Apex LE3245M does not function whatsoever. The remote doesn't work, the only button that works on the television is the power button and that's it.
  • 6 Answers
SOURCE: 32" Insignia TV (functions don't work)
new power board at partstore.com or andrewselectronics.com mfg. advent part# 667-L32K5-20C $68.00 works great!!
Posted on Jun 05, 2008
  • 121 Answers
SOURCE: theres no picture on my sony bravia KDL-40S4100
Try pressing the TV/Video button. The problem could be that the TV is set to an input with no source.
Posted on Feb 25, 2009
SOURCE: channel button on tv and remote control dosent work
Just press menu go to auto search
problem fixed and you'll have more digital channels as well
Posted on Mar 29, 2009
budmrtn
  • 11361 Answers
SOURCE: the remote control has power, the television
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera’s Lens (Digital Camera can detect IR), you should see flashing light on the camera’s screen when any one of the remote button is pushed.
If the remote does send out signals, then the problem can be the IR receiver in the TV, it can be due to failed 5vdc or the IR receiver module is bad.
http://www.shopjimmy.com/catalogsearch/result/index/?q=Sharp+Aquos+LC-42D62U&limit=25
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Posted on Jun 28, 2010
SOURCE: Remote sensor on the APEX
The set is slow to respond but you must have a clear shot at the lower right corner of the set. That is where the signal is received. Our sofa cushiopn sometimes gets in the way and must be moved. When a signal is received the blue light comes on.
Posted on Jan 11, 2011
Selecting these options without remote control? This is a Apex digital LE3245M.
You should be able to toggle between options using the volume plus and minus or the channel plus and minus followed by the enter key.
Dec 20, 2015 | Televison & Video
I have a APEX LE3245M TV, this morning the screen went black but the sound was good.
Check out the inverter board. It is responsible for the back lighting so you can see a picture.
Oct 08, 2015 | Apex Digital Televison & Video
LE3245M apex tv i
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
May 06, 2014 | Televison & Video
Apex k12b c2
If only one button do not work, it might be set right by cleaning it. But to clean it, you must open the remote control If you check the link given below, you can get the procedure about how to clean , repair and check a remote control http://electronicshelponline.blogspot.com/ Pull up older posts there.
May 25, 2013 | Apex Digital APEX K12B-C2 Remote Control
Apex model #AT2704S front panel buttons stop working? Menu, channels, volume, and power? Also has a red key in lower left corner and the screen is blue. I have tried mute and function buttons on univ
Your Apex TV has been locked by anyway. Just try this method to unlock it.
Apex TVs have parental locks that allow you to block certain programs based on
their rating. When this feature is no longer needed and you want your TV to display all programming no matter its rating, you must unlock your TV. Unlocking your Apex TV is done completely from your remote control and does not require any tools. The process takes less than 5 minutes.
• Press the "Menu" button on the remote control and use the arrow buttons to scroll down to the "Parental Guide" option, then press the "Enter" button.
Type in the default parental code "6688" if you have not set your own code. If you have set your own code, type it in. If you set your own code and forgot it, override it by using "6688."
Use the arrow keys to switch the parental lock to "OFF." This allows all programs to be viewed no matter the rating. Press the "Exit" button on the remote and start watching all your channels.
Feb 07, 2013 | Apex Digital Televison & Video
My remote doesn't work
Do you have any flashing indicator lights on the remote? If you don't you can verify your remote is sending IR signals by pointing a cell phone camera at the front of the remote and viewing through your cell phone screen while holding down a button on the remote. You should see the flashing IR light on your cell phone screen. If you do not see the flashing light either the batteries are no good, or the remote is not getting power due to a problem with the circuit board.
Nov 23, 2012 | Apex Digital Apex 40" Class 1080p 60Hz LCD...
How to program the TV remote to work with an APEX DVD player? I do not have the APEX DVD code.
As far as I can remember, the original JVC remote doesn't support a DVD player. It doesn't have the necessary buttons to control the player functions. You'll need to stick with the original Apex remote if you have it, or look for a universal remote that is compatible.
Jul 30, 2011 | JVC AV-32D502 32" TV
How do i unlock a Gt 3215 apex tv? and where and how does the function button look like on a remote??
Hello
Apex TVs use a four digit code to control the v-chip. The override code for many models is 6688. Other sets may not have one, or may have a default code of 1225 instead of an override code.
  1. To use the override code:
  2. Hit the MENU key to get to the menus.
  3. Go down to the SYSTEM menu and hit the right arrow on the remote control.
  4. Once in the SYSTEM menu, go to PARENTAL GUIDE. It will ask for your code.
  5. Enter the override code listed above. From here, you can turn on and off different rating restrictions, as well as set a new code.
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired.
Function buttona nd Menu buttons are the same or some remotes. I don't know whether you have the original remote of Apex or not. On original remote there is a function buttom marked as Function.
OK>
Jan 06, 2011 | Apex Digital GT3215 32" TV
Problem with code for apex ld3249
You can power scan for the code.
Turn ON the electronic device you want to program the remote to control.
Press the Mode button( sat,tv,dvd,aux) on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Apr 07, 2010 | Apex Digital LD3249 LCD TV
Remote control chkt1a for apex tv does not work properly. None of the functions work even though while pushing the buttons the red dot works but nothing happens on the tv
You may have bad solder joint inside the remote and especially on the l.e.d at the front, happens often(remote dropped etc.). If you have a soldering iron you can open it a make a round of the solder joints, it should fix your problem. Hope this will help.
Dec 02, 2009 | Apex Digital PF2025 20" TV
Televison & Video Logo
208 people viewed this question
Top Televison & Video Experts
