Question about Exercise & Fitness
Pacemaster proelite treadmill
Belt is going in reverse
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 163 Answers
You connected the drive motor wires backwards. Reverse the wires from the drive motor.
Posted on Jan 04, 2014
SOURCE: richelle07
was able to locate error codes from manufacturer.
Posted on Sep 10, 2009
  • 1796 Answers
SOURCE: Where is the elevation fuse on a Pacemaster Gold
Hi!!
On page 6 of your owner's manual, step 3 shows a diagram to remove the shipping bolts. On that diagram, you can see the motor and the power cord wrapped around it.
Click on the following link to get a copy of your owner's manual on .pdf format, scroll to page six and magnify it to 400%, you should be able to see the blue circuit board and two white fuses. Make sure your Pacemaster is disconnected before working on the fuses.
http://www.pacemaster.com/manualPDF/PremiereGoldEliteFoldup.pdf
A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Posted on Nov 06, 2010
ercupa190
  • 12223 Answers
SOURCE: pacemaster treadmill no power
http://www.youtube.com/watch?v=N6Yg5S0WML8
see the step for torubleshooting your problem.
Of course test the breaker or fuse from your house. See if the wire ground is connected to your outlet supply. Do not use any extension cord.Use regulator voltage recommended.
If necesary call some electrician .
sincerely.
Posted on Dec 22, 2011
SOURCE: looking for a user manual for a pacemaster proplus treadmill
I have a pdf of the Owners Manual for a PaceMaster Pro-Plus Treadmill. I am attempting to upload it to www.manualsonline.com, so if you still want it, hopefully they will have it soon.
Posted on Jan 11, 2013
  • 7 Answers
SOURCE: Pacemaster treadmill will not start, no lights, nothing.
Is there a spot on the control board you can check for out going power? You might have a bad board. You can visually inspect your board for anything that looks burnt or one component that looks swolen or loose. Poor solder joints are a common problem with treadmills because of the constsant movement.
Posted on Feb 19, 2013
How to adjust tension belt on pacemaster proselect treadmill
Tread Belt Tension Adjustment - Aerobics ProSelect ...
www.manualslib.com > ... > Treadmill > ProSelect > Owner's manual
Aerobics ProSelect Manual Online: Tread Belt Tension Adjustment. Step One:Locate ... Treadmill Aerobics PaceMaster Gold Elite Owner's Manual. Treadmill (38 ...
Aug 26, 2015 | Exercise & Fitness
New Magnetic Key
Go to walmart and look in kitchen goods. Look for refrigerator magnets and find small one... It will work... Looks cute too.
Jun 22, 2014 | PaceMaster ProPlus II Treadmill Incline...
Pacemaster Pro Plus treadmill popping fuse
You need to replace the walking belt. Don't use the machine until you've replaced that.
May 22, 2017 | Exercise & Fitness
Treadmill belt will not move
This can be caused by a few things...call for service 877-805-1030
Jan 03, 2014 | PaceMaster Gold Elite Treadmill Deck
I have a Pacemaster Gold treadmill that will not hold elevation. I have no error codes. It will go to the proper elevation and then immediately start descending. If I change the elevation setting it will...
Run the utility software calibration for easy diagnostic, and fix it.
Go to HOOD open the cover motor and follow the steps indicated. or your owner manual.
God bless you
Sep 30, 2013 | PaceMaster Gold Elite Treadmill Upper...
Pacemaster treadmill err 133
I just fixed the same 133 error, it's about the communication between motor module and upper panel. There is an 8 wires cable, uses standard RJ45 connectors. In my case, one of the RJ45 connector to motor module is poorly done by the manufacture, so the connection is not reliable, I re-do the connector, problem fixed.
Apr 15, 2013 | Treadmill Doctor Pacemaster Platinum...
Feb 18, 2013 | PaceMaster Aerobics Pro Plus Walking Belt
Looking for a user manual for a pacemaster proplus treadmill
May 08, 2012 | Exercise & Fitness
Exercise & Fitness Logo
61 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
