Question about CDA 4X4SS Cooktop
Cda gas hob Pilot light not sparking to light hob, can use a match to light burners no problem.
No sound of sparking when I try to light burners, lights with match. Can't find where pilot is located. Manual doesn't have troubleshooting guide.
  • 46 Answers
IS THE POWER TO THE HOB ON ?
IF SO IS THE FUSE OK ?
IS THE PLUG WIRED CORRECTLY ?
TRY THESE FIRST, IF NO JOY YOU CAN DOWNLOAD YOUR PRODUCT GUIDE FROM CDA ON LINE
Posted on Dec 30, 2013
Two of gas burners will not light
Assuming you have electronic ignition on your stovetop, you may have spilled food onto the burner which has clogged the holes needed to get gas to the spark ignitor. Clean the holes (or slits) and dry them and try again. If they are not dirty, check to make sure you have a spark at each burner. If you have manual pilots, there could be many other problems, like the pilot is not lit, dirty vertical holes (on the burner side) at the pilot tunnel or tunnel is not positioned properly.
Mar 16, 2015 | Cooktops
Westinghouse gas hob four burner only one igniting the other three only light with a match gas coming through but no spark
Clean the wires going to the ignitor of each burner, clean the burners as well. Chances are you have too much oil and dirt on them that is why your burners are not igniting.
Jan 27, 2014 | Cooktops
CDA gas hob ignition
try the fuse ..
Dec 27, 2013 | Cooktops
Middle section ticking sound with sparking as if trying to ignite even though knobs aa
see this steps and fix it. God bless yo
Relight an oven pilot:
  1. Turn all controls off, open the doors, and allow gas to dissipate.
  2. Hold a lighted match near the tip of the pilot on the burner assembly. If a burner does not light within two minutes, adjust the pilot, step 3.
  3. Turn the pilot adjustment screw (located near the pilot or the thermostat) in small increments and retest until the pilot has a blue flame.
  4. Check and replace an oven spark igniter:
  5. Turn all of the appliance controls off.
  6. Open the door and remove the oven bottom and the baffle (see above).
  7. Unscrew the igniter from its mounting bracket and inspect it for cracks or other defects. Replace it if it is damaged.
  8. To replace a faulty igniter, find the ignition control module, unscrew the cover, and disconnect the module. Install the replacement part and test.
Oct 02, 2012 | Fisher and Paykel GC36 Gas Cooktop
Will not light
Have you removed the burners covers and top to see if the PILOT LIGHTS may have blown out? Hold a stick match or fireplace match (long stick) down in the area of the circular burner after turning on some gas. The burner should light and the pilot light should stay on as well. You local gas company provides service for this type of problem. Call them and have a gas company representative make a home call (free service) in most areas.
Oct 08, 2010 | Kenmore 36 in. 33212 / 33214 / 33219 Gas...
Electric ignition to hob seems to be jammed
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 31, 2010 | Cooktops
Gas stove burner will not turn on
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 29, 2010 | Gaggenau 23 in. KG 260 Gas Cooktop
GAS TWO BURNER COOKTOP. THE CLICK STOPPED LAST MONTH ANDNOW I USE A MATCH TO LIGHT THE BURNERS. HOW CAN I REPAIR OR CHANGE THE SPARK MECHANISM.
heatman101
Mar 15, 2010 | KitchenAid Cooktops
We have a thermador 5 burner gas range top and the pilot light seems to have gone out. The burners don't go on but we smell gas. How do we re-light it?
Most gas range tops no longer have pilot lights but use an electronic ignition (sparker) to light the burner. Normally when you turn the burner on you should here a snapping or sparking sound, at which point the burner should ignite. Here is a link to the user manual for 36" - 5 burner Thermador rangetop...maybe this will help: http://dl.owneriq.net/a/ac64ae7b-1ed3-44a3-9235-e4dbd8fe4628.pdf
By the way, in the short term you could always use a match to light the burner. JUST BE VERY CAREFUL THE YOU HAVE THE MATCH LIT AND OVER THE DESIRED BURNER BEFORE YOU TURN KNOB TO START THE BURNER!!!!
Jan 15, 2010 | Thermador 37 in. SGSX365 Gas Cooktop
Gas hob is permanently igniting
hi gud day,try to clean the area of knobs by using vacium,remove all the knobs firts then clean it,unplug the unit before u clean.
tnx gerbee
May 19, 2009 | De Dietrich DTG775X Gas Hob 22 in. Cooktop
CDA 4X4SS Cooktop Logo
216 people viewed this question
Top CDA Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a CDA Cooktop Expert? Answer questions, earn points and help others
