Question about Stanton T55 USB Turntable
I own a Stanton T55 and I seem to have a problem making both speakers work with it. It is attached to an amp (Sansui A-910) and speakers (two Boston Acoustics A25). Yet when I listen to my vynils, only one speaker works. Sometimes, however, both will work, then it will revert back. I have been through another amp, other speakers and just recently aquired new RCA cables, none of which made a difference. The problem must therefore be with the table. I have no idea what to do!
  • Stanton Master
  • 5,397 Answers
Remove the wires to the cartridge (make a note of where they fit first). With your amp on, touch each wire (one at a time) with your finger. On one wire you should hear a buzz in the right channel, on another wire a buzz in the left. The two others should make hardly sound at all, or nothing. This test will prove the signal is getting to the amp. While testing make sure you move any RCA leads or plugs, to be certain they don't cut out.
If this checks out then replace the cartridge.
If it does not then you have a problem either with the connectors or and internal amp inside the turntable itself.
Posted on Dec 30, 2013
4 Suggested Answers
dburns60
  • 410 Answers
SOURCE: I thought there was a problem with the speakers or
The "needle", now called a "stylus", doesn't produce anything on its own. At the worst, the tip will shear off and it will slide across and damage the vinyl. So probably your "cartridge" is defective. Now, most low rumbling distortion would come from your turntables motor or platter bearings. Also if you unplugged the Phono leads from the preamp ports in the back of your amp and the noise goes away then you have learned that the amplifier is not producing the effect. Does this help?
Posted on Jul 03, 2009
  • 8404 Answers
SOURCE: TurnTable left channel no signal
Somewhere in the jack or the plug you have a wire broken. You will just have to look for it. If you have a volt ohm meter, this will aid you in finding the broken conductor. When you find the bad connection, you will probably have to solder it back together.
Posted on Dec 29, 2009
Testimonial: "Very quick response! Helped me get to the next step. Thanks!"
futurework
  • 70 Answers
SOURCE: Half the signal only through left speaker
Try the switch in the other position and see if that fixes the problem. some turntables had a phono level that is different than a standard rca line level input. Also try a different cable if the rca is not hardwired in to the turntable. The cable could be bad. If worse comes to worse upgrade to another amplifier or tuner that has a separate phono input. hope that helps.
Posted on May 09, 2010
Testimonial: "thanks a lot i've tried the switch in both positions but it could easily be the cable which is not hard wired!"
On the connection for my Boston Vr2 Floor Speakers there are 4 connections which are connected vertically with a brass plate which is approx 1/2 " wide. I have lost one and the speaker does not seem
You can use a piece of speaker wire to replace the missing bar. those speakers are designed to be used with the bars in place for normal use. they can be removed if you are bi-amp/bi-wireing them.
Jan 14, 2013 | Boston Acoustics Audio Players & Recorders
We found a pair of Boston (computer?) speakers in the trash, but the cords attached to them are confusing...on the main speaker the 2 cords have 1 end that fits into my headphone port on my laptop (like...
I have a similar set of speakers at home from the same company. For the pair i have, they are attached to an amplifier which provides the power to these speakers. without the amplifier, these speakers will not work. Now you can take the speakers to radioshack or a similar company and see if there is an specific type of amplifier that you can buy to work with these speakers, but im not sure if the speakers work at all!
hope this helps! Thumbs up if it did :)
May 03, 2011 | Boston Acoustics MicroMedia Computer...
Boston Acoustics BA745 2.1 Analog Speaker System. The left speaker drops out after system warms up.The D-shaped plug clicks twice when plugging the cable into the Out to PC outlet on the subwoofer (labeled...
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer hope this helps
Apr 11, 2011 | Boston Acoustics BA745 Computer Speakers
I purchased the Stanton T55 USB Turntable today,I put it together and I was told it would play with just the USB connection to my PC. Needless to say,I cannot get any sound from the turntable. Not...
You can get a cable to convert the two outputs from the turntable to a 3.5 if that will help. Amazon should have them. Picture below:
or
grubhead_9.jpg Also check your control panel and sound selection (IE SoundMax etc) to make certain the imputs are switched on or not set to low or on the wrong sound settings.
Feb 22, 2011 | Stanton T55 USB Turntable
I just bought the t.55 usb turn table and am having trouble playing it. Do you need an amp?
hi,
yes you need an amplifier with or without phono input.
your turntable has three types of output
1.phono output (can connect to the phono input of an amplifier which has a phono input)
2. line level output [can connect to ( aux,cd,tape,tunner what u prefer) an amplifier which has these inputs]
there is a selection switch for phono or line level output on the back side
3. and usb( to computer)
Jan 06, 2011 | Stanton T55 USB Turntable
I miss some cables of the Digital BA735. Which cables I have to purcahse?
You need a set of RCA cables, Red & White, you will need two sets. The Cables, simply wire color to color. You nay also need, some adapters, if you cannot get RCA to Phono Jack, on one end. To make with PC, Output Socket, you need an 3.5mm Phono, Jack, and on the other end, the RCA, for connection to the Speakers
http://www.ehow.com/how_4793807_wire-boston-acoustic-proseries-amp.html
http://www.ehow.com/how_5412465_connect-boston-acoustics-ba-speakers.html
How to wire the speakers at above two links.
http://forums.overclockers.com.au/showthread.php?t=229490
Drivers above.
Apr 09, 2010 | Boston Acoustics BA735 Computer Speakers
Static sound when red light blinks
It might be a loose connection. Do you obly get the crackling when the red light flickers?
Dec 29, 2008 | Boston Acoustics VR950 Main / Stereo...
STANTON STR8-150 Sound levels
try different rca leads to amp
Jun 01, 2008 | Stanton STR8-150 Turntable
Stanton T55 USB Turntable Logo
104 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Vito Vacirca Jr.
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
