Question about Yamaha HTR-6060
No sound on my Yamaha HTR 6060. DVD, Cd or radio.
It appears to be functioning, just no sound. I ran all the obvious check ups. I want to be able to fix this myself if possible.
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
  • 44 Answers
SOURCE: My Yamaha HTR-6050 shuts off at random times and says "Check SP Cable"
i think it means speaker cable?
http://www.fixya.com/search/p514076-yamaha_rx_v2700_7_1_channels_receiver/check_sp_cable
Posted on Apr 23, 2009
  • 40 Answers
SOURCE: problem with sp cable (yamaha)
The speaker cables are the ones that clamp or tighen down on the back of the reciever. All the spkr wires have to have the positive and negative leads correct. Also not aven one little strand of wire can be touching another conductor or you will have this problem. Make sure all leads are correctly ran and hooked up positive to positive and negative to negative from the back of the reciever all the way to the speakers. This should solv your problem.
Posted on Jul 25, 2009
That is a check the speaker wire error, caused by a short or perceived short. If you look at the back of the receiver you may see 1 strand of the wire loose, they are very hard to see sometimes. You may use banana plugs as it is painful to get everything hooked up without a few loose strands.
If there is still the issue check your speaker connections for the same issue. If they are in ceiling/wall speakers disconnect them all then plug them in one at a time to narrow it down.
If the issue persists perhaps one of your speaker wires has a short somewhere, could be a misplaced drywall screw from hanging a picture, or a carpet tack strip, or a pet deciding it was a nice chew toy.
If you are completely sure it is none of those then I would say it is a bad speaker or receiver. Try changing in and out known good speakers/receivers if you have access to them to see which one it is.
Good luck
Posted on Aug 21, 2009
satavlad
  • 405 Answers
SOURCE: Yamaha HTR-6230 receiver set up w/HDMI no sound
BD and DVR hooked up to the receiver and from the receiver to the TV right? If yes: Your receiver set to pass sound trough to the TV, if you want sound from the home theater setting has to be changed.
Posted on Nov 28, 2009
How I how do I reset my htr 6060 Yamaha receiver
Willard, Check the attached links,reset receiver.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Yamaha HTR 6060 Owner Manual Resetting The System
Yamaha HTR 6060 MCXSP10 Manual Page 94
Yamaha HTR 6060 Manual Page 104
Yamaha HTR 6060 Manuals Support and Troubleshooting Receivers
Mar 08, 2016 | Yamaha Audio Players & Recorders
How to connect external microphone to htr 6060
There is a stereo MIC plug on the front of the receiver.
Labeled "Optimizer MIC" same size plug as a Ipod head phone jack.
Sep 30, 2014 | Yamaha HTR-6060
I have a yamaha htr-6160 AV receiver. I have hooked up my DVD to it using using component video cables but I can't sound out. Video no problem but no sound.
it is sad your having a sound problem with your Yamaha
to resolve these problem , check the audio out settings of your DVD
player, it might have been set to digital and not analog.
Dec 26, 2010 | Yamaha HTR-6160 Receiver
My HTR-6060 plays through the tuner and dvd but not the DTV/CBL
Digital settings need to be assigned by the receiver in the ption Menu >> Audio Select.
Check the one for the HDMI from DTV/CBL.
May 23, 2010 | Yamaha HTR-6060
When listening to the fm tuner on my yamaha htr 6060, will all 7 speakers still make sound? i' having trouble getting sound from the other speaker connections other than the L and R front connection.
analog fm is broadcast in stereo you would need to use a simulated surround setting to have sound come out of your rear and mid surround speakers.
your manual says the default setting for fm broadcast is:
Radio Listening TUNER MUSIC ENHANCER
7ch Enhancer
Select this SCENE template when you enjoy FM or AM
radio programs.
make sure you unit is not in straight mode try pushing the straight button on the front of the receiver let us know if more troubleshooting is needed.
Cheers!
Feb 15, 2010 | Yamaha HTR-6060
Yamaha HTR-6130 sound only from centre, rear or front speakers
its not how there connected its in your settings. rehook up all your speaker connections properly,then make sure you proram the reciever to recieve fiber optic,hdmi,digital coax etc in the reciver.
May 18, 2009 | Yamaha HTR-6130 Receiver
No sound using digital coaxial connections
Couple of possibilities:
Press Audio Select on front of unit until "Analog" changes to "coax/opt"
or
When you select the component connected to the MULTI CH INPUT jacks as the input source (see page 38), this unit automatically
turns off the digital sound field processor, and you cannot select sound field programs.
May 16, 2008 | Yamaha HTR-6080
No output from outputs to speakers.
Usually the outputs are not fused, but you can go thur speaker white noise test and see if that works first. If it does, then outputs are probably fine, IF not then the output transistors are most likely bad. Let me know and we can try some other things thur live chat if you would like. Good luck Guru Jay
Oct 29, 2007 | Yamaha HTR-5650 Receiver
Yamaha HTR 5740 no surround sound with DVD
i have the htr 5230 and i had the same prob ... are you using fiber optic ??? try the effects like pro logic. or 5.1
Sep 23, 2007 | Audio Players & Recorders
Yamaha HTR-6060 Logo
23 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
