- Thanks Koolkidkip! It's not a tube amp, so that rules that out. As for the OHM load, not too sure how to check that. I'll try reducing the signal going to the amp and turning up the gain on the unit, so if that helps... the problem is it would cost about $100 to have someone look at it, and it's about $150 to replace it! (I sure appreciate the suggestions though!)
- @ Cloudio.
Any chance you could elaboarate on your solution?
Where would I find a 44.62.9.012 12VCD Coil 2x 10A changeover relay and are they expensive?
Was this the only thing you replaced? I have no idea about electronics unfortunatly but I may approach someone who does so knowing what to replace and where to get it from would be very useful.
Is your amplifier still working perfectly now after a few days of use?
Oh yeah, Alesis have ignored every one of my emails on their technical support page. What is more frustrating is that other amplifiers on the market at the price range (i.e Samson) are apparently fitted with the same components as the Alesis RA series so I assume they would have this problem too. This makes looking for a replacement amp on a budget very difficult.
- Had the same issue as described (RA-300). Replaced the offending relay with an 8A version: Finder 50.12.9.012.1000 -
http://nz.farnell.com/finder/50-12-9-012-1000/relay-pcb-safety-8a-12v/dp/1329680
Now works a treat.
- I just replaced the "relay in question" on my RA300 and initial results are great! *crosses fingers* FIXED!
- I've got an Alesis RA300 that worked well for about 1 year then the channels started crackling in and out. Tapping the top shifts the problem from one channel to the other.
- I'm also having crackles and dropping channels with with RA-150. I'm tempted to try replacing the relays. Do I need to drain any capacitors before working on this thing?
- Same problem will replace relay thanks fellas RS 300
Need additional assistance?
Popular Solutions for Alesis RA-150 Amplifier
the fuse keeps blowing in my amp,
the fuse keeps blowing in my amp, changed the fuse several times but just keeps blowing!!!
no bass and muffled quiet sound... help
i am plugging my ipod directly into the amp ( alexis ra150 ) from 2 phono inputs. the output from the amp is quiet ...
Samson power amp capacitor?-HELP!!!!
I have a Samson s1000 power amp that has a blown capacitor. The (value) or numbers on the capacitor are Samwha 100 ...
2*400 Ohm headphones - Can't get enough ...
Hi there! I am an owner of the Beyerdynamic DT 100 headphones. These headphones feature 2*400 ohm resistance on each ...
Amp cuts out after a while
The amp works great for an hour or so then starts to crackle and cut out intermittently. Any ideas?
My amp keeps switching off after 5 seconds
Looking for manuals to digital surround processor
Looking for manuals to digital surround processor SH AC5000 and Digital stereo reciever processor SA AX6. Where can I ...
How to use the SUPER
How to use the SUPER BASS ? what speaker will I buy for this ? thanks
My EMX-312SC POWER OFF. I
My EMX-312SC POWER OFF. I want replace the fuse inside. Where the power fuse inside the EMX-312SC?
RA-150 Amplifier: I have my motor home hooked up ...
I have my motor home hooked up to the house and it keeps blowing the cirtuit this has never happend before any idea what ...
