Question about Mitsubishi WD-57733 57" HDTV
How to get error code for WD-57733 - Mitsubishi WD-57733 57" HDTV
How do i fix a code 18 in my mitsubishi tv wd-57733?
Try with the remote the soft reset: Menu, 1,2,3, Enter.
Dec 08, 2012 | Mitsubishi WD-57733 57" HDTV
Hi, I have a Mitsubishi wd-57733 dlp tv that shuts down
Ballast is possible if repeated lamp failure but I have a solution I posted several times for this type of problem that works and is simple to try:
http://www.fixya.com/support/t12296849-turns_off_shortly_after_turn?mt_f=viewFull162
Apr 30, 2012 | Mitsubishi WD-57733 57" HDTV
What is the part number for a new bulb
Mitsubishi WD-57733 lamp part no is 915P061010.
Click this LINK to buy online.
Jdvillanueva
Jun 18, 2011 | Mitsubishi WD-57733 57" HDTV
I have a 57" mitsubishi
You probably have a bad lamp again I hate to say. These lamp are so critical when being moved. If after you atttempt to power on TV then red light shows, press menu+input on the front panel and hold for 5 seconds. Front timer LED will blink a 2 digit error code five times then stop. Code 34 and 66 are lamp errors, and if you read code 66 the lamp is broken. Good luck
Bill W
integrityhomeworx.com
Mar 09, 2011 | Mitsubishi WD-57733 57" HDTV
Blinking green light (timer light). No video, no sound. Error code 12. This model has no DM board so it's not the better known "capacitor" problem.
Error code 12 signals that no failures were detected , which means that it's a power source failure. You will need to check it - the board sits on top of the main board.
Feb 16, 2011 | Mitsubishi WD-57733 57" HDTV
How to remove and install tv lamp for model wd 57733
See page 62 of this manual. Read the section titled "Lamp cartridge replacement". It has detailed info with pictures.
http://www.retrevo.com/support/Mitsubishi-WD-57733-TVs-manual/id/3124bh436/t/2/
Feb 06, 2011 | Mitsubishi WD-57733 57" HDTV
Replaced the lamp in my wd-57733 and now the lamp light is flashing amber
Try to re-seat the lamp, if that doesnt fix it it could be your lamp motor.
Jul 18, 2010 | Mitsubishi WD-57733 57" HDTV
Mitsubishi WD-57733 57" HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
