. Can you please tell me why they worked before and now they are now dim?
Thank you so much....
Patty
    Champion:
  • 225 Answers
From what you said it sounds like the problem is in the wiring.if they worked befor you rewired them i would recheck the wiring.
Posted on Jun 07, 2009
Dim headlight is out
Are you speaking of the dimmer control on the dash?
Feb 20, 2014 | 1998 Ford Windstar
Lights go dim when rev engine
Hi, Anonymous if your headlight is not working, only one beam works, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chaffed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/lo beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty wiring between battery positive and headlight bulb socket.
9. Weak charging alternator/generator.
10. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
headlights dim when revved up General Dirt Bike Discussion
ATV Connection
Honda ATC200E Headlights are dim while at full throttle brighter at idle
Lights flicker when idle and dim when rev
Stator Question
Jan 22, 2014 | Yamaha Motorcycles
Malibu lights system 8 yrs old and always a-ok. Other night, lights noticed to be super-dim. replaced 200 watt transformer with a new identical model. Lights powered up ok, but only about half...
Since it is uncommon for a power supply to vary, it is more likely there is a variable drain on the system, such as a nick in the insulation, variably grounding depending on soil moisture.
I would suggest isolating most of the circuit, and only plugging in one light at first, and then adding more until you find a change.
The other way to do it would be with an inductive ammeter or audible pick up, and trace the circuit, detecting a drop in current or sound right after the drain.
Feb 28, 2011 | Intermatic Malibu 300W Power Pack...
Only the fan mode works well, the a/c mode trips off whenever the compressor tries to start, giving a buzzing sound and causing the other lights in the house to dim. what do I do please?
Im sorry to say I believe its too late. but you can check things and it may just be melted wire .turn power off check disconnect wires then contactor wires then capacitor wires finally take cap off compressor check those wires possible that one will be burnt and can be replaced but if you dont find the cause it will get worse if all is good ohm compressor to check windings also see how dirty outdoor coil is please send me a vote and rating if you have any questions email to pendletonheatandair@hotmail.com
Sep 21, 2010 | Samsung Heating & Cooling
Hi i have a timer outdoors running xmas lights its remote after i turn them off the lights are very dim i have to pull plug out before they go off ive had three timers so far the lights r led
This sounds like load leakage current through the timing device. The timers shown in the picture use electronic control components and do not turn the power all the way off like a light switch, especially if not grounded properly. This can cause issues with LED lights since they are basically diodes and can "leak" power in reverse bias.
Most of these timers have a three-prong plug - they should be plugged into a grounded, three prong outlet so the residual current is shunted off during the "off" cycle.
In plain English, the circuit should be grounded.
You could try another type of timer, like one meant for air conditioners or lamps - they use a basic on/off switch. However, these devices may not be rated for outdoor use so be careful.
Dec 10, 2009 | Woods INDUSTRIES 13660 OUTDOOR DIGITAL...
Dim interior lights, power locks wont work......
Try looking at your battery. Check the cables to make sure they are tight and clean. Brush the corrosion off with a wire brush. Now, if you have a wiring schematic, find the ground for the interior lights and clean it up too. Oh, put vasoline on it, and the battery cables, to keep them corrosion free. Check the other grounds in the car cabin too.
Aug 10, 2009 | Buick LeSabre Cars & Trucks
Light dimming
BROTHER; It sounds like you have a ground issue,clean all of your elect. connections with CRC, lectamotive. This will clean out the dirt and old grease, then greasy the connections with DI-ELECTRIC GREASE, nothing else. If you use any other grease you will have a short and more elect. problems. Try that and GOOD LUCK......GREASY
Aug 06, 2009 | Sport & Outdoor - Others
DIM lights towards end of wire
you need a bigger supply. 14 lights at 20w each running in parallel is 280w.
if you are running anything bigger than that, then you need a supply at less 360w or better.
May 25, 2009 | Malibu Hardware & Accessories
Very dim interior lights
There may be a bad ground for the interior lights.
Mar 03, 2009 | 1998 Buick LeSabre
Light is new,but only lights up extremely dim, possible solutions
Make sure the ground wire from the light is clean and secure to the frame.
Jan 02, 2009 | Garden
kawasaki Full Suspension Mountain Bike Men Logo
71 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Phillip Edwin
Level 1 Expert
michael
michael
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
