Denon AVR-2113CI Receiver NO SOUND
I reset the microprocessor and don't have any soun no sound from speakers no sound from headphones try different settings combinations and still no sound.Everything is visually working expect the sound.All wiring is corect Thank you for Help Libor
  • 35 Answers
Re-install sound drivers
Posted on Dec 28, 2013
  • 47 Answers
SOURCE: built in speakers don't work.i have sound only when i plugg the headphones
Looks like there is some problem with the stereo headphone connector. As its a hardware issue, I would recommend sending it to the service center.
You may also use external speakers temporarily.
Posted on Apr 15, 2008
SOURCE: HP Compaq 6720s Sound problems!!!!
pls. check the internal speaker audio cable is ok or not. and also check the audio cable is connected on the audio section of motherboard.
Posted on Feb 16, 2009
  • 3940 Answers
SOURCE: sound is working but internal speaker is not working
Connecting headphones to the system will disabled the internal speakers until the headphone jack is disconnected, at which such time the internal speakers should function again.
If you disconnect the headphones and the internal speakers are not re-activated, then there may be damaged to the microswitch in the jack. (Try rebooting after the headphones are disconnected too)
Posted on Mar 02, 2009
jovianstone
  • 7 Answers
SOURCE: headphone jack does not work, audio still plays from speakers
sound like the hardware supporting your headphones may have disconnected from its solder.This could have happened from dropping the notebook with the headphones plugged in and landing badly, or a strong or constant tug on the input. Otherwise, it could be a software configuration like you've tried
Posted on Jun 08, 2009
SOURCE: sound does not come out of speakers but does with headphones
I have an acer aspire 4720Z laptop and the sound does not work from the speakers. It works with headphones. The sound card says it is working, and the speakers are not on mute..
Posted on Jul 27, 2009
Denon avr-1612 keeps shutting off and on
You have an output problem, check outputs for short
Apr 07, 2014 | Denon AVR-1612 5.1 Channels Receiver
Denon AVR-487 SYS-57HT SPEAKER SYSTEM
check that wire and fuse again and try to reset and try
Dec 11, 2007 | Denon AVR-4800 Receiver
Denon receiver problems
Check sound from headphones. These models have been known to have bad headphone jacks that make the unit think there are headphones plugged in even when there isn't. Sometimes just plugging in headphones and unplugging them will fix it for a while.
Apr 26, 2013 | Denon AVR-689 7.1 Channel Home Theater AV...
Denon Receiver keeps switching between H/P input and speakers
The problem may be dust in the headphone jack
http://blog.adamnash.com/2010/10/01/solution-denon-av-receiver-avr-1410790-with-no-sound/
Jun 17, 2012 | Denon AVR-1709 Receiver
My denon 3808ci reciver has sound out put when you connect head phones but nothing coming out of the speakers when the head phones are disconnected?
hi,
In all receivers when you connect the headphone it will swich off the speakers. Its normal. When you use the headphone there is no need for external speakers its the principle behind this. .
ok
Sep 09, 2011 | Denon AVR 3808Ci Receiver
My Denon AVR589 just started crackling like rice krispies, I've tried resetting the microprocessor, but no luck it still crackles. Is my unit fried?!
Is the sound from the unit itself (airborne) or is it through speakers only?
If the former, turn it off and take it to a tech to figure out what's sizzling in there.
If the latter, is it specific sources and/or specific speakers?
Mar 15, 2011 | Denon AVR-1508 Receiver
My Denon AVR-1709 was professionally installed. It lasted less than 2 years, then the speakers started popping, then a few days later there is no signal to any of the 5 speakers or subwoofer. same for all...
This is a case where the audio output ic's have failed, you describe a popping sound which is a classic sign of total audio collapse. Since this was a professional installation, I recommend a top of the line audio technician with an estimate in mind.
Jan 07, 2011 | Denon AVR-1709 Receiver
How do I reset my Denon avr-589? I would like to reset my reciever back to original settings.
Press the power button, and speaker a and speaker b simultaneously and hold until the display begins to flash then release speaker A and speaker B buttons. That resets the microprocessor.
Jan 02, 2010 | Denon AVR-1508 Receiver
Headphones only have left channel on Denon AVR-588 Receiver
Hi peroty,
Two suggestions for you.
1. If you look at the headphone jack connecton do you see one or two black O-rings or black lines on the jack. If you only see one they are Mono headphones and you would only get sound out of the left side. If there are two black lines they are stereo headphones and you should get sound on both the left & right sides.
2. If after checking the headphone jack connection and there are two black lines on it then I would suggest try a different pair of headphones to see if a different set of headphones works fine.
If a different pair of headphones works properly the original headphones may be bad. If neither set of headphones work properly it may be the reciever that may need to be repaired.
I hope it's not the receiver, but let me know if you have questions.
Matt @ OneCall
www.onecall.com
twitter.com/onecalldotcom
Nov 25, 2008 | Denon AVR588 Receiver
Computers & Internet Logo
90 people viewed this question
David Payne
David Payne
