Question about Nu Mark AXIS 9
How to calibrate axis 9"s - Nu Mark AXIS 9
    Problem Solver:
  • 4 Answers
Posted on Jun 09, 2014
Error 86:01
did you perform a scan axis calibration after changing all these parts? If not then you should do that before doing anything else.
Sep 01, 2014 | HP Designjet Z6100 InkJet Printer
Axis 9"s skipping
I solved this exact problem by re-calibrating the units follow this link to see how :) http://www.numark.com/images/product_downloads/axis9_recalibration.pdf
Dec 27, 2013 | Nu Mark AXIS 9
Why axis 9 smell burnt
Output IC might be damaged. Seek tech support.
May 27, 2012 | Nu Mark AXIS 9
DW079 CALIBRATION
Here is how you get your laser into adjustment modeY axis; Power and scan key at same time, unit then will tip from Y1 to Y2, then recenter. use up and down arrows to bring laser into adjustment. Let unit stabilize for 30 seconds, press scan key, you will get a continuos beep, now at same time press down arrow key. This will store your new calibration.To get X axis into adjustment mode power on and up arrow at same time, and for Z axis type laser onto Z axis and use adjustment procedure for Y axis. Saving your calibrations is the same as in Y axis. Hope this helps you
Jan 04, 2012 | Office Equipment & Supplies
Hello sir im in ksa ihave an hp designjet 500 series that problem was double print with every line pls tell me solve that problem
Hi and salam Moideen
The problem may be with the calibrations. First of all do the calibrations all i mean Color and line calibrations. If the problem still appears then you have to replace the Paper Axis motor which is responsible in moving the paper forward. If you replace the paper axis motor then you have to perform the calibrations which is a must.
Jul 20, 2011 | HP Office Equipment & Supplies
Does the axis 9 have a bpm counter????
my axis 8 does. i just dont have it anymore so i cant recall how to tell you how to do it but it does
Mar 16, 2011 | Nu Mark AXIS 9
My axis 9 wont play burnt cds
I'm having the same problem with the Axis 9 I just purchased on eBay. And so is the person who posted "Numark Axis 9's. . Problematic. Ahhhh!!!" Seems ridiculous that this would be so common. I definitely don't want to re-burn 100's of CDs just to use this CD player.
Nov 08, 2009 | Nu Mark AXIS 9
X-axis trouble
I had the same problem with my X52 and searched high and low on the internet for a solution. What I did was pop the base off and found a loose connection on the x-axis wires. I re-routed both the x and y axis contact wires underneath the p/s2 port and put it back together. Seems to be working fine now. I will not that opening up the controller will void your warranty and it also could be possible that your x-axis problem could stem from something completely different from what was wrong with mine. You may contact me if you need any help with it. mynameisbob AT gmail DOT com.
Jul 19, 2008 | Saitek (PS28) Joystick, Throttle
Error 0F0100030C099F on hp5000
found this maybe can help i dont know
I tried the fix of :
This may be an error finding the mark encoder. The mark encoder is the
white plastic piece on the left end of the roller. Replace the lense cover
first. If the error remains, turn the printer off, and place a piece if black
tape over the hole at the left end of the drive roller, this will block the
mark encoder from the line sensor and should trigger a 010092 error during
power on. When the 010092 error comes up,
press enter to continue past the error. After the printer comes ready, remove
the tape, and run a scan axis calibration.
To run the Scan Axis Calibration:
1. Enter "Device Setup".
2. Enter "Utilities".
3. Press the UP arrow and ENTER keys simultaniously,
4. Select "Yes".
5. Enter "Service Calibrations".
6. Run the "Scan Axis Calibration".
May 30, 2008 | HP DesignJet 5500PS InkJet Printer
Nu Mark AXIS 9 Logo
124 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
da surgen
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
