Question about Bissell SpotBot Hands-Free Compact Deep Cleaner - Silver
Spotbot trigger won't pump - Bissell SpotBot Hands-Free Compact Deep Cleaner - Silver
The top of my Spotbot separates from the bottom when picked up
There are a few screws that hold the two parts together. Check the housing and see if cracked around those screws.
SpotBot Supplies
800-775-6586
GoodVac com
Feb 22, 2015 | Bissell SpotBot Hands-Free Compact Deep...
How do I clean the spray tip on my spotbot? It isn't spraying.
if it's not been used for a long time the pipes may be cloged up or the pump may be siezed up this video will show you how to dismantle it to check inside.
http://www.youtube.com/watch?feature=player_embedded&v=1sSVIu6arbY#!
Nov 22, 2012 | Bissell SpotBot Robotic Wet/Dry Vacuum
My Bissel Spotbot will only let me use the Manual Mode, when I try to push "Set in Stain" or "Surface" stain the light won't turn on. My children were playing with it, but I...
There is a small magnet in the end of the hose. Under the phillips screw and plastic cover. Mine rusted to bits and stopped tripping the switch. A bit of a super strong hard drive magnet siliconed back in the end of the hose and all was fine.
May 26, 2011 | Bissell SpotBot Robotic Wet/Dry Vacuum
When I set it to manual, the sprayer won't spray. The sprayer light is on though
Hello, I hope this helps you...1st, rinse out the little filter that sits in the hole where you place your "Cleaning Solution" tank. It's a small piece of felt. If this gets loaded with dirt or soap...the machine WILL NOT SPRAY. If this doesnt work and your machine is out of warranty...there is an easy fix for about $20 Unplug the unit. Remove the screw under the clean solution tank, remove that plate and remove the two screws under it...next remove the 4 screws under the "Dirty Water" tank. Lift off the top of the machine and you will see a little red pump under the "clean solution" tank area. Remove the 2 screws and clamps holding it in and replace the pump. (Just do a Google search for "SPOTBOT Pump" until you find one.) That will do it. After replacing the pump, fill the clean solution tank..check for leaks and let the unit sit overnight. The pump has to fill with solution to work...
Jan 18, 2010 | Bissell SpotBot Robotic Wet/Dry Vacuum
Bissell spotbot: leaking the dirty water from bottom. I took the bottom plate off and there is a really crappy rubber seal. I think it is leaking from there.
I had the same issue. After some research, I determined I was missing a black "duckbill" gasket on the bottom of the dirty water collection tank.
This caused reduced suction, and for the water to pool at the botom of the spotbot, thus leaking.
I purchased the gasket at Bissell for 1.39. The part number is 203-6646.
I purchased my SpotBot new from Target, and never remember seeing this black gasket, but the difference is night and day.
Sep 07, 2008 | Bissell SpotBot Robotic Wet/Dry Vacuum
No Power on Bissell Spotbot
board likely not available, contact Bissell dealer.
Jim
Jul 27, 2008 | Bissell SpotBot Robotic Wet/Dry Vacuum
I have a bissell spotbot. The trigger on the spay head sticks open when pressed. It will not shut off. HOw can it be fixed?
If it comes apart, see if cleaning will help. other then that you will have to replace the hose asm. part #2036665 .
Apr 20, 2008 | Vacuums
User guide
You will need Adobe Reader to read/print these manuals
Use the following link and click Get Adobe Reader
http://www.adobe.com
There appear to be two models the user guides are in the right column -- be sure the models are right the model numbers 1200-a and 1200-B appear under specs
http://www.bissell.com/Bottom_Menu/Product_Search.aspx?Criteria=spotbot+1200
Dec 22, 2007 | Bissell SpotBot Robotic Wet/Dry Vacuum
Bissell SpotBot Hands-Free Compact Deep Cleaner - Silver Logo
29 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
