Question about Bushnell Trail Sentry 11-9200 Digital Camera
Trail camera keeps shuting off
My game camera will not save pictures even when it says captureing images and it will not stay on when i go back to check it the next day its shut off and still turned on has new batterys fresh out the pack
3 Suggested Answers
  • 115 Answers
SOURCE: fresh battery dies fast
for this you will need to send the unit into their repair at 8500 marshall drive lenexa ks 66214 4-6 week turnaround and put your name address and telephone number inside the package. if there is a cost they will send an estimate.
alt if they are still available you can get a battery door with an on off switch from bushnell at 800-423-3537 option 1
Posted on Mar 24, 2010
vetteman3002
  • 2299 Answers
SOURCE: bushnell sentry trail cam not
This is a common problem with the cams. Some of the cams did not get the proper seals put in to keep moisture out. You can return the cam for a refund or exchange it .
Posted on Nov 01, 2010
What features should one look for while purchasing a trail camera?
he features should one look for while purchasing a trail camera -
1. Picture Quality
Picture quality doesn't just involve the number of megapixels that a camera has, this metric also takes into consideration the clarity of the picture, the color composition and how it contrasts the subject with the foreground and the background.
Resolution is measured by megapixels and the notion that the higher the megapixels count the better the quality is a false notion that marketers use to make customers think otherwise. The resolution works together with the other features to give the best image the camera can capture.
Checking trail camera picture quality involves looking at the picture online and comparing them. Outdoor shops also have units available for testing that customers can take sample pictures with to judge the quality of the picture.
2. Night Mode
Probably the most important feature in a trail camera, the ability to record and capture images at night is what gives trail cameras the edge when it comes to tracking. The perfect trail camera should have either infrared or black LED flash. The bulb-type camera flash can scare wildlife away when it takes pictures at night. Game especially nocturnal ones are sensitive to sudden bursts of light and, as a result, they will scatter and probably never go back to where the trail camera is.
It is understandable that night pictures would have significantly less quality in the images it captures but the photos should still be crisp and clear within the acceptable range. Some cameras can eliminate red-eye from the subject but this is an optional feature.
3. Video quality
Videos are a newly added feature to trail cameras and most of them would have the option to select the length of the video. Others would also include the option to go HD or VGA with their recordings. Check the quality of the video in both day and night modes, the video playback should be clear and blur-free.
4.Time Lapse
Time lapse videos are taken even when the sensors are not triggered and the output would be a video of the landscape but at a higher speed setting. For example, the camera would record for 8 hours but the resulting time lapse video would only be about 10 seconds. This is an optional feature for hunters are they are more focuses on the hunt rather than playing with video effects.
5. Power Consumption
Almost all trail cameras run on 8 AA batteries but not all of them would have the same consumption rating. Some would have a power saving feature while some would have many features that would use up the juice on the batteries at a faster rate. Ideally, fresh batteries should be able to take about 16,000 pictures before draining out.
6. Memory
Most trail cameras would have built-in memory already, however small, but the unit itself should be able to support at least a 32GB SD Card. The external SD card has the advantage over the internal memory especially when downloading the captured images. SD Cards can simply be removed from the device and plugged into a computer whereas an internal memory camera would require removing it from the mount, and storage unit, and then plugging it in which translates to time and effort lost
7. Detection Circuit
The Detection Circuit is what detects game passing in from of the camera and is also the same mechanism that takes the picture or video and records it. Here are its components:
Trigger Time - once a wild animal enters into the detection zone, the amount of time used to snap the picture is called Trigger Time.
Recovery Time - after a camera triggers the lens and memory would need some time to store the recently captured picture and prepare for the next one, this is called Recovery time.
Sensors - these are what detects game in front of the camera and gives the signal to the mechanism to take the picture. Trail cameras often use infrared sensors.
Detection Zone - this is the maximum range that the sensors can detect movement. This also correlates to the effective distance of the camera lens.
Simply put, the detection circuit is the trail camera and the faster the trigger and recovery time the better. A wider detection zone would also be ideal for a trail camera.
