Cannot forward my port
Recently i took a new broadband connection when click ''test if my port is forwarded'' in utorrent the web page is displaying the message'''' Port 26963 can not be checked. Your browser is setup to connect through a proxy.''''   And when i try to forward my port using port forward its askin me to create account which i cannot afford to pay.  So guys is there any solution for my prob cant i use another tool for forwarding my port in utorrent . I cotacted my isp provider to forward the port ,he's saying that he's new to internet and doesnt know about it                                The company name of the router is intex  so  i need some help
  • 854 Answers
Port Forwarding
A. Determining the IP Address and MAC Address of a Computer:
Note: Please use the computer for which the Ports are to be opened:
For Windows 2000/XP users:
1. Please click on Start and select Run.
2. Type in cmd and click on OK.
3. In the Command Prompt, please type ipconfig/all then press Enter or Return key.
4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router).
5. Please note down the IP address and Physical address.
B. Reserving an IP Address:
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. When the setup page opens, click on LAN IP Setup under Advanced tab.
5. Click on Add under Address Reservation.
6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table.
7. If the computer you want is not on the list, please click on the Refresh button to update the table.
8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add.
9. Click the Add button when done.
C. Opening Pre-Defined Ports for Internet Services:
1. Click on the option with the name Port Forwarding/Port Triggering under the Advanced menu.
2. Please select the service type Port Forwarding. The router pre-defined services are listed there.
3. From the Service Name pull down list, select the service that needs to be hosted.
4. Enter the IP address of the computer in the Server IP Address box.
5. Click the Add or Apply button.
6. Repeat all steps to open more ports.
Note: If the name of the Internet service does not appear in the drop down list, you may manually open the ports for that Internet service. Please follow the steps below:
D. Opening Ports for Games, Applications or Custom Ports:
1. Click on Add Custom Service button.
2. Type the service name in the Service Name box and the lower range numbers in the Starting Port box.
3. If the application uses only a single port; type in the same port number in the Ending Port box.
4. If the application uses a range of ports; type in the higher range numbers in the Ending Port box.
5. Type the IP address of the computer in the Server IP Address box. Click Apply button.
6. It will then refresh to the Port Forwarding page, and will show the list of all ports opened in tabulation.
7. Repeat all steps to add more ports for more services.
E. To Edit or Delete a Service Entry:
1. Click on the Radio Button that needs to be Edited /Deleted, under the Port Forwarding page.
2. Modify the information from the Service Name, Starting Port, Ending Port, and the Server IP Address, and then click the Apply button.
Posted on May 28, 2009
Hi, I'm having problems port forwarding my Thompson TG585 v8. Im trying to port forward for utorrent application but it does not seem to work, everytime i get an error saying "port is not...
- Please check if it's UDP or TCP. You might have selected TCP for port forwarding but Torrent also uses UDP. For some ports that's important to make both forwarding. One for TCP, the other for UDP.
- If this doesn't work, you need to go deeper. You need to have access to an external computer on internet (a friend) from which you can start a telnet. For instance :
telnet mypublicip 45682
On your side, you need to check what's coming on your network interface. Two options to achieve this :
- Either you book a linux live cd (kubuntu), and you run in a console :
sudo tcpdump -ni eth0
(eth0 is the first ethernet adapter of your workstation).
- Either you use wireshark on Windows, this should do the trick, but you cannot be sure that there is no other software blocking on your current installation.
Regards,
Jul 10, 2011 | Computers & Internet
Tip
How to Forward NAT for the gaming device ?
  • Connect the DSL Modem to Router in the port named Modem (usually yellow in color) using an Ethernet cable.
  • Connect the Computer to the Router in one of the 4 ports named wired (usually grey in color) using another Ethernet cable.
  • Open internet explorer / Firefox or any of your default web browser.
  • In the address bar type the default gateway address of Belkin router 192.168.2.1
  • Belkin router setup page (RSP) will be displayed.
  • Login to the page. (password: leave it blank and click submit)
  • On the left side of the page click firewall and disable it and apply changes.
  • Open DMZ on left, enable it and type the ip address of the device for which NAT ports has to be forwarded.
  • Select wan ping blocking and “ uncheck ” it and apply changes.
  • Select virtual servers and forward the ports for the device ip address.
on Jul 23, 2010 | Computers & Internet
Need find out how portforward can you tell me how udp and tcp ports open
Here is the solution to help you out to do the port forwarding as you wished sir..
2wire-gateway-1921681254-300x234.png Once you have accessed your default gateway screen for your router, you will then want to click on the firewall tab at the top of the screen. After the firewall summary screen opens, you will then click on the firewall settings tabs to begin setting up an open port on your 2wire dsl router.
2wire-firewall-300x234.png Once the firewall setting screen opens you can then add an open port to your specific pc. Under step 2 you will see a list of predefined applications that have already been created for certain video games, servers and telephony (VoIP) services. Since in my example we are opening a port for Utorrent, we are going to manually configure port forwarding for one of my pc's. To be opening a port for Utorrent, click on "add new user-defined application" you can find the link just below the list on the left side of the screen.
2wire-edit-firewall-settings-300x234.png Once you click on add new user-defined application, you should have a window that resembles the one below. Within this window you should now be able to enter a name for the application that you are opening a port for. Underneath the application name, you know have the choice of either tcp or udp, and then you would enter a port number or a port range that you want to open up.
