Question about SanDisk Sansa e250 MP3 Player
Sansa e250 doesn't work
It says I need to clear six mb and I have no music on it
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
SOURCE:
Says" not enoughh space for music db please free 8 mb" wont let me put music on or delete
Try removing the microSD card then delete something from the e250's internal memory to free up 8MB.
Feb 07, 2010 | SanDisk Sansa e250 MP3 Player
I can hear music on my sansa e250 but i cant see the screen?
make sure you have headphones plugged in. Once your in the screen for music or radio turn the clear dial (that looks like a border but isn't) clockwise to turn the volume up.
Apr 10, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
It doesn´t recognized the music files
is the music files in the music folder? (its a hidden folder stupidly enough so is hidden files turned on in your operating system?)
are they mp3 or wav files? If the answers are no - now you know why.
Jan 28, 2009 | SanDisk Sansa e250 MP3 Player
Sansa Problem
you need to take pictures and viedos off of the mp3
Jun 03, 2008 | SanDisk Sansa e250 MP3 Player
Deleting songs
got to the main menu, select settings, select format, if not then use the remover on the sandisk website
Feb 24, 2008 | SanDisk Sansa e250 MP3 Player
No music
clear 6 mb, it needs at least 6 megabytes on the thing to create the list of playable music on it.
Jan 31, 2008 | SanDisk Sansa e250 MP3 Player
Music DB??? clear 6 MB???
Have you tried re-formatting the device?  This will "wipe" memory, getting rid of corrupted files, etc. and should restore use.
Oct 24, 2007 | SanDisk Sansa e250 MP3 Player
How do i clear
Some of that space is reserved for the firmware of the unit(the software that runs your mp3 player, controls all the menu's)
Sep 22, 2007 | SanDisk Sansa e250 MP3 Player
My music folder is gone
To reset the player hold in the power button for at least 20 seconds, when you release the button the player should restart on it's own. If it does not then try again holding the power button for a little longer. If for some reason the player becomes unstable and resetting doesn?t resolve the issue, then try the Sansa Connect Recovery Tool which will clean up your player and restore it to factory settings. You can download this tool & get instructions on it's use on the following link: http://www.sandisk.com/Retail/Default.aspx?CatID=1532 Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 15, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
16 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
