Question about Brother CS6000i Computerized Sewing Machine
Needle hits bobbin holder
Removed bobbin holder to clean, when I replaced it the needle hits the holder. Is holder supposed to turn?
  • 1,263 Answers
Hi, sounds to me like you haven't refitted the bobbin correctly
Regards
www.electronicrepairs.co
Posted on Dec 28, 2013
Testimonial: "Duh!!! How stupid do you think I am?"
  • Robin Hill
    Robin Hill Dec 29, 2013
    Sorry no insult intended but this is common problem... what happens is that the bobbin does not click home,,
SOURCE: Needle won't pick up bobbin thread - HELP!!!
I recently fixed my wife maching with the same problem. I found that the screw had come loose that holds the linkage together that rotates the bobbin holder. I was fortunate enough to notice the screw while looking at the machine. To replace it requires taking both the front and back covers off of the frame since the bobbin holder linkage is in the rear behind the needle area. Be careful to insure that the plastic toothed "rail" that runs the bobbin holder is positioned properly or it may break off a tooth. Once I replaced the screw and put the machine back together, it picked up the thread with no problem. Hope this helps.
Posted on Apr 15, 2007
jmeredith
  • 417 Answers
SOURCE: Bobbin holder turns and keeps bending needles
hi,
the whole upper assembly may have come out of alignment when the machine bent the needle, the upper cover may have to come off, and study the inner metal area where the needle is attached for alignment bolts or screws, maybe one has come loose. On ours if you choose the zig zag and adjust it all the way out it will do that everytime. maybe download the user manual at www.brother.com and see if theres something in there also.
J
Posted on Jul 23, 2008
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Posted on Apr 07, 2009
SOURCE: bobbin holder
Make sure the needle is in the highest position before you try putting the bobbin holder in. The bobbin holder has a metal 'finger' which fits into a 'slot' in the housing and it only goes in if you have the needle up.
Posted on Apr 17, 2009
  • 52 Answers
SOURCE: Needle holder fell off of machine
there should be an allen screw on the back side of the needle bar clamp push it up and on and make sure its as stright as you can get it and tighten down on the allen screw
Posted on Jul 14, 2009
My sewing machine is a Janome Magnolia 7330. The hand wheel will not manually turn backwards to raise or lower the needle. When sewing, the bobbin stitches are loose and looped.
I would find a local sewing machine sales and repair shop near you. You will need to have them look into this, it may be a timing issue or a broken or damaged part.
Feb 16, 2017 | Janome Sewing Machines
How would I secure the hook and race so they don't move after they're clipped in?
Your repairman is what's wrong! The bobbin case I believe is what you are talking about. (I hope you didn't remove the race)
1. Anyway the bobbin case has to be snug so it doesn't move clockwise or counter clockwise. If it moves the needle will crash . If your machine is an older one the truth is the same.
2. The bobbin case cannot be allowed to spin. See adjustment!
3. Before you start sewing again clean the feed dog real good.
4. Before you put the bobbin in the bobbin case (on top of race) put a drop of oil on the race.
5. Replace the needle. This is important.
If you still have a problem your machine probably needs to be timed due to the needle crashing before.
Feb 23, 2015 | Sewing Machines
I have a Janome Memory Craft 4900. I broke a needle while sewing in a zipper. I replaced the needle,but now the machine makes a medal scraping noise when I sew. I took off the needle plate and bobbin...
did you find the tip of the needle? Also you may have a nick in the metal where the needle hit and broke.It can catch on other parts and need to be sanded or replaced.One time I had this issue and I found the tiny broken tip under my bobbin case.
Jan 18, 2014 | Janome Sewing Machines
I have a Sears Kenmore sewing machine model 385.16231300 problem I'm having is the bobbin holder won't turn. I have cleaned it. Purchased a new holder and that was not the problem.
When you say bobbin holder do you mean the bobbin case where you drop the bobbin into? That part is not supposed to turn. The metal ring (the hook) below that is what turns. I'm assuming you are having a stitching problem. First check the needle. Make sure it is in correctly and up as far as it will go. Then check the treading. Without more information it will be hard to help further.