8. Advanced Features
Higher end models have some advanced features that can include:
Remote Access - this provides hunters the ability to check on the images captured at the comfort of their homes, camps or offices.
Viewfinder - this is slowly becoming a standard among trail cameras. This allows the hunter to view images and videos without connecting the unit to a computer. This also acts as the menu screen for the unit.
9. Price
Each year the price of parts go down as components get smaller and easier to manufacture and this also brings down the standard price of new trail cameras. Nowadays, it is not unheard of to have a good quality camera to be priced at less than $200.
10. Brand Recognition
There are many brands to choose from with the same features but read about customer feedback and see which brand brings in more customer loyalty than others. This is indicative of a good quality product.
Mar 29, 2017 | Cameras
THE IMAGES CAPTURED AT NIGHT ARE SO DARK THAT WE ARE UNABLE TO VIEW THEM. WE CAN SEE SHADOWS IF DEER BUT CANNOT FIGURE OUT HOW TO GET AN ADEQUATE PICTURE AT NIGHT.
Turn camera off take out battery's and sd card. Once everything is out put it to the on postion for about 2-3 min. Then put battery's back in with the camera being on still leave sd card out. Once it says no card turn camera off then put sd card back test in dark. If still not working call Moultire 8006533334 option 1 and 1 for a live person.
Sep 30, 2013 | Moultrie Game Spy C-90I 10.0Mp Scouting...
I want to keep some pictures on my camera and delete some
While viewing the image, press the trashcan button. The camera will ask for confirmation of the delete.
I would recommend against making a habit of keeping some pictures on the camera or memory card and deleting others. You're guaranteed to fragment the memory, leading to camera speed loss and eventual memory corruption. The camera is an image capturing device, not an image storage device. If you need to keep some pictures on the camera, copy them to a computer, format the memory card, and then copy them back using a card reader.
Mar 18, 2012 | Canon PowerShot SD1100 IS Digital Camera
Delete select pictures from camera
How to save a picture to a memory stick,,
Even if the Memory Stick Duo is inserted in the Camera, the images will not be saved in the Memory Stick Duo until the capacity of the Internal Memory is full. To save the images in the Internal Memory to the Memory Stick Duo, select the EXPORT option from the Viewing Menu of the Camera. Touch the MENU icon when viewing images to select the IMPORT option.
There are two option in the Viewing Menu of the Camera (Export and Import). Export option is to save from Internal Memory to Memory Stick and Import is for saving from Memory Stick to the Internal Memory.
This Camera is having 4GB of Internal Memory, hence the images captured will get saved in the Internal Memory first and then to Memory Stick once the Internal Memory is full.
Thanks for using FixYa
Dec 04, 2010 | Sony Cyber-shot DSC-T2 Digital Camera
Pictures to PC
HI,
Just uninstall the software without the camera plugged in and then install it again.Then plug in the camera.
Goodluck..
Apr 17, 2008 | Largan Chameleon Digital Camera
Camera cant capture image
camera can not save picture.how can i solve the problem.
Oct 29, 2007 | Sony Ericsson K750i Cellular Phone
Auto reset following each picture shot
Well most digital cameras are not equipped to allow to take a lot of action photos or just snap off various pictures of the same subject in a relatively short time. The models which are ill-equipped require more time between shots to save the image to the memory card. Just imagine the time it takes to save something on a disk. Keep in mind that the burst mode allows temporary storage of images. This way, you could take as many pictures as you can in no time. With the Nikon Coolpix 4300 Digital Camera, you can expect to find a shutter speed of 1/1000 to 8 seconds. One more camera feature include a Self-Timer mode, which provides a three- or 10-second delay between the time the Shutter button is pressed and the time the image is actually captured... Good luck!
Oct 23, 2005 | Nikon Coolpix 4300 Digital Camera
Bushnell Trail Sentry 11-9200 Digital Camera Logo
48 people viewed this question
Top Bushnell Cameras Experts
Johnny Massengill
Johnny Massengill
Are you a Bushnell Camera Expert? Answer questions, earn points and help others
