Question about NetGear WGT624 Wireless Router
Cannot remember password for my Netgear WGT624 wireless router
I have two computers in my home. One computer has access to the modem from Verizon. The other computer had no way of running a cable to it, so I have been using one of those USB port wireless connectors. This Christmas, my mother got me a Netgear WGT624 wireless router so that my "wireless" computer could use my own internet, instead of piggybacking off of a neighbor's. I redid both the network name and password.
I had saved the name and password on the "wireless" computer when I attached the router to my modem, but about a week ago we had a thunderstorm and now, even though it will piggyback off of neighbors again, the second computer will not connect to my wireless router. I tried deleting it off of my system and re-entering it, but it seems I don't have the password anymore.
I know I have the net name correct since it was listed in my internet options every time I logged on over the past 5 months. Is there a way to access the router through the 1st computer (the one the modem is hooked up to) and figure out what I saved the password as, or a way to change the password so that I know what it is for the second computer?
I've looked on the internet for some sort of solution, but they all say "hard press and start over", but the router is still getting internet perfectly fine to the modem computer. Plus, I don't know how to "hard press restart" the router since I see no buttons anywhere.
Please help.
    President:
  • 272 Answers
  • The default user name is: Admin
  • The default password: is password or (for older routers) 1234
Try the default username and password before resetting the router to the factory defaults.
When a router resets, it goes back to the state when it was new — all information that was entered by hand is lost! Examples are critical things you need to get online, such as ISP username, ISP password, IP addresses, security keys, and ports and services that were opened. It all needs to be re-entered.
So, have your ISP information before resetting the router.
Naturally, if you moved to a new city, or if you bought a used router, the old information in the router may not be of use to you. Contact your ISP if you can't connect any computer directly to the Internet. Then, if there is a connection problem when the router is added, see No Internet Access Through the Router
Reset for most routers with a reset button on the rear panel
Write down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is admin and the password is either password or 1234. Try these before resetting the router.)
  1. Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the router was not cleared, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
Posted on May 18, 2009
  • rjbeg123 May 25, 2009
    The only thanks we get is a rating from you. If my response helped you with your problem please rate me accordingly. If you aren't able to give me a fixya at this time please feel free to ask me more questions until you can. Thanks for using fixya!
  • 700 Answers
Commonly its a pin hole at the back of the unit with the tag RESET.
From the manual;
To restore the factory default configuration settings without knowing the administration password
or IP address, you must use the Default Reset button on the rear panel of the router.
1. Press and hold the Default Reset button until the Test LED turns on (about 5 seconds).
2. Release the Default Reset button and wait for the router to reboot.
Or view this link its a V3 for comparison.
http://kbserver.netgear.com/pdf/wgt624v3_ref_manual_25Apr05.pdf
This will make its settings back to default.
Reset switch for this is near the antenna a small circular hole. Just read the manual on page 2-7.
Commonly resetting a router. Just the unit and the power supply. No other cable is attached to it. You will insert a small pin in hole (reset pin), hold, then attached the unit's power plug then count 5 seconds as your model says(see manual for other detail). Then release the pin. Detached power plug then reaattached it should be reset in its factory default. Then reconfigure again your settings.
NetGear WGT624
If you need to setup your Netgear wireless router then -
Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Mar 03, 2012 | NetGear WGT624 Wireless Router
Have 2 computers connected to Netgear WGT624NA router via ethernet connectors and have operated well for over a year. Now have gotten DSL and have run phone line to modem and via ethernet cable have...
Have you tried to reset router. It has to be done in order.
1. unplug router
2. unplug modem
3. shut down computer and restart after waiting 1 min
4. after restarting computer plug power back into modem and wait for all the lights to start blinking
5. after the modem is working plug power back to router and plug in the computer with ethernet cable and make sure you have internet,
6. try to link up with wireless,
If this does not work you will have to setup the router for wireless if it is att wireless you will have to call them to give you the password to set it up.
Jan 10, 2011 | NetGear WGT624 Wireless Router
Dont know how to install a password so other wireless computers cant log on I have a netgear WGT624
Hi dude check this would be useful
Things You'll Need:
  • Ethernet cable
  • Cable or DSL modem
  • WGT624 Installation CD
  1. 1 Plug the Netgear WGT624's AC adapter into a wall outlet. Plug an Ethernet cable into the yellow Ethernet port on the back of the Netgear router. Attach the other end of the cable to the Ethernet port on the back of your modem.
  2. 2 Insert the installation CD that was included with the Netgear WGT624 into your computer's disc drive. Click the language option you want to use and then click "Setup."
  3. 3 Follow the setup wizard's onscreen instructions and then click "Finish." The wizard will automatically detect your Internet settings. Open a web browser and navigate to "http://192.168.1.1."
  4. 4 Type "admin" in the Netgear's "User Name" text box and then enter "Password" in the text box labeled "Password." Click "OK."
  5. 5 Click "Yes" and wait for the latest firmware upgrade to install. Double-click the upgrade file and follow the onscreen instructions to install the upgrade.
  6. 6 Click the "Wireless Settings" link if you want to password protect your wireless network. Click the "WEP" radio button and then type in the password you want to use for your network in the "Passphrase" text box.
  7. 7 Click "Apply" and then close the web browser.
Sep 27, 2010 | NetGear WGT624 Wireless Router
Netgear wgt624 v3 problem,cannot go to any sites
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Let me know if you need further assistance.
Thanks for using FixYa.
May 27, 2010 | NetGear WGT624 Wireless Router
WGT624 Wireless Router: how to reset the passphrase. I can not access the...
Use a wired computer to access the setup page of the router.
In the address bar of a web browser, type 192.168.1.1 or www.routerlogin.net.
By default, the username is admin. Password is password.
Once on the setup page, go to Wireless Settings. You will see the passphrase and network key on this page.
I hope this helps!
May 15, 2010 | NetGear WGT624 Wireless Router
About 108 mbps wireless router wgt624 netgear
HOW CAN I INSTALL MY NETGEARN 108Mbps WIRELESS FIREWALL ROUTER WGT624 v2.
Jan 23, 2009 | NetGear CG814M Wireless Cable Modem...
No connection when installing WGT624 Netgear router
Plug an ethernet cable into the wan port of the router from your virgin modem... then plug ethernet cable from computer into a port on the router....that should solve your problem.
Jan 09, 2009 | NetGear WGT624 Wireless Router
Wireless Router Advice
what kind do you have right now? verizon fios offers some great wireless routers that are very strong
Dec 06, 2008 | Computers & Internet
NetGear WGT624 Wireless router
Check the security settings in the router . try 192.168.0.1 in your browser and check the access/security. Alternately reset the modem using button on back next to Ariel and press for 5 secs. Your computer firewall may be a problem or there may be an address conflict with your other modem.
Jun 28, 2008 | NetGear WGT624 Wireless Router
ISP blocking my internet connection.
hello!
-- do you know your verizon username and password?
-- what is the operating system of your computer?
-- have you tried connecting your computer directly to the modem to check if you can get online?
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings, you need to input your verizon username and password on the router setup page then save the settings.
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
May 26, 2008 | NetGear WGR614 Wireless Router
Open Questions:
See all NetGear WGT624 Wireless Router Questions
NetGear WGT624 Wireless Router Logo
531 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