Sep 15, 2013 | Kenmore Sewing Machines
Pfaff 1472
make sure that the needle was put in the needle holder correctly and tightened into the needle holder correctly..
if the needle was in the needle holder correctly and it's still hitting the bobbin carrage then the machine needs to be checked to see if the sewing machine needs a adjustment
Aug 17, 2013 | Sewing Machines
Singer Athena 2009 needle hitting plastic in bobbin case
here's something to check
is the needle inserted all the way in to the needle holder?
needle--flat side goes to the back of the machine
is the needle clamp screw tight or loose?
if the needle is correctly in the needle holder & the needle clamp screw is tight --then the needle bar is out of time & need to be serviced
IF YOU DO HAVE TO TAKE IT TO BE SERVICED AFTER YOU GET IT HOME STOP RIGHT THEN & SEW ON THE MACHINE TO MAKE SURE THEY FIXED THE MACHINE & IT SEWS LIKE IT SUPPOSE TO, I HAD ONE CUSTOMER THAT TOOK THEIR MACHINE TO A SHOP & THEY CLEANED IT AGAIN & DIDN'T FIX IT BUT CHARGED THEM FOR IT & THEY BROUGHT IT TO ME TO FIX & IT HAD TO BE RETIME
did you get a instruction manual for the machine if not check at singer
Go to the singer website
Click on customer support--there will be a drop down menu
Choose instruction manual
In the box type the model number---2009
Click search--if you don't see a manual--contact singer customer service
Feb 11, 2012 | Singer Sewing Machines
I was sewing a straight seam and all of a sudden the thread wouldn't pick up the bobbin thread anymore. Now I can't sew and have much to sew for a wedding in 5 days. Can I fix this myself? When I turn the...
If you can hear a click then I'd say the needle is touching some part of the hook mechanics which could mean timing is out. However, it is possible that the bobbin case has just moved a little so as first trouble shooting steps, I'd suggest the following:
clean out the bobbin holder area as per manual (ie. remove the needle plate, bobbin, sewing foot and needle, take out the bobbin holder, clean the race area out, then put bobbin holder back in as per your manual, there is usually a stopper and knob or two red marks to line up. This is held by a magnet so it is possible to knock it out of place during a jam up.
Replace needle plate, bobbin, sewing foot and put in a new sharp needle, flat shank to the back and make sure it is fully up into the holder, thread up and very slowly using the needle up and down button, test sew a couple of stitches again.
If no stitch formation or you can definitely hear/see something touching then I'd say timing is out and no, its not something fixed yourself; best left to a trained technician.
Apr 11, 2011 | Elna Quilter's Dream 6003Q
Thread is knotting up under the feed dog plate getting error LO.I tried removing the plateand cleaning and replaced bobbinholder and it is still jamming. is there supposed to be any play in the bobin...
It should move a little so the thread has clearence. If the thread is bunching underneath, it usually means the thread's not in the take-up lever or top tension is too loose. If you're needle has hit the bobbin case and created needle marks, the thread can get caught... in which you'd need to replaced the bobbin case.
Feb 23, 2010 | Janome 8080 Computerized Sewing Machine
My DB2-B797 suddenly has needle breaking because needle is hitting bobbin. I need help with technical specs and needle positioning. PLEASE
Hi
First thing to check is are you using the correct needle, if it is too long this will hit the bobbin holder.
If the needle is the correct one, for some reason your timing is out or the needle bar has dropped lower than it should be.
I can't explain on here how to re-time as it is complicated.
If the timing is out it is very unusual as the working parts are locked in position.
Take out the thread, remove the needle plate and turn the machine over by hand watching the needle and see if it is actually hitting the bobbin or bobbin holder.
Rob
Jan 02, 2010 | Sewing Machines
The bobbin holder turns so the needle hits the holder and breaks.
Out of alignment means the timing is off...take it to a pro to have it cleaned and re-timed...if that's the real problem.
However, it seems that you think the issue is may be a bobbin holder that wasn't installed properly??
Do you have a top, side, or front loading bobbin?
Sorry...I don't understand: "If I manually turn the bobbin and holder clockwise just as the needle comes down, it goes all the way down without breaking or bending."
Do you mean that you're turning the hand wheel towards yourself...and that works properly? If so, it's probably not a timing issue.
If you have a metal bobbin case that you insert a wound bobbin into and then place that bobbin holder w/bobbin into your machine...perhaps the bobbin case just needs a slight turn in order to snap into place.
If that's not it, check your machine's manual to see what part might be missing...then, to find that small, shiny metal part, try shining a flashlight across the area where it was lost.
Apr 06, 2017 | Brother XL-2230 Mechanical Sewing Machine
Brother CS6000i Computerized Sewing Machine Logo
107 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
