Question about Car Audio & Video
Tuning an audiobank nab2950.2 amp
It has a base controller and a 1300w 15in sony explode sub
SOURCE: amp shuts off when music turned up
i have a 1.5 farad cap hooled up to mine and it does the same thing. I have it hooked up to 1 3000 watt pioneer spl 12.
Posted on Jun 03, 2007
SOURCE: Overcurrent protector
i keep blowing fuses in the amp all three . and it work fine for 2months then all of a sudden it stoped work so i got new fuses and it did it again what do u think?
Posted on Sep 17, 2008
  • 4 Answers
SOURCE: Amp Turns on Fine, but no Sound
have you checked the levels on the ohms? adjust them higher if need be contact me on yahoo msgr if you need more assistance
jcbproducts-always forward
ym-jcbproducts
Posted on Dec 03, 2008
  • 4 Answers
SOURCE: 3 amps 2 subs sound system for car, need wiring help
it is easy to hook it up!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Jan 14, 2009
etirbynnor
  • 655 Answers
SOURCE: is amp big enough for speakers
To run 2 subs, the amp would be a little small. The subs will run OK, they just won't be very loud.
It's usually better to compare and match up the RMS power rather than the peak power. The Sony XS-L10P5B sub has a peak power handling figure of 1200 watts, but the RMS is 300 watts. The Sony XM-ZZR3301 monoblock amp puts out 1100 watts peak, but only 330 watts RMS. They would work great together, 1 sub, 1 amp. But if you add another sub, each one would only be getting about 165 watts. They'd work OK, just not as loud as they could be.
Hope this helps!
Posted on Mar 29, 2009
3 subs in 2 box 1 1200 watt Sony explode amp
Most sony amps run at 4 ohms mono. There is no way possible to get your subs even close to that. you need to either remove a sub from the equation or get a 1ohm stable amp.
Oct 20, 2014 | Car Audio & Video
Can i use 2 12inch 1400 pyle red label with1600 watt mean machine
yes u c an i have a 1000W sony amp and a 1300W pioneer sub works perfectly fine
Mar 07, 2012 | Car Audio & Video
What amp do i need for Sony Double XS-L124P5B 1300w each?
Most professional car audio installers and manufactures say that to get the best sound out of your subs, you should run half of the RMS wattage listed on the speakers, which in your case would be 1300w for both which is kinda up there, but you can find a 1200w amp and even a 1000w amp would work great, just make sure that the amp has true wattage listed because they have a habit of over rating them until you read on it later. Another way of going about it would be 2 amps, 1 for each speaker, which would be smaller amps, but you would have to make sure both are getting the same amount. Hope this helps.
Mar 03, 2010 | Sony Xplod (P589) Car Subwoofer
Is amp big enough for speakers
Hope this helps!
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Sony XM-1252GTR Amplifier
Can it power the subs? Yes.
Can it make them crank? Well, that all depends on your expectations. That amp/sub combo is going to give each sub about 125W, which isn't much. But if it's what you have, it's better than nothing. You might also consider using only one sub and bridging the amp. This would put about 340W on the one sub, which is much more reasonable.
Mar 13, 2008 | Sony XM-1252GTR Car Audio Amplifier
Amp and sub connection
Too many problems, lol. One at a time. I lost you in your post, run by me again but one amp at a time.
Jan 08, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Sub power hadling capacity
Yes. If the rated power is 380W and the Max power is 1000W then it will handle it. Subs fry when clipping occurs. Clipping is when the amplifier is pushed past its capabilities and the output to the sub gets "dirty". The better quality the amp, the safer it will be on your speakers. It is also important to remember that the gain control on the amplifier is NOT a volume control to boot the sound, it is only to match the output from the headunit to the input handling of the amp. Cranking the gain up too much WILL CAUSE CLIPPING.
Jan 04, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Amp shuts off when music turned up
try adding a capacitor to feed the amp. these are large in capacity (farads)and dims (about 6' x3' dia.)...what wire size are you using?
May 30, 2007 | Sony XM-2002GTR Car Audio Amplifier
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
