Question about Pioneer DEH-65BT CD Receiver with Bluetooth, MIXTRAX, Pandora and iPod
No Auxiliary My stereo was working fine but suddenly my auxiliary cant be found and Bluetooth does not work
  • 158 Answers
SOURCE: Auxillary mode: can't get to it!
did your battery die after you installed cd player or did it die because of some other reason. please first confirm this since wrong connections are the biggest culprit .best of luck.
Posted on Jul 13, 2008
  • 158 Answers
SOURCE: ipod through auxiliary port has very low volume
the only way here is (1)either route the audio signal of ipod through an amplifier OR(2)turn up the volume on your ipod so that the amplifier in the stereo gets a higher voltage to work with ,resulting in a higher output.
Posted on Aug 27, 2008
  • 56 Answers
SOURCE: new iTouch doesn't work in DEH-P4800MP
The newest versions of the Iphone uses USB charging only, while older generations of (any) Ipods used firewire for charging. First generation Iphone and Ipod Touch could be charged with either method. Most docks historically used the firewire charging method, making them incompatible with all but 1st generation Iphones. You need a new cable/charger that charges with the USB method.
Posted on Jun 10, 2009
  • 69 Answers
SOURCE: Can't get auxiliary to work on Pioneer Mosfet Head unit 50x4
you have to turn the AUX input on through the function menu which can be accessed by following these steps
1. with the unit on. press and hold the source button unitl the unit turns of (or goes into demo mode, which is fine)
2. depending on the model that you have, you will have to press and hold the
(volume button or the audio button), until a menu is displayed.
3 . toggle through until you find AUX 1 and AUX 2. i would turn them both on and see which one you have plugged into, then you can go back and turn the other off.
4. once you have change it to ON. press the source button to turn on. the aux option should now be in your source options.
5. also, while on AUX, you can go into the audio settings and turn up the SLA (sound level adjustment) to +4
hope this helps
Posted on Aug 26, 2009
  • 34 Answers
SOURCE: I have a Y-cable (dual RCA plugs one end and
make sure your jack is pressed all the way in your IPod
Posted on Oct 07, 2009
Where is the auxiliary input in 2007 sante fe elite
If you don't see anything on the radio saying "auxiliary output" with a little earphone jack then you aren't Aux ready.
You might be able to go to a stereo shop and have them install an auxiliary output plug. They will pull the factory stereo out and splice/plug in an output wire that you can plug your iPod into.
Mar 28, 2014 | 2007 Hyundai Santa Fe Limited
Tip
How to connect my iPod to an Amp & Subwoofers
<p>If your iPod to your amplifier or subwoofer that connects to a stereo receiver. This can be done through an additional cable. <br /> <p><br /> <p>1. Locate the auxiliary input on your stereo connected to your amplifier and subwoofer. These entry, small and round is labeled "AUX". Usually this entry is available in front of the stereo, but some devices can be found on the back. <br /> <p><br /> <p>2. Connect another cable to the auxiliary input of your stereo. <br /> <p><br /> <p>3. Connect the other end of extra cable to the headphones of his iPod. <br /> <p><br /> <p>4. Press the "AUX" input button on your stereo. Now when you play a song on your iPod you listen to them on your speaker system including subwoofer and amplifier. <br />
on Aug 09, 2011 | Apple iPod touch
Rear auxiliary audio plug port not working
Auxiliary is likely an input for external sound source. It won't produce sound.
Nov 06, 2013 | Logitech Bluetooth Speakers Z600
How do I listen to music from my phone through my indash??
Most new model in-dash stereos have an auxiliary mini jack input. Connect a mini-jack cable to the auxiliary jack on your in-dash stereo (available at RadioShack or anywhere there are portable music player/smart phone accessories), and connect the other end to the headphone input on your iPhone/smartphone or player.
Change your stereo input to "aux" or "auxiliary" and Voila! Music will play from your car speakers.
Feb 22, 2011 | Clarion VZ 409 Car DVD Player
I can't get any sort of direct connection from my inner console ipod auxiliary. It has two plug in points, one for a generic mp3 auxiliary, and the one from the manufacture. I tried both plugs ins on my...
we have an ipod with an fm transmitter,(accessory)plays in any car wire free....trouble is when you brake hard, you cant find the damn thing......
Aug 28, 2010 | 2008 Scion Tc
Only 3 speakers play with ipod all other is ok
Are you playing your ipod through the stereo with a cable in aux mode? If so check your fader and balance settings when in aux.
there would be no other reason except for speaker wiring check and make sure there is no auxiliary wiring that may not be hooked up.
if it's not settings, then it's wiring, unless your stereo has an internal problem in the auxiliary circuit.
May 27, 2009 | Apple iPod MA446LL/A MP3 Player
I pod dock
There's an option to turn on the AUX input in the settings menu, I had the same problem with mine.
Mar 25, 2009 | Pioneer DEH-P7400 CD Player
2004 Ford Expedition rear floor cool/heat
Item Part Number Description 1 — Air inlet door 2 — Temperature blend door 3 — Headliner airflow 4 — Auxiliary mode door 5 — Floor airflow 6 18476 Heater core 7 19860 Evaporator core 8 19805 Blower motor
The auxiliary A/C and heating system has the following features:
  • The auxiliary A/C and heating system is functional whenever the instrument panel mounted A/C control is in any position except OFF.
  • The auxiliary blower motor recirculates the air inside the vehicle. Outside air is not available to the auxiliary system.
  • Air is cooled and dehumidified by the auxiliary A/C evaporator core only if the instrument panel mounted A/C control is adjusted to a position that requires A/C compressor operation.
  • The temperature blend door and the auxiliary mode door are controlled by electric actuator motors.
  • Movement of the auxiliary temperature control between COOL and WARM causes a corresponding movement of the temperature blend door to mix air flowing through and around the auxiliary heater core.
  • Movement of the auxiliary mode control between PANEL and FLOOR causes a corresponding movement of the auxiliary mode door to direct air flow between the panel (headliner) registers and the floor duct.
I would say the auxiliary mode door (#4) electric motor is not wokring.
Auxiliary Blend Door Actuator —Air Distribution Removal and Installation
  1. Remove the RH quarter trim panel cup holder and access panel.
  1. Remove the screws.
  1. Disconnect the blend door actuator electrical connector.
  1. To install, reverse the removal procedure.
Jan 14, 2009 | 2004 Ford Expedition
MP3 jack plug
You will need to use a 3.5 MM Stereo Cable with no resistance for the best sound on the Auxiliary input.
Jan 11, 2009 | Car Audio & Video
Pioneer DEH-65BT CD Receiver with Bluetooth, MIXTRAX, Pandora and iPod Logo
24 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
