Question about Siemens HM19550EU Gas Kitchen Range
Manual operation Having just moved house I find myself unable to to use this cooker as the fascia is damaged.
2011 Dodge Caravan. Ran into a metal wheelchair ramp rain. Drove back - dislodged - the black trim insert near the bottom of the plastic bumper cover. That black plastic thing has to be just put back on...
Hello Bruce...here are the steps to follow per All Data.
Release hood latch and open hood.
Remove the headlamp assemblies.
Hoist vehicle and support with safety stands.
Remove the five push pin fasteners attaching bottom of fascia/air dam to radiator closure panel.
Remove front wheels.
Remove front wheelhouse splash shields fasteners as necessary to gain access to bolts attaching front fascia to fender.
Remove the two bolts and two nuts attaching fascia to the front fenders (Fig. 1) and (Fig. 2).
Disconnect fog lamp wire connectors, if necessary.
Lower vehicle.
Remove two bolts attaching the upper grille support to the headlamp mounting panel at each side of the grille.
Remove bumper fascia from vehicle.
INSTALLATION
Position front bumper fascia on vehicle (Fig. 1) and (Fig. 2).
Install the two bolts attaching fascia to headlamp mounting panel at each side of grille.
Install the two bolts and two nuts attaching fascia to the front fenders. The fascia should be flush to fender.
Install front wheelhouse splash shields fasteners.
Install front wheels.
Connect fog lamp wire connectors, if necessary.
Install the five push pin fasteners attaching bottom of fascia to radiator closure panel.
Lower the vehicle.
Install the headlamp assemblies.
The "push pin fasteners" are the pain you are having i believe. They push in, but to get them out you need squeeze them on the back & pull at the same time. If you happen to break a few, you can buy them in various sizes at the auto parts store. I hope this information is helpful, an owners manual will not have any info like this in it.
Dec 02, 2011 | Cars & Trucks
Ignis_Manuals built in cookers akl905wh
The Inglis site does not post manuals. Recommend you contact the Inglis Customer Experience Center directly at:
Toll-Free 1-800-807-6777
Oct 30, 2011 | Crock Pots & Slow Cookers
I have a stoves farmstyle 1100 df cream range cooker. I am having problems with the timer and have bought a new one but I need to know how to remove the top to fit it. The cooker serial number is 050564146
Hi.
To replace the timer control you need to remove the front fascia panel and the hotplate at top.
Before starting disconnect power and move the range forward.
To remove front panel you need to undo the 4 screws at the sides and to remove the knobs, then remove front panel.
To remove the hot plate you need to remove 4 screws at the back. There are also 4 screws at each side of the hot plate. You may need to remove the side panels to reach those screws. There is also an additional screw located behind the control.
Here a service manual for the range Farmstyle 1100E, which is similar to 1100DF. The disassembling instructions for top and front are at pages 62 to 64 of PDF (sections 4 to 6). Control board and touch pad are at page 67-68 (sections C and D of disassembling).
Service manual: Stoves Farmstyle 1100 1st.pub
Regards.
Ginko
Oct 07, 2011 | Stoves 1000DFDLm Gas Kitchen Range
How do you remove the air filter box on a 2001
REMOVAL
Access Rubber Grommet
Remove large rubber grommet (70 mm x 168 mm) from splash shield to gain access to fascia fasteners.
Fastener Locations
Remove fasteners attaching fascia to the front fender and splash shield, using access hole in splash shield.
Remove Push In Fasteners
Remove the push pins attaching the fascia to the upper radiator closure panel.
Headlamp Jack screws
Remove jackscrews attaching headlamp housing to crossmember and remove the lamp housing to access the lamp(s).
Roll Fascia Forward
Roll fascia forward to clear way for headlamp housing removal.
Disconnect wire connector from back of lamp socket(s) and/or bulbs.
Remove Headlamp Housing
INSTALLATION
CAUTION : Do not touch the glass of halogen bulbs with fingers or other possibly oily surface, reduced bulb life will result.
Place headlamp housing into position.
Connect wire connector to lamp socket(s)
Verify headlamp and signal lamp operation.
Install jackscrews to attach headlamp housing to crossmember.
Align fascia to bumper reinforcement and install the top center push pins, to upper radiator closure panel.
