Question about Roper RAX4232KQ Top Load Washer
Machine will not agitate
Fills and pumps out the water but it will not spin or agitate. It sounds like the motor is running.
  • 3 Answers
Washer has a motor coupling between gearcase and motor. This coupling is probably broken.
Posted on May 19, 2009
Kenmore series 80, model 110-25842400, and serial number CR3353550 washing machine. I hadn't heard the machine work before the problem, and my wife said it was not working right (would fill with water and...
thabks for being through... i wish everyone was like you.. i get alot of Its not working? i hate that what does that mean... wish they were like you.. please check the harness on the motor while it is spinning.. i had that problem before... also it could be the speed selector switch.. sometimes it will get caught running 2 speeds at once and it will click like that...
checks these things and let me know if you need more assistance.... you sound like a tech.. wanna job? lol
Apr 12, 2010 | Kenmore 24032\24036 Top Load Washer
Whirlpool model SM 8525079 fills with water but will not agitate or spin
If you have motor sounds after water fill,but no agitation or spin it could be a broken direct drive coupling. If it will not pump out water,there could be something stuck in the drain pump.
Jan 17, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
My whirlpool washer will not drain or spin, but it will fill and wash
This sounds like you are having a problem with the motor not changing direction. The pump for draining is on the front of the motor and runs even when agitating, just it runs backwards therefore keeping the water in the machine. When the motor changes direction, the pump starts taking water out of the tub and at the same time the transmission changes state from agitate to spin.
This could be a bad motor, a bad timer (not connecting the proper wires to reverse motor direction) or even a connection problem with the wiring harness, though the former two are more likely.
Hope this helps
Oct 27, 2009 | Whirlpool Washing Machines
Kenmore 80 series will agitate but not spin or let water out.
Hi, I know washer had a party, he just need a dancing partner, joking, that's a common problem, when machine is not properly level, you should used spirit level, to level machine, after leveling machine, place both hands on machine, and try to rock it from left to right, forward and backward, and it should not have any play, if there's play adjust legs to compensate, water has to be pumped out first before machine spins, rhere's something wrong with water pump, maybe some fabric stuck in pump impeller, or maybe wires disconnected from water pump, remove back of machine and check connection to water pump, check for kink hoses, visual check, if wire were remove, connect to water pump, you're smart. good luck.
Aug 08, 2009 | Kenmore 24032\24036 Top Load Washer
Won't agitate or spin
If you mean that when the unit should be agitating or spinning the motor is running, and you lift the lid causing the motor to stop running, it sounds like the coupler.
Mar 31, 2009 | Whirlpool LSR5132PQ Top Load Washer
WASHER FILLS WITH WATER,MOTOR ENGAGES AND RUNS SMOOTHLY,BUT NO AGITATOR ACTION. WILL GO THRU TIME CYCLES AND FILL WITH AND DRAIN OUT WATER BETWEEN CYCLES. JUST NO AGITATOR. iT WILL SPIN DURING THE SPIN...
Sounds like you motor coupling has broken. The water pumps out so that tells me the lid switch is fime and motor is fine. The drive coupling mounted between the tranny and motor is probably broken
8a0970d.jpgI have a page with pics and movies to give ya some ideas what to do. HERE
Mar 11, 2009 | Washing Machines
Will fill water but agitator wont run.
Thats very agitating.There is a motor that runs the agitater,its either going out or you have lost the drive,a little spendy to have fixed.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer does not agitate after filling with water
does it spin?
sounds like your coupling is broke.It takes the place of the belt if it breaks it won't spin or agitate. it will still pump though.
Part # 285753A
Nov 04, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Sep 29, 2008 | Washing Machines
Doesn't agitate
Place the unit in the spin cycle and see if it will pump the water out and if it will spin. (This makes the motor,transmission and pump run in the opposite direction.)
Jan 13, 2008 | Maytag Performa PAV2200
Roper RAX4232KQ Top Load Washer Logo
166 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