2wire-add-user-definition-300x234.png For security reasons, you should only open one port, unless the application specifies otherwise. The more ports that you have open on you router, the more doorways you open for hackers and viruses to enter your home network. Since we are opening a port for Utorrent, you are going to want to click on the tcp box and then enter the port number that Utorrent gives you, in my example I am opening up port number 51225. After you have entered you port number, click the add definition button. Once you have added the definition, you are going to then click on the back button.
2wire-utorrent-open-tcp-port-300x234.png After you have clicked the back button, you should now be at the edit firewall settings screen. All you have to do now is select your computer from the list that is listed After you have selected the computer that Utorrent will be hosted on, all you have to do is find the recently created user defined definition from the list under number 2. After you have located the Utorrent port forwarding application simply click on the add button, which should assign the Utorrent port forwarding application to your computer. After you have completed the above steps, you should be all set; now your Utorrent program should download and upload at a faster speed.
I have used Uttorent as an Example for you to have an idea how to do the work.. if you still have any problems or question just send a message i will get to you as soon as possible..
If you like the answer and it helped you please like the answer, it will be a great help.. Thanks
Jun 01, 2011 | 2wire (2701HG-B) Wireless Router
How do I get two xbox 360s to have an open NAT on a Cisco Linksys WRT160N V2 wireless router?
you need to setup both your xboxes with a static IP address for example
192.168.1.50 xbox 1 192.168.1.51 xbox 2
on your linksys router you will need to setup port forwards for both xboxes
Click the Applications & Gaming link near the top of the page.
You should now see a new menu. In this new menu, click Port Range Forward.
requires you to forward the following ports: 53,80,88,1863,3074
Mar 30, 2011 | Cisco Linksys E1000 WirelessN Broadband...
How do i clear my port for forward settings? Recently I set up port forwarding for my xbox. However, thru researching im reading that enabling dhcp and dmz is all i need for a the bext xbox live experience
Access the router's built-in web-interface, and access the router's web-page where you "enabled" the port-forwarding. Then, "remove" or "delete" the settings.
Then, access the router's web-page that defines which of your computers/XBOX is to be placed into the 'DMZ' ("De-Militarized-Zone"). Put your XBOX, not your desktop, into the 'DMZ', to allow it "full" access to the Internet, i.e., bypassing the protection of the "firewall" that is inside your router.
Apr 07, 2010 | Dell TrueMobile 2300 Wireless Broadband...
Hello,a message appears low on the bar of utorent no incoming connection.what is this?
You need to open or forward the port that utorrent uses. Open the router's admin page and do it under port forwarding
Apr 18, 2009 | Computers & Internet
Can't get my netgear PCI Adapter connected to my 2wire 1800hw broadband
You will need to modify the router configuration rather than the adapter to setup port forwarding. Normally Network Address Translation (NAT) will allow most of your services to connect without issue.
Nov 06, 2008 | 2wire HomePortal® 1800HW Router...
Utorrent
yes that indicates that there are no incoming connections..when u click on the triangle you come to an option that says to check if port is forwarded properly and to configure the connection speeds..
i am a regular u torrent user and my port is never forwarded correctly..despite the orange triangle i get very good download speeds..a trick i use is to use the"force start" option on the downloads..right click on a downloading torrent and use force start option..i also noticed that over time the triangle becomes green..hope it helps!
Oct 31, 2008 | Enterasys Distributed Forwarding Engine...
Port forwading
http://portforward.com/
this site may be of some assistance
Jun 19, 2008 | Computers & Internet
Utorrent downloads with WRT54GL?
Before we can forward ports for Utorrent, we need to figure out what ports Utorrent is using. Here is a brief walkthrough on how to do that. Go ahead and open up Utorrent.
Click Options in the menu at the top of your screen. In the list that drops down click Preferences.
Click Connections on the left hand side of the Utorrent program. You should now see the menu shown in the screenshot above. Make sure the Enable UPnP box is unchecked. The number in the Port Used for Incoming Connections box contains the port you need to forward. You can change the port number, if you want to. Please enter the port you chose into the box below.
Utorrent's Port for incoming connections To setup port forwarding on this router your computer needs to have a static ip address. Take a look at our Static IP Address guide to setup a static ip address. When you are finished setting up a static ip address, please come back to this page and enter the ip address you setup in the Static IP Address box below.
Do not skip this step! Please enter the static ip you want to forward to: 192.168.1.
Open a web browser like internet explorer or Netscape. Enter the ip address of your router in the address bar of your browser. In the picture above the address bar has http://www.google.com in it. Just replace all of that with the ip address of your router. By default the ip address should be set to 192.168.1.1.
You should see a box prompting you for your username and password. Enter your username and password now. By default the username is blank, and the password is admin. Click the Ok button to log in to your router.
Click the Security link near the top of the page.
Remove the checkmark from the Block Anonymous Internet Requests checkbox.
Click the Save Settings button near the bottom of the page.
Port Range Application Start End Protocol IP Address Enable To Both 192.168.1. We will list a series of lines here that will show you exactly how to forward the ports you need to forward. Utorrent requires you to forward the ports you entered above. Go ahead and enter the settings shown above into the Port Range Forward menu.
When you're finished, click Save Settings near the bottom of the screen to save your changes.
And that's it! You're done!
Feb 21, 2008 | Linksys Wireless-G WRT54GL Router
Computers & Internet Logo
706 people viewed this question
David Payne
David Payne
