Question about Rokenbok Toys
Broken plastic gear - Rokenbok Toys
What do I do to fix the gear shift indicator on a automatic transmission?
The gear shift indicator is just a peace of plastic it could be broken or just come lose. I think that car has gear shift on the floor. Normally are screws on the side of the plastic cover on each side. Just remove the screws and lift the cover and you should be able to see if the pointer broken or just needs adjusting. You should not have to try on it. just remember that it is just plastic. good luck Jerry
Apr 11, 2015 | 2009 Pontiac G5
Runs but doesn't turn. Worm gear is not broken.
Something must be broken if the motor is turning and the planetary is not. It will be one of the following, we will start from the first point of contact with the armature
1) Worm gear broken (fuse gear) you say no teeth broken
2) Worm gear not broken but whole unbroken plastic part not gripping aluminium boss
3) Pin through worm gear broken or missing
4) Pin through centre (or bevel) gear broken or missing
5) Pin through small gear in planetary broken or missing
6) Pin through planetary hub centre shaft broken or missing
The most common ones in order of likelihood are, 1, 2, 3 and 6
Dec 29, 2014 | KitchenAid KSM90 Ultra Power Series Stand...
How do I resolve knocking noise from fusing unit of MP C3502 Ricoh?
check movement transmitting gears, they can get broken or loosen ( a spring),otherwise you have to disassemble the entire fusion unit, again a bad gear and /or a broken belt. ( some fusions use fusion belts),if they get broken, they force the gears, make friction and noise.
Sorry, you really have to open the fusion unit.good luck! Ps - Plastics in this zone become very fragile and broke very easy! A broken piece of plastic inside fusion can make that, but this is just a supposition.
Mar 11, 2014 | Office Equipment & Supplies
The plastic "nut" gear that
YOU COULD TRY AMAZON WEB SITE THEY DO SOME PARTS............... BUT TYPE IN THE SERCH BAR BREAD MAKER PARTS
Feb 19, 2011 | Toastmaster 1148X FastBake Bread Maker
A plastic bevel gear has broken and the material
You can get the gears quite easily on ebay, they are standard on all singer machines
Nov 21, 2009 | Singer 5070 Mechanical Sewing Machine
Broken gear on Destroyit 2602 SMC
If this is a Royal shredder call 1-800-524-0799 for parts assistance.
Mar 26, 2009 | Office Equipment & Supplies
Broken Plastic Gear Wheels
Check out this website if you have an outdated machine without a parts program still in place it may come in handy.
http://www.rushgears.com
Feb 20, 2008 | Intimus 385 se Shredder
Plastic drive gear from motor broken
I have a left over set of these plastic gears that I can send to you. The motor bracket on mine snapped. I took it apart to check. It looks unrepairable.
edbwest@aol.com
Oct 31, 2007 | Cross Infoguard Shredder SX102M
Broken plastic small drive gear.
buy a new icecream maker parts are to get for them.good luck.
Dec 24, 2006 | Rival GC9151 1 Quart Ice Cream Maker
Toys Logo
97 people viewed this question
Top Rokenbok Toys Experts
Bill Boyd
Ernest
Ernest
Rahul Prajapati
Rahul Prajapati
Are you a Rokenbok Toy Expert? Answer questions, earn points and help others
