Question about Magnavox Audio Players & Recorders
Setting the alarms on aj 3240/17 - Magnavox Audio Players & Recorders
2015 AJS JSM 50 wiring diagram
Hi, Simon for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your AJS, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
AJS JSM 50 wiring diagram Google Search
https://www.chinesemotorcycledealers.co.uk/downloads/50cc_Wiregram_AC.pdf
http://fullmanuals24.com/brand/ajs
JSM 50
Ajs Jsm 50 User Manual
Oct 02, 2017 | AJS Motorcycles
AJS JSM 50 won't start
Hi, Joe and the usual suspects are:
1. Fuel tank empty.
2. The fuel tank has old dead gas.
3. Fuel tank bottom contaminated with ethanol sludge, dirt, water, rust, etc.
4. Fuel supply valve/petcock turned off.
5. Fouled spark plugs.
6. Engine flooded as a result of overuse of the enrichner.
7. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
8. Fuel valve/petcock or filter clogged.
9. Fuel line to carburetor or throttle body pinched, kinked or blocked.
10. Carburetor float stuck.
11. Fuel injectors clogged.
12. Fuel injectors stuck open.
13. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a cursory reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
14. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
15. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
16. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections loose, or connected to the wrong cylinders.
17. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
18. Faulty neutral, clutch lever, or kickstand safety switch.
19. Faulty fuel pump or fuse or relay.
20. A stuck bent or burnt valve.
21. Tilt sensor needs a reset.
22. Security system not disarming alarm needs a reset.
23. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
AJS Regal Raptor won x27 start
What to Do Check When Dirt Bike Won Start
Workshop Manuals
AJS 50cc Mopeds 125cc Scooters Motorcycles Motorbikes for Sale at AJS
Owners Manuals
Jul 29, 2017 | AJS Motorcycles
AJS regal raptor 125 fuse box location
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your AJS, despair not, for a mere $15 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
AJS regal raptor 125 fuse box location Google Search
AJS Regal Raptor DD 125 04 06 Manual Haynes $15
http://www.ajs-shop.co.uk/acatalog/Regal-Rapter-Parts.html
Regal Raptor DAYTONA 125 User Manual
AJS Regal Raptor DD125 MK2 2010
Mar 15, 2017 | 2008 AJS Regal Raptor DD50E2
2011 ajs regal raptor wont start no spark any ideas
Hi Allen, if you have a CKP sensor it needs compression to send correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in head. If still not getting spark the usual suspects are:
1. Fouled spark plugs.
2. Battery voltage below 8.7 volts, loose or broken battery cables, check the "NEGATIVE" cable at both ends.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, MAP or BAS sensor.
7. Faulty ignition switch.
8. Security alarm failing to disarm.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
Motorcycle Workshop Manuals
Jul 13, 2015 | 2011 AJS DD50E2
Why no indicator lights working on my ajs eagle raptor motorcycle
Hi Anonymous, I am sorry you can't find the first and best tool you ever bought for your AJS but despair not for a mere $00.00 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
AJS CSR NKT1 125 2009 Sport Twin 5 Speed Repair Manual
Jul 28, 2014 | 2009 AJS CSR NKT1 125
AJSdd50e stopped going. No spark at plug, I have changed the cdi, fault persists, could it be fault with stator generator or possible kill switch fault.
Hi Terry, if you have a CKP sensor it needs compression to send correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in head. If still not getting spark the usual suspects are:
Sep 17, 2013 | 2010 AJS Regal Raptor DD50 E2
Immobiliser/alarm not letting the car start
With an after market alarm it all comes down to how well it was fitted. They are not all going to be fitted in the same place for a particular model, you are not going to be able to just unplug it, dealers don't tend to be a lot of good when it comes to this sort of thing, they all come to us. Take it to an auto electrician, it's not difficult if you know what you're doing. If you don't know what you're doing you could be making the likes of me even more money.
Mar 29, 2017 | Volkswagen Golf / Gti
Have 125 raptor ajs, will not start when cold
Hi Tugay, and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of over use of enrichner.
5. Vacuum hose to fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, loose, corroded or broken battery terminal connections especially the "NEGATIVE" cable inside the harness at both ends.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to faulty ignition coil, ignition module or sensors (MAP, CMP CKP and/or BAS).
11. Sticky or damaged valve or pushrod wrong length.
12. Primary cam sprocket spline sheared or missing spacer.
13. Security alarm needs a reset.
Jan 16, 2012 | 2010 AJS Regal Raptor DD50 E2
Tape format playback for AJ-D250
menu item 107 can be used to select dv playback
Dec 08, 2008 | Panasonic AJ-D230H DV/Mini DV VCR
79 people viewed this question
Top Magnavox Audio Players & Recorders Experts
Jay Plesset
Are you a Magnavox Audio Player and Recorder Expert? Answer questions, earn points and help others
