Question about Android Gemini Tab
My 9.7" JoyTAB Gemini keeps freezing
Keeps freezing all the time
I have a lg g pad 7.0 and it keeps freezing on me how do i get it to stop freezing up?
Sounds like a software issue. If possible see if there is a update for the device. That could help with the freezing problem.
Dec 02, 2014 | LG 8GB G Pad 7.0" Wi-Fi Tablet Black
HOW CAN I FIX MY TABLET THAT KEEPS FREEZING?
remove the memory card , an reset it . small pin hole in side.
use a free program manager to see what is running at all times . uninstall or disable them programs in your startup.
go to your settings an disable all updates .
it might have a memory or cpu issue too.
Jul 10, 2014 | Nextbook Premium Series Next7P12
Keeps constantly restarting
Warning: All applications and personal files contained on the tablet will be erased. Only do this if you are unable to start your tablet.
  1. First, ensure the tablet has been switched off.
  2. Hold both the VOL+ and POWER buttons until the Gemini logo appears. Release both buttons.
  3. You should see a green robot on the screen with a red warning sign.
  4. Press & hold POWER then press VOL+ once, then release the POWER button. A menu will show on-screen.
  5. Using the VOL+ and VOL- keys you can move up and down to select the Factory reset option. Press POWER to select this option, then move down to YES and press POWER again.
  6. Once completed, press POWER to restart the unit.
Apr 13, 2014 | Tablets & eReaders
Proscan 7 inch tablet keeps freezing
My proscan tablet is keep freezing and lines are coming across the screen. What can I do
Dec 28, 2013 | Proscan 7-Inch Android Internet Tablet,...
Why is my Toshiba tablet freezing
It could be a number of things. Too many programs running. Or prolonged use while on charge could cause overheating.
Jan 03, 2013 | Tablets & eReaders
My kindle keeps freezing
In most cases, to avoid freezing, keep battery charged and turn off wireless when it's not being used. To properly reset, hold power switch to the right for 15 seconds.
Resetting the device is not a bad thing, most electronic devices need it to be done. It can be annoying, but it's not fatal.
I would keep track of how many times you need to reset the device. Once the amount get over a few times per day, honestly, I would call Kindle Support. They've got the necessary software to look further into your Kindle.
Mar 11, 2009 | Amazon Kindle Wireless Reading Device
Android Gemini Tab Logo
Top Android Tablets & eReaders Experts
Yoav Shilon
Yoav Shilon
Phillip Whisenant
Phillip Whisenant
Are you an Android Tablet and eReader Expert? Answer questions, earn points and help others