Align the two fascia studs to the fender vertical attachments, at the same time align the fascia groove on the horizontal flange with the fender drive pin. Push fascia rearward to engage the fasteners.
Install nut on fascia stud through the splash shield access hole.
Verify headlamp operation and alignment
Nov 03, 2009 | 2001 Chrysler 300M
Lost cooker manual during a house move
Try downloading a manual from
http://www.usersmanualguide.com/parkinson_cowan/cooking/page3
However, you need the product number code to get the exact manual for your cooker.
Good luck,
bornleader
Sep 24, 2009 | Parkinson Cowan Kitchen Ranges
Lost the manual for a new world cooker
To get a new (pdf) manual ask at http://manualfox.com - they find you every manual.
Jul 31, 2009 | Ovens
How do you replace headlamp bulbs on 1999 chrysler 300
You half to remove the Headlamp housing to change it. Here is the instructions out of the factory manual.
Tell me if this works for you?
HEADLAMP HOUSING - CONCORDE/LHS/330M Headlamp lens fogging is a normal condition and does not require service unless excessive or continual. Moisture will vent from tubes or vents located on the back of the lamp.
REMOVAL
  1. Release hood latch and open hood.
  2. Remove large rubber grommet (70 mm x 168 mm) from splash shield to gain access to fascia fasteners Access Rubber Grommet
  3. Remove fasteners attaching fascia to the front fender and splash shield, using access hole in splash shield Fastener Locations
  4. Remove the push pins attaching the fascia to the upper radiator closure panel Remove Push In Fasteners
  5. Remove jackscrews attaching headlamp housing to crossmember and remove the lamp housing to access the lamp(s) Headlamp Jackscrews
  6. Roll fascia forward to clear way for headlamp housing removal Roll Fascia Forward
  7. Disconnect wire connector from back of lamp socket(s) and/or bulbs.
  8. Remove headlamp housing Remove Headlamp Housing
INSTALLATION CAUTION: Do not touch the glass of halogen bulbs with fingers or other possibly oily surface, reduced bulb life will result.
  1. Place headlamp housing into position.
  2. Connect wire connector to lamp socket(s) and/or bulbs.
  3. Verify headlamp and signal lamp operation.
  4. Install jackscrews to attach headlamp housing to crossmember.
  5. Align fascia to bumper reinforcement and install the top center push pins, to upper radiator closure panel.
  6. Align the two fascia studs to the fender vertical attachments, at the same time align the fascia groove on the horizontal flange with the fender drive pin. Push fascia rearward to engage the fasteners.
  7. Install nut on fascia stud through the splash shield access hole.
  8. Verify headlamp operation and alignment
Mar 27, 2009 | 1999 Chrysler 300M
Lost Manual - not sure which is high or low
Hi. I'm a Ronson Service Centre.
I grabbled this blurb from a Ronson Slow Cooker Manual. Not the same model, but it has the same settings:
On Setting 1 (Low) the Slow Cooker can operate all day and night if required.
When set to 2 (High) it is very much like a covered pot on the stove. Foods will cook in ½ the time required for 1 (Low)
When set to Auto, the Slow Cooker will cook on 2 until the food reaches a pre-set temperature, then switches to 1 and maintains a constant slow cooking temperature.
“Auto” is the ideal setting for someone leaving the house for the whole day as most food will cook for 8-9 hours and be ready to serve when they return.
Mar 15, 2009 | Crock Pots & Slow Cookers
' Fagor 2h-134 I ' cooker manual needed
Hello
Are you looking for the pressure cooker manual?
Jul 12, 2008 | Fagor Cooktops
Damage
Here is a replacement Fascia:
http://cgi.ebay.co.uk/Original-Samsung-F300-Housing-Cover-Fascia-Brand-new_W0QQitemZ140207015445QQcmdZViewItem?hash=item140207015445&_trksid=p3286.c81.m20.l1116#ebayphotohosting
Kind Regards ACD
If you need it fitting please reply
Mar 14, 2008 | Samsung SGH-F300 Smartphone
Siemens HM19550EU Gas Kitchen Range Logo
101 people viewed this question
Top Siemens Kitchen Ranges Experts
R.A. Ellis
R.A. Ellis
Bill Boyd
rpar
Are you a Siemens Kitchen Range Expert? Answer questions, earn points and help others
