Question about Directed 1100d Car Audio Amplifier
Directed 1100d 2-channel amp
How exactly would i run (3) 10"mtx thunder 6000 single voice coil subs to a directed 1100d 2-channel amp?
Well the 1100d directed amp is a mono block.... but yes tou would run them in series which is pos 2 neg on each speaker if there 4 ohm and if there 8ohm run it parrel pos 2 pos neg 2 neg....
Posted on Dec 17, 2008
  • 65 Answers
You will bridge the amp, and if the subs are all 8 ohm subs, you can probably wire them all in parallel, if they are all 4 ohm subs, you would wire then in series.
Posted on Oct 18, 2007
I need to know how to bridge the mtx speaker 4500
I assume you mean wiring a dual 4 ohm voice coil sub to a 2 ohm load, right?
Follow closely
Go from positive of the source (amp or positive post in box) to the positive of both voice coils.
Then go fromt he positive of the source (amp or positive post in box) to the negative of both voice coils.
You will be running two length of speaker wire for this. It's the easy way and makes sure that each voice coil gets clean power.
This is called a parallel set up and will bring two 4 ohm voice coils to a 2 ohm load.
Happy Wiring
Aug 14, 2011 | MTX Thunder 4500 T4510-04 Car Subwoofer
I need help hooking my kicker cvr 12 to my direct 600 amp
Is the sub a single voice coil or dual???? If its a single, just bridge sub to amp....(+ of one channel and the - of the other) amp should show where to bridge with a diagram near speaker outs. If its a dual voice coil, then run one voice coil to the left channel and one voice coil to the right.
Nov 02, 2010 | Directed 600D Car Audio Amplifier
What is Positive and what is Negative
Hi Mason.
Are the positions colour coded in any way?
Red = Positive
Black = Negative
I've looked at some photo's from the website and at a guess I would say that yours are the push on crimp types, so no colour markings.
Have a look at the pdf wiring diagram they supply here as it may shed some light on things:
MTX Thunder US-XT12-44
I've looked over loads of forums but none seem to mention the wiring of these subs.
Understandably you want to get this right as they are a very nice set of subs when they're up and running.
If all else fails try looking at the MTX contact list and ringing one of their supported dealers for more info.
Regards
Mike
Mar 21, 2010 | MTX Thunder 6000 T61044A Car Subwoofer
How do i wire up my mtx 15 5500 sub woofer dual voice coil any one know i have tried several ways
there are several ways, it all depends on the bass response you want, and with that, it also changes the ohms in the amp. i'm going to give you seval ways to hook them up. if you are running more than one just follow these steps per sub. the first one is if your sub is dual 2 ohm. Wiring Option #2
1_2ohmdvc_1ohm.gif Wiring Option #2
this is for dual 4 ohm coils
1_4ohmdvc_2ohm.gif Wiring Option #2
Mar 06, 2010 | MTX Thunder 5500 T5510-04 Car Subwoofer
2 MTX Thunder Problem.. Bridging?
Is there a option on the chanels that say ''Bridged''? If so, you can hook the subs up in parellel or series to get different ohm loads. Usually the lower ohms, the more power amp puts out. Those subs can handle 225 watts RMS whitch means the power it can handle constantly. If the amp gives more than 225 watts RMs, you could be at risk of blowing the sub. If you could give me the model # of the amp, I can be of more help.
Feb 11, 2010 | MTX Thunder 4500 T4510-04 Car Subwoofer
How do i wire mtx 9500 subs 2 10'' down to a one ohm
THE T9510-04 SUBS ARE SINGLE COIL SUBS AND YOU CAN VIEW THAT WIRING DIAGRAM AT THE FOLLOWING LINK:
http://www.mtx.com/caraudio/products/subwoofers/TechData_T9510-04.pdf
THE T9510-44 SUBS ARE DUAL VOICE-COIL SUBS AND YOU CAN VIEW THAT WIRING DIAGRAM AT THE FOLLOWING LINK:
http://www.mtx.com/caraudio/products/subwoofers/TechData_T9510-44.pdf
SINCE YOU NEED A 1 OHM LOAD, I PRESUME BRIDGED AND ARE USING TWO SUBS, THEN HOPEFULLY YOU HAVE THE DUAL VOICE COIL TYPE, AS THEY ARE DUAL 4 OHM AND YOU WILL HAVE TO CONNECT THE VOICE-COILS IN PARALLEL WHICH WILL MAKE EACH SPEAKER A 2 OHM SPEAKER AND THEN CONNECT THE TWO SPEAKERS THEMSELVES IN PARALLEL AND THIS WILL PROVIDE YOU THE 1 OHM LOAD. IF YOU IN FACT HAVE THE SINGLE 4 OHM VOICE COIL VERSION, THEN IT WILL ONLY PARALLEL THE PAIR DOWN TO 2 OHMS. OK. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Jan 08, 2010 | MTX T9510-44 - 10" 9500 Thunder Series...
WIRING A DUAL VOICE COIL SUB.
Just wire one voice coil each into left and right rear respectively, in series with the original rears or if this is too quiet, wire both voice coils in parallel together and connect as per original single coil unit.
As they are 4ohms each they can simply be connected as simple speakers on each rear channel output, since thats exactly what they are, capacitors are used inside to make them react to bass frequencies only. Wiring them up is no different to wiring up a pair of 6x9's.
Oct 24, 2009 | MTX Thunder 4244 Car Audio Amplifier
When I bridge the BAMF 2200/2 Power Acoustik amp it cuts off
Hello munchisfun,
I'd suspect that the amp is operating into too low of an impedance and going into protection.
The 2200/2 is not rated to drive a 2ohm load when bridged (most 2-channel amps aren't) and when you connect 2 4ohm subs in parallel, the load is 2ohms. I'd run one sub from each channel.
Hope this helps.
Jul 26, 2009 | Power Acoustik BAMF2200/2 Car Amp
Subs
I looked up that amp, it doesn't have a listing for 2ohms x1 but it has 2 ohms x 2 and its at 250watts. For this situation, I would recommend a different amp or different subs. Right now you are getting the most you can get out of your sub/amp combo, if you only have single voice coil subs. Which is common in the mtx preloaded boxes. Either you want an mono block amp stable at 2 ohms or 2 dual 4 ohm voice coil subs. If you got the subs you would wire the voice coils in series so you could get 8 ohms then the subs in parallel so you could get 4 ohms, which would be the best for that particular amp. Good luck.
-Andrew Hawkins
Aug 23, 2008 | Legend LA1490 - American Legacy Series 2 -...
Directed 1100d Car Audio Amplifier Logo
180 people viewed this question
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Libran Moreno
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
