Question about Frigidaire Affinity Red 3.9 Cu. Ft. Front Load Washer & 7.0 Cu. Ft. GA
Washing machine is stuck on pause - Frigidaire Affinity Red 3.9 Cu. Ft. Front Load Washer & 7.0 Cu. Ft. GA
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Washer stuck in pause mode
Check the door switch. I think you have posted twice.
Thanks/Mike
Oct 31, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Front loading washing machine stuck on pause - won't restart
If your Fisher & Paykel Front loading washing machine stuck on pause, give us a call and we'll troubleshoot it over the phone or send a tech to diagnose it in no time. More info here : http://appliancerepair.biz/brands/fisher-paykel-appliance-repair/
Oct 17, 2014 | Fisher Paykel Fisher & Paykel Traditional...
How to replace a start/pause button switch
When you find out let me know . My misses is stuck on on and on and on. Never pauses for **** all. Lol .
Aug 10, 2014 | Haier Washing Machines
I paused the cycle after about 3 minutes of starting the machine to add an item. There is water in the machine and I cannot restart and I cannot cancel the cycle. What should I do?
first of all you don't have to paused the machine as it is on spin it get stucked with the clothes and gets difficult to run again when restarted.you can put more water if it stucked .but next time you must collect each and every clothes you want to wash so that your machine do not get shocked.
Jan 27, 2011 | Kenmore Elite 45986 Front Load Washer
My neptune washer is stuck in pause mode I can't set it any any wash mode to wash a load the start/pause light just keeps blinking. Is there any way to reset it or boot it to get it started again thanks...
Karen,
Power it down by pulling the 120VAC power cord to the washer then plug back in and see if it will progress with the wash cycle. Which machine do you own the FAV6800A LED console display or the FAB9800A LCD console.
If still no good I will have you try to get into Service Mode but let’s see if a power cycle will clear the issue…….Rich
You will need the Service Manual for reference. Sears Parts Direct for reference.
May 21, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Machine stuck on pause/err
un plug the washer for 5 minutes and re try
May 28, 2008 | Frigidaire ATF6000ES Front Load Washer
Pause mode stuck
Is the door firmly closed? Open the door and close it firmly. If the pause button is really stuck, you will need to repair/replace the board.
Oct 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire Affinity Red 3.9 Cu. Ft. Front Load Washer & 7.0 Cu. Ft. GA Logo
13 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
