Question about Yamaha FC4 Piano Style Sustain Pedal
Yamaha fc4 sustain pedal not working with casio wk6500
It sustains when pedal is not pressed and sustains when pressed
SOURCE: Sustain pedal not working on my Yamaha P-90
What I figured out is that when i turn on the keyboard, if i hold down the pedal by accident, it will work in reverse. I dont know if this is what you mean. If it is, just dont touch the pedal when you turn it on. If it isn't, try to return the pedal. I dropped one, it had this problem, and they gave me a new one. Your cord for it might have been bent (?). Also, turn the keyboard on with the pedal already plugged in. It's not made to be plugged in while it's on. Hope this helps. - Matthew
Posted on May 15, 2009
  • 4090 Answers
SOURCE: The sustain is on all the time.
The pedal activates a microswitch fitted to the circuit board. I suspect for some reason unbeknown to man and spirits this switch has become "stuck" or collapsed. If the latter then it has to be replaced as they are soldered to the board. You coulod open the unit trace the pedal back to the sustain switch and "jiggle" it manually to try and release it. A small amount of WD40 on your finger and rubbed over the pole of the switch( do not spray it) should help it to stay releaased until wanted. If you see corrosion on the board near the switch then take it to a music repair shop as this corrosion is like a cancer and will spread to other keys.Mice piddle is not unusual on keyboards and a great destroyer.
Please rate my help++++Thanks for using FIXYA
Posted on Dec 02, 2009
SOURCE: Sustain pedal on Yamaha DGX not working
Hi, I had the same problem, but I have an easy solution. I am trying to connect an FC5 to a Casio CTK-3000. The problem is open vs closed circuit in the pedal and the way that the casio interprets the info. Paulll's fix is correct, but you do not have to use soldering. Simply remove the cover, unscrew the silver screw, and you will notice that the black contraption that holds the two metal strips has one side that pops off. Pop off this side.
Now, notice that the short strip is on top and the long strip is on the bottom. The way the strips bend mean that the circuit is closed when there is no pressure on the pedal. When you press the pedal, the white knob on the long strip pushes the long strip down and breaks the connection with the short strip.
What you need to do now is remove the two strips and slide them back into the black contraption with the long strip on top and the short strip on the bottom. The white knob on the long strip should be facing up. Make sure when you do this that you hook the short strip over that little horizontal black plastic rod so that it will easily contact the long strip when the long strip is pressed down.
By bending the top (long) strip a little, you can make it so that the long strip does not touch the bottom (short) strip in the relaxed position. Make sure that the ends of the strips where the wires join do not touch each other either. You now have an open circuit in the relaxed position, which is what Casio recognizes as NO PEDAL.
Pop the side piece back on the black contraption and screw the black contraption back in place with the silver screw. Set the spring back in place and reattach the 'pedal'. Make sure that there is enough clearance between the top of the white knob and the inside of the pedal so that the circuit remains open in the relaxed position.
Now, if the two strips are NOT touching each other, when you plug it into your Casio, the Casio will not recognize the pedal, which is good. When you push on the pedal, you will close the circuit and the Casio will recognize the pedal.
If you push on the pedal and nothing happens, then the two strips are not contacting each other in the fully pressed position. Take the unit apart and try again.
If the Casio still recognizes the pedal even though you are not pushing on it, then the two strips are contacting each other at any place along their length. Take the unit apart and try again.
Enjoy your new working pedal!
Greg
PS. If you Casio won't work with your computer, there is a fix out there for that too. It involves removing (or renaming) some files that Logitech loads on to your computer when you install a webcam. Weird, but true.
Posted on Jan 27, 2010
SOURCE: Sustain Pedal Opposite Effect
I found that if I plug in the sustain pedal BEFORE turning the power on, it works fine. If I plug in the sustain pedal AFTER turning the power on, then it works in the opposite way. Probably just the design. So I would try playing with that before doing anything drastic.
