Question about Sonos ZP120 Amplifier
Sonos amp repair
Reapir led
LED display not lit
If you have the knowledge to reapir TV systems, go ahead,
One thing is sure: it won't get reapired by puhing remote control buttones
Aug 31, 2015 | Samsung Audio Players & Recorders
Tip
How to Listen to Audible Audiobooks on Sonos
Due to an incompatible update, the Audible service is removed from the Sonos. In this post, you will learn other alternative ways to play Audible on Sonos through line-in connection or by removing the DRM from
Audible files first.
How to Play Audible AudioBooks on Sonos
on Apr 06, 2017 | Sonos Audio Players & Recorders
Receiver blinking ue22. Cannot find in manual. No sound for cable or sonos or netflix. No sound period
Unfortunately this error code on a Pioneer receiver indicates that the firmware has been corrupted. The only fix for this is to replace the digital board. If out of warranty, it is probably not economical to repair.
Jun 19, 2015 | Sonos Audio Players & Recorders
Reapiar tv plasma samsung ineed manull servis or reapir PL43E4850
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Dec 16, 2014 | Samsung Televison & Video
How do i connect sonos " control " to denon avr 300. Where are audio output on this denon?
The AVR-E300 doesn't have an audio output. It's a very basic AV receiver built down to a price.
Even if you has a better quality receiver, you still would only be able to port sound from analogue sources (ones connected via red & white RCA/phono) to the Sonos Connect for distribution around the rest of your home. AV receivers don't decode audio from HDMI sources to analogue stereo.
If you want to port sound, hook up a source direct to the Sonos Connect's audio input. Don't try going via the receiver.
Sep 14, 2014 | Denon Audio Players & Recorders
How do you connect a sonos connect to a wired sound system
Basically it will act like a CD or TAPE input. You can either use RCA or Optical (i believe) and just plug it into an existing input slot. The key is that for Sonos you will need to have a Sonos Bridge or an existing Sonos Player.
Jun 28, 2012 | Sonos CONNECT Wireless Music Streaming...
Is there any way to hook up a sonos zp120 to the bose 901's without using an amp
No speakers will run without an amp.
The Active Equalizer must be somehere in the Line Level path between any source and whatever amp is exclusively driving Bose 901's, which makes the ZP120 useless as a networked music delivery system becuase everything IT outputs would be 901-encoded - unless you had 901's in every room.
The Sonos neither knows nor cares what processes are applied to the signal before it arrives through the Line Level inputs but the digital audio/ethernet route lacks anywhere to insert ANY analog processing, so 901's will not work with the ZP120 if the music originates elsewhere.
I'm not so sure how the claimed 55 watts would work out for 901's. I'd take that specification with huge grain of salt as this unit only weighs about 5 lbs.
This link leads to the multi-lingual manual...
http://www.google.com/url?sa=t&source=web&cd=8&sqi=2&ved=0CF4QFjAH&url=http%3A%2F%2Fwww.abt.com%2Fdocuments%2F20166%2FZP120_Setup_Guide.pdf&rct=j&q=sonos%20zp120%20manual&ei=nwV7TpjcLumIsgKfm7WzDQ&usg=AFQjCNEp4MtETHn2IZLqk9fVXn4QPsV9iQ
Sep 21, 2011 | Bose Audio Players & Recorders
Flashing White status light continuously
Can music be played through it? If yes, you need to just go into the zoneplayer settings and uncheck the box regarding the white indicator like.
Dec 16, 2010 | Sonos ZP100 Digital Media Streamer
Sonos won't play when attached
Attach the analog RCA output of the Sonos to the CD input of your receiver. On the receiver select CD is the input. Now turn the volume up on both the Sonos and the Receiver. Dont forget to make sure some music is playing on the Sonos.
Good luck
Dec 18, 2008 | Harman Kardon AVR 300 Receiver
Sonos ZP120 Amplifier Logo
57 people viewed this question
Top Sonos Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sonos Audio Player and Recorder Expert? Answer questions, earn points and help others
