Question about Epson PowerLite 8350 Home Cinema Projector V11H373120
Need a main board for Espon PowerLite home Cinema 8350
I have owned this projector for only 3 years. A bulb blew so I replaced it. However, the projector still has the two (Lamp and Temp) lights blinking at the top of the projector, and I still am not able to get an image. I called Epson support. They had me send it to a service center. They thought it was the power box. After replacing that, it still didn't work, and now I am being told that I need to replace the main board, which costs over $2,000. Seeing that I can buy this projector new for about half that, it's obviously not worth it. I am trying to look around to see if I can find a used projector for parts or just the board for cheaper. Does anyone know what the part number is for that? I am not able to find anything in my attempt at searching. Thanks
Enter enter enter enter
enter 4 times
Posted on Dec 28, 2013
  • Alex Galvin
    Alex Galvin Dec 28, 2013
    sorry, wrong post
5 Suggested Answers
ViscamTech
  • 528 Answers
SOURCE: Epson PowerLite 410W projector (used
It seems you assume that it is not an overheating problem.
The problem is, the bulb gets really, really hot when using the projector. It doesn't matter whether it has been there without any usage. As you switch it on, it will start to get hot.
But the lamp or other parts of the projector should not get too hot. To control the temperature, air is moved through the projector with the help of fans. Air enters through air filters and move through the projector absorbing heat from hot parts. This prevents these parts from getting overheated.
But what if air doesn't flow freely? Then the parts CAN get overheated.
First, switch on the projector and check whether you can hear the fans working.
Next, switch off the projector and remove power cable.
After about 30 minutes, remove the cover and check whether the air filters are blocked. If they are, clean them with a small brush.
This would probably solve your problem.
Posted on Sep 23, 2011
zabolyx
  • 38 Answers
SOURCE: images has a blue color across the center
Wow, 3 in a row. As described on 2 other projector issues this is very similar to those others. I'll repeat the info here.
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the blue color has gone out. The image is made up of red, green and blue images layered upon the screen. If the blue panel has gone out then there is nothing filtering out the red light in the image.
It looks like yours has just a secone of the panel dying or comming loose from it's connector.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
Posted on Apr 01, 2009
BILLatNASA
  • 3 Answers
SOURCE: How do I reset the lamp hours on an epson
EPSON PowerLite 7250
Reset the lamp counter hours in 3 steps
1. Make sure, your projector is ON
2. Hold down the Help and Menu buttons for 5 seconds.
The "A.S." screen will appear.
3. Hold down the Tracking and Tracking - buttons for 5 seconds.
Posted on Sep 20, 2010
gmontgome595
  • 225 Answers
SOURCE: Epson 460 powerlite hooked to smartboard green light blinking and no image.
Yes this is most likely the lamp. Does it eventually go back to just a red light?
Posted on Dec 06, 2012
What should i do when my projector's temperature light is flashing red 30 sec after start up?
try changing the light bulb. they have a time limit on them. with mine, I had to change the light bulb. Not cheap, but it worked for me.
Nov 12, 2014 | Epson PowerLite Home Cinema 8350 3LCD...
Why is my epson powerlite 3020 beeping?
This usually comes from using an aftermarket bulb. Not sure if Epson intentionally engineered this annoyance or if it's from something inherent in the cheaper bulbs.
Sep 07, 2014 | Epson PowerLite Home Cinema 3020 LCD...
Epson powerlite home cinema 8100 picture quality problem?
It can be a bad lamp. Under menu setting, select Dynamic or presentation. Those are my favorite picture settings.
Aug 30, 2014 | Epson Powerlite Home Cinema 8100 Home...
Epson powerlite home cinema 8100 problem with picture
Dark pictures after a lamp change normally indicate that the lamp isn't aligned properly, or that it has been touched with bare fingers and caused a black mark, or it's an inferior (budget) lamp.
Aug 30, 2014 | Office Equipment & Supplies
Epson 8350 both lamp and temp red lights come at startup?
I'm being told it is the auto iris adjustment that is the problem. More than likely warranty or manufacturer work. It is internal.
Jul 28, 2014 | Epson Powerlite Home Cinema 8350 Eh-tw3600...
Epson 5010 can't open
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Mar 05, 2014 | Epson ELPLP69 - V13H010L69 Projector...
Blue light flashes, lamp doesn't light
competitive price.
have a nice day!
Jerry Lampdeng Lim
Mar 04, 2014 | Epson ELPLP69 - V13H010L69 Projector...
Epson projector is stuck in start up mode
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
Have a nice day!
wheel,
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Dec 24, 2012 | Epson ELPLP69 - V13H010L69 Projector...
Can the epson projector 8700ub be used in Australia with our power suppy being 230 volts? Thanks. Mr Tay thengtay@hotmail.com
Rated frequency 50/60 Hz AC Power supply 100 to 120 VAC:
3.1 A (Home Cinema 8350) 3.3 A (Home Cinema 8700 UB) 200 to 240 VAC:
1.3 A (Home Cinema 8350) 1.5 A (Home Cinema 8700 UB) Power consumption 100 to 120 VAC: Operating: 272 W (Home Cinema 8350) 297 W (Home Cinema 8700 UB) Standby: 0.2 W 220 to 240 VAC:
download the manual for this model
Techbelkin
thanks for rate me.
Jan 08, 2011 | Epson Power Supply 110/200 VAC Switchable...
Epson PowerLite 8350 Home Cinema Projector V11H373120 Logo
452 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
