Canon image runner C5185 not connecting to my desk top, not saying find new hardware when i plug in my usb printer cable.
  • Office Equip... Master
  • 8,073 Answers
Even if the computer recognizes that some device is connected you still need instal the software that shipped with it, along with the drivers.
Posted on Dec 28, 2013
Testimonial: "i DID NOT GET ANY SOFTWARE."
4 Suggested Answers
ohms
  • 1879 Answers
SOURCE: USB CABLE
better if you check with the manufacturer if your thermal printer's parallel interface is replaceable by a usb interface. try installing the usb driver for your product (drivers available at the manufacturers website)
Posted on Dec 03, 2008
color_50
  • 22 Answers
SOURCE: ROM Error for Canon Image Runner 2010F
When the ROM Error message is displayed on the control panel, this will indicate an issue with the Flash DIMM on the Image Processor PCB.
re-flash the system software for that specific model. If system software does not resolve the error, replace the DIMM Assembly. When replacing the DIMM, you may be required to flash the system software to it's latest version.
iR 2010F FG6-9454-000, Dimm assembly.
As a temporary work around, power on the iR while holding down the STOP key. This may boot the iR to a ready state and copies can be made.
Posted on Mar 14, 2009
canontech
  • 1219 Answers
SOURCE: copy darkness problem canon image runner 2830
Did you try to clean beneath the copy glass?
On digital machines, when the copy glass or optics are dirty, copy becomes verry light.
How many copies do you have? pres 123 button.
It also could be that you need to change the toner station, by the book it goes 300000 copies.
But I bet on dirty copy glass and dirty scanner assy.Clean the glass with glass cleaner and polish it with dry cloth.
Posted on Jul 25, 2010
Testimonial: "so thanks"
Why does my canon PIXMA 452 say pc not connected when I hit the start scan button
Hi, several things i would be asking
Do you get an error code?
Is the error on the PC or Printer?
Can you print?
How is the Printer connected USB or Wireless
the first is the error code will determine where the fault lies.. if in the 5000 range.. its a hardware problem and would need to be repaired by a service center or repairer.
if you get the printer error.. check the cable or wireless connections
if the PC error it could relate to software you are using to scan too, even if you acquire the correct twain driver (select source).. some are not compatible.. try the scan function in your Canon Utilities IJ Scan Utility. Scan it there first and save it as a PDF or image file.
if you can print its not a connection problem if you cannot print try another USB/printer cable Or make sure your device is setup for wireless run the installation software again and complete the wireless procedures in setup. I hope this helps.. or post me the error code and i can give you a definite answer.. Cheers!
Jun 09, 2014 | Canon Pixma MX452
Test print
If you have already checked to see that the USB cable was plugged-in at BOTH ends.
Try disconnecting the printer from the back of the PC and moving it to an un-used USB port. See if the system detects a new device connected, (it will install drivers automatically if it does.)
If it does not, then the cable may be damaged, get a new USB cable.
Tallon41
Sep 18, 2012 | Canon PIXMA MX310 All-In-One Printer
Connecting my printer to my desk top.
connect the usb cable of printer to the usb port of desktop and then turn the driver application for the printer so ur printer will be install
Aug 23, 2011 | Canon Office Equipment & Supplies
How do I get the Canon image runner 1023if to scan documents? I have followed the instructions provided by Canon (what little there was) loaded the drivers, (as per Canon) and still cannot get past the...
Try using different software for scanning. e.g. Photoshop Select the right scanner, for Canon you usually see WIA. Then import image and select Canon. New window will pop-out and you can start scanning. Be sure to press the SCAN button of the machine before scanning.
Jan 26, 2010 | Canon imageRUNNER 1023iF Black and White...
Blank sheets when Copying on the Canon Image Runner 1310.
Hello sir; I would like you to check the charge corona wire inside the drum cartridge or you just replace a new drum cartridge, before you change also check the discharge corona wire at the bottom inside the machine.
Sep 17, 2009 | Canon imageRUNNER 1310 Copier
Cannot install Canon PIXMA MP190 printer
Thank you for your promptitude.
Today I solved my problem. Was a cable connection problem. Cable incompatibilit or all 3 cables used before are damaged. Tuday I buy an other new cable and SUCCESS!!!: my computer see de printer ("new hardware found" when attach usb cable) , create virtual usb port, install the drivers (I have the drivers downloaded from the Canon web site) and printer is working fine.
Anyway, thank yow again for your support!
Jul 09, 2009 | Canon PIXMA MP160 All-In-One InkJet...
USB DEvice not recognized
Turn off the CPU unplug the power cable and all usb cables, let it sit for about 15-20 minutes. Plug power cable back in, turn on CPU, plug in your usb devices.
Mar 06, 2009 | Canon PowerShot SD790 IS Digital Camera
42 people viewed this question
k24674
jasbo
jasbo
