Question about Panasonic NN-P295SF Microwave Oven
Panasonic NN-P295SF door release problem I have a Panasonic-P295SF and something has broken or come loose in the door release. It still works but hangs strangely and has to be pushed on all four corners to function. I want to remove the control panel to see if I can fix it, but I am unsure how it comes off. There is a screw at the base of the door release, but it seems to not be attached to the control panel. There are two screws at the top near the vent that look like they might help. I don't want to break it as it is built in to the kitchen. Can anyone help?
5 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic NN-T687 (The Genius) door
You will need to remove the oven from the frame, then remove the outer cover from the door.
Once the outer cover's off, you'll be able to see that door opening button presses against the door opening lever, which presses up on the door key/hook to open the door.
Usually the problem is a broken door opening lever.
You can order that part directly from Panasonic here.
Once it's fixed, if you want to download the owner's manual, it's here.
We have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 26, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic nn-p295 blows buss fuse when turned on for cooking
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer. But this is likely an inverter model, so it wouldn't have one and would be some other component in the inverter I'd say.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/xformer.html
http://www.gallawa.com/microtech/mag_test.html
The best place to order Sharp parts is Tritronics. Or you can call them toll-free at 866-779-5835.
Posted on Dec 26, 2008
SOURCE: Door Release Button not working on Panasonic Microwave NN-T664SFT
The problem I had experienced with the Door not opening easily will be resolved by removing the micowave oven top cover with a tamper proof torx head, replacing the door switch and reinstalling the top cover.
Posted on Jan 20, 2010
eugbug
  • 479 Answers
SOURCE: Need an installation instruction manuel for
The instructions for this model can be found here:
http://www2.panasonic.com/consumer-electronics/support/Home-Appliances/Microwave-Ovens/Prestige-Countertop/Built-In-Microwaves/model.NN-P295SF
Hope this helps!
Posted on Feb 24, 2011
Door does not open
You'll need to remove the outer cover to get to the door open button or door lever, either of which can cause this problem.
The service manual is here.
You can order Panasonic parts from Encompass here or you can call them toll-free at 866-779-5835.
Jan 15, 2013 | Panasonic NN-P295SF Microwave Oven
DOOR WILL NOT CLOSE ON NN S752 WF PANASONIC MICROWAVE OVEN
it looks like theres a faulty door lock mechanism have it checked out and replaced!
Sep 25, 2011 | Panasonic NN-P295SF Microwave Oven
How do I change the door hooks on a panasonic micro?
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
A Panasonic service manual covering some models is here.
Sep 14, 2011 | Panasonic NN-P295SF Microwave Oven
When power went off and then came back on, screen on micro wave continually shows demo and I cannot set time
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes and try again.
If it still won't work, then you may have a bad membrane keypad / DP circuit.
If your model is NN-P295SF, the service is here.
Parts can be ordered from Encompass here.
Aug 19, 2011 | Panasonic NN-P295SF Microwave Oven
Have a Panasonic Microwave Mod. # NN-P294BF. The Door opener (push button type) became detatched from the door latch. It is mounted over the stove. Do I have to take it down to be able to take the...
Here you can find what you need for a very similar model
http://www.searspartsdirect.com/partsdirect/part-model/Panasonic-Parts/Microwave-Parts/Model-NNSD297SR/0789/0123370/50036271/00001?blt=06&prst=0&shdMod=NN-SD297SR
Yes, to take down the face you must have the unit fully accessible - the bolts are accessible only from the rear.
Apr 13, 2011 | Panasonic NN-P295SF Microwave Oven
Microwave fuse keeps blowing on my Panasonic Microwave NN-9854P
I would check the door interlock switches and then if that doesn't fix it replace the invertor board and possibly magnetron.
Feb 21, 2011 | Panasonic NN-P295SF Microwave Oven
My model nn-p295wf microwave stopped working ,all power just stopped, about a year ago. I took it to a repair shop and they replaced the DIODE and the fuse, then it worked again. Afew weeks ago it happened...
Replace the magnetron, safety fuse and diode as a set and check the door interlock switches.
That should get it working for another year or so.
Don't forget microwave mains fuses are special sand filled and semisurge type.
Nov 16, 2010 | Panasonic NN-P295SF Microwave Oven
Panasonic NN-P295SF Microwave Oven Logo
74 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
