Question about Garden
210 John Deere Garden Tractor PTO
Original Problem:
The PTO Lever on my 210 John Deere Garden Tractor has a 1 3/4 Inch free play when it is engaged. The play causes the mower blades to bog down and slip unless you bring the PTO lever back to the position where there is tension on it. Once the tension is on the PTO lever, it works fine. What should I do to eliminate the free play on the PTO lever.
What I did to try and correct the problem:
I did adjust the PTO linkage and the clutch but am still experiencing a problem and now still need to create tension on the PTO to make it work properly. Something else is still causing a problem so I still need to find out what that may be. Now to make it work properly, I have to bring the PTO lever slightly before the full-engaged position.
4 Suggested Answers
  • 69 Answers
SOURCE: THE PTO LEVER ON A 210 JOHN DEERE GARDEN TRACTOR
I believe there is an adjustment for this. Check
www.weekendfreedommachines.com for specific info. Look in the Restoration and Repair Forum.
Posted on May 06, 2009
mowerman1857
  • 389 Answers
SOURCE: pto spis all the time on my 1989 john deere 420
Are the blades turning? If they are not, this is normal. The PTO is an electro magnetic clutch that engages when you apply electricity via the PTO switch. When it is disengaged, the bearings and top portion of the clutch will turn because it is coupled to the engine. If the blades ARE turning then you have a bad clutch and will need to repair or replace it
Posted on Sep 18, 2009
mowerman1857
  • 389 Answers
SOURCE: is the pto of a john deere 420 garden tractor run
Why wont my john deere d140 move when I ngage the double foot pedal
The drive belt may be broken, or it may have slipped off a pulley.
Aug 03, 2014 | John Deere Garden
Where is the lever to engage pto on john deere 2140, year 1982
This is the link to all the John Deer manuals for the 2140 tractor (and accessories). Unfortunately, when I posted this, the John Deere page was unavailable. If I still can't get it later, I will try somewhere else. Regards, Brian
Jun 19, 2013 | Garden
PTO Issues
replace the pto solenoid as it has an internal short causing the fuses to blow.
Jun 02, 2013 | John Deere Garden
1983 john deere 420 garden tractor thats stalling out when barely moving the hydrostactic lever or trying to engage the front or rear PTO
There are 2 safety switches on that unit as well. Most of them are right below the steering column in the firewall area. Search that to see if that unit has them. I'd be willing to bet one of them is faulty. Most are just a push button type.
Oct 18, 2017 | John Deere 420,1020,2010,2020,2510,2520...
Hello, We have a John Deere 2140 Tractor with front end loader attachment. How do we engage the PTO, or where is lever. Thanks
You should have a round knob on your dash or console you pull it up turn it to the left or turn it to the left and slowly pull it up.
Terry
Feb 12, 2011 | John Deere 420,1020,2010,2020,2510,2520...
Engine cutting off after engaging the pto (mower deck) JD 317
its likely to be a switch playing you up try hard wireing the switch to see if it stops this cutting out first, do one switch at a time till you fine the one playing up
May 02, 2010 | John Deere 420,1020,2010,2020,2510,2520...
PTO CONTROLS. How do you engage and disengage PTO.
The tractor is not a 6300 is it.If it' not you need to adjust the cable for the p.t.o. until it will stay down.Don't turn the turnbuckle too much at a time because there is a fine line between the won't engage and the won,t disengage adjustment.
Sep 06, 2009 | John Deere 6300,6300l,6400,6400l Tractor...
John deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Mar 11, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
230 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