Posted on May 19, 2011
  • 5603 Answers
SOURCE: Fc4 sustain pedal is in
Sorry, but the Yamaha pedal has the opposite sense (it is a normally open contact) than what is REQUIRED by Roland equipment. Roland requires a Normally Closed contact. Unfortunately, one is confused because the Roland jack for the sustain shorts itself to no sustain when you unplug a pedal. SOMETIMES one can open a pedal and with soldering iron change a wire to reverse the pedal sense IF the particular pedal has both contacts available.
Posted on Jun 17, 2011
How to fix a corrupted display?
If everything else works fine then it likely just needs the display replaced.
Apr 24, 2014 | Yamaha FC4 Piano Style Sustain Pedal
Ctk-651 sustain pedal working backwards
Buy sustain pedal made for CASIO or switable model.
Pedal for Yamaha or Roland will work in reverse on a Casio.
If you cannot return for exchange, then open up and solder a different type of micro switch.
Dec 31, 2013 | Casio Keyboard Ctk-481 Ctk-631 Ctk-651
Sustain pedal does not work
Yamaha FC4 and FC5 sustain pedals are normally closed, sorry Fred. Roland is opposite. I suspect the P120 just needs to be reinitialized. Hold down top white key (C) while turning on power. Wait 3 seconds and then release white key. Should now be reset to factory spec. Always plug the pedal in before you turn it on. If it still doesn't work check it with a meter.
Mar 17, 2012 | Yamaha CP300 Stage Digital Piano...
The sustain peadal in my yamaha s03 is unable . How do i fix this problem?
Press Utility and scroll (up/down arrows) till you see FSTxCtlNo and press inc/yes until it says 64. Your sustain will now work. Hit exit to get out of edit mode.
Jan 14, 2012 | Music
I have a Casio CDP 200R. I recently purchased a FC4 foot pedal but it works in the reverse way. I tried switching the piano off and then plugging it in and it still does not work. Can you please let me...
You should try having the pedal connected when you turn unit on. Some pedals can be rewired to act opposite... However I believe this pedal should work with the Casio. You can open the pedal and see if you can move one wire so it works opposite. Also verify that the jack is set to the "SUS" setting per your user manual... around page E14
Sep 07, 2011 | Yamaha FC4 Piano Style Sustain Pedal
I plugged a sustain pedal from my Yamaha DX7 on the dumper pedal jack but it works opposite as it should (by pressing the pedal sound cancels as i release the keys; when pedal runs completely free sounds...
every sustain pedal got different polarity.. normally just go to global setting on your keyboard and change damper polarity setting to plus or minus (select which one work with your sustain padle).
Jul 26, 2011 | Korg M50 73 Note Workstation
Fc4 sustain pedal is in "sustain" mode at all times -- it won't release the sustained notes. I tried plugging the pedal in (to a roland ep-9) before powering up and had the same problem.
Jun 16, 2011 | Yamaha FC4 Piano Style Sustain Pedal
When I plug the pedal in and play, the music is constantly sustained without me pressing the pedal. Do i need a new pedal ? Is the problem within my Roland ? Please help ! - I use a Roland 700 GX. -The...
1.Make sure you are plugged in to DAMPER (not FC1 or FC2) 2. Check to see if the notes STOP sustaining when you PRESS the pedal. If that is the case, first try turning off the Roland with the pedal plugged in and restarting with the pedal pressed down. 3. Press the EDIT button and scroll to Damper Polarity. See if it's set to Standard or Reverse. 4. If problem persists after all that, try holding the pedal jack into the Roland at different angles and then try the same with where the cable connects to the pedal. At that point, you can either attempt to repair the pedal or get another one.
Hope this helps, Stewart
Feb 28, 2011 | Roland DP-10 Damper Pedal, B-Stock
Hi. I'm Using PX330 as a midi controller that plays "Galaxy pianos" in cubase 5. I'm interested in buying a continuous sustain pedal (the one I got with the piano is an On\Off pedal). can you...
The Yamaha FC-3 uses a TRS (three conductor plug). The PX330 does NOT use TRS jacks for the sustain and sostenuto pedals so they are NOT compatible with the Yamaha FC-3. Therefore I would conclude that continous sustain that the Yamaha pedal would be used for is NOT supported.
Feb 15, 2011 | Casio Privia Keyboard Case
Yamaha FC4 Piano Style Sustain Pedal Logo
59 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
