Question about Arris SURFboard Gateway SBG6580 DOCSIS 3.0 Wireless Cable Modem
Settings change wireless
How can I change the channel number for this router?
    Problem Solver:
  • 13 Answers
I set a password for my router without setting a username. And now I can't connect to my wireless.
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Regards
TOM
Jan 12, 2011 | Belkin (F5D7633UK4A) Wireless Router
How can I change the channel selection on my router....it keeps dropping the internet signal. Is there something else I should try?
In order to change the wireless channel of your Dlink wireless router DIR-615 , please follow these setps
1. Open up the internet explorer in the comp in which you are online and clear the address bar and type in the number 192.168.0.1 and hit enter.
2. You will be logged into the D-Link router setup page .
3. Under the SETUP tab, in the left hand side, click on WIRELESS SETTINGS? you will find Wireless Network Settings under which you can change the wireless channel and click on save settings at the top .
Good Luck!
Thanks in Advance!
With Regards,
Prema.
Jan 03, 2011 | D-Link DIR-615 Wireless Router
How do i change the channels from 1 to 11 on my router thomson tg 585v7
This setting is changed by accessing the router directly. Typically you have to plug network cable into the router directly, access via web browser, and look under wireless settings.
Remember to change system ID to something you would recognize, set access password for the router, and turn on wireless security. LOG ALL passwords.
The channel issue change to 11 is a good idea as many routers compete with wireless home phones for the lower channel numbers, but suffer intermittent failure, not complete malfunction. Good on you for desiring to change to 11 (or so).
Oct 03, 2010 | Computers & Internet
Keep losing signal to wireless, have to disconnect power to router then power back up and its fixed
I think you may need to change the wireless channel number or you need to update the firmware of your belkin wireless router. In order to change the wireless channel number you need to access belkin default page. you can refer this Change Belkin Wireless Channel number and SSID
Aug 09, 2010 | Belkin (F5D8231-4) Wireless Router...
Why is my Netgear router slowing down my internet?
If you upgarde firmware on router and changed the channel number of router then you can resolved issue
open router page with www.routerlogin.net (router default user name is "admin" and password is "password" all in lower case
now you need to click on wireless setting which is under setup
you can changed channel number on that
Hope it can help you
May 13, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
My phones run with 2. Ghz frecuency so when I used my inalambric phones get disconnected from the web, how can I solve this problem I have a router model F5D 7230-4
On all wireless routers there are channel settings. If you phone is on the same channel, you may have problems with the router. Also make sure your base station to your phone is not next to the router. Its radio waves may cause interference. First thing to try is to change the channel number for your wireless router. See the attached link for your router information and how to change the channel.
The link is: http://en-us-support.belkin.com/app/answers/detail/a_id/76/q/routers
Good Luck.
Jan 30, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Cannot connect to internet wireless
Please get to the router configuration console (Router GUI on 192.168.1.1) and click wireless => Try changing the channel number and if reboot the router and test for all 11 channels, incase if there is no diffrence please follow the steps below:
Wireless => Advanced wireless Settings => Change the following:
1) Beacon interval = 50 instead of 100
2) Fragmentation Threshold = 2306 instead of 2346
3) RTS Threshold = 2307 instead of 2347
Nov 18, 2009 | Linksys Wireless-G WRT54G Router
Laptop doesnot recognise my router Desktop works fine connection is from cable modem to router. rouer to desktop.
Try changing channels on the wireless tab in the router. On most routers the default wireless channel number is 6 and you and your neighbor could be sharing tha number. Go to channel that is avaiable, I myself had that trouble myself.
I had channel 11 set and someone got the internet and mine was having trouble so I done a scan and found 3 was open and I have no problem since.
Nov 11, 2009 | D-Link DIR-615 Wireless Router
I just bought a belkin wireless router. it is a wireless G MIMO Router. i have set it up, but the number i have to type in on the address bar, it comes up 'nothing to display' i have no idea what else i...
gunja
Rank:wizard_s.gif Wiz
Rating: 85%, 88 votes hi,
Open the router page 192.168.1.1 >> type this in the internet explorer address bar.
1. the Home Page is displayed. Click Wireless from the left menu
2.The settings to Wireless section of Router appear.Click Channel and SSID.
3.Changing the Wireless Network Name (SSID)
To identify your wireless network, a name called the SSID is used. The SSID is your network name. The default network name of the Router is Belkin N1 Wireless followed by six digits that are unique to your Router. Your network name will look something like Belkin_N1_Wireless_123456.
You can change this to anything you choose, or you can leave it unchanged. Keep in mind, if you decide to change your wireless network name, and there are other wireless networks operating in your area, your network name needs to be different from other wireless networks that may be operating in your area. To change the SSID, type in the SSID that you want to use in the SSID field and click Apply Changes.
The change is immediate. If you make a change to the SSID, your wireless-equipped computers may also need to be reconfigured to connect to your new network name. Refer to the documentation of your wireless network adapter for information on making this change.
4.Changing the Wireless Channel
There are a number of operating channels from which you can choose—in the United States, there are 11 and in the United Kingdom (and most of Europe), there are 13.
In a small number of other countries, there are other channel requirements. Your Router is configured to operate on the proper channels for the country in which you reside. The channel can be changed if needed. If there are other wireless networks operating in your area, your network should be set to operate on a channel that is different than the other wireless networks.
Select channel from Wireless Channel drop-down menu. Click Apply Changes.
5.Using the Wireless Mode Switch
This switch allows you to set the Router’s wireless modes. There are several modes. Note: Some modes may require firmware updates to be enabled.
1) 802.11g only
Setting the Router to this mode will allow only 802.11g-compliant devices to join the network, keeping out any slower 802.11b devices.
2) 802.11g & 802.11b
Setting the Router to this mode will let 802.11g- and 802.11b-compliant devices to join the network.
3) 802.11n & 802.11g
Setting the Router to this mode will allow N1/draft 802.11n- and 802.11g-compliant devices to join the network, keeping out any slower 802.11b devices.
4) 802.11n only
Setting the Router to this mode will allow only N1/draft 802.11n-compliant devices to join the network, keeping out 802.11g and 802.11b devices.
5) Off
This mode will turn OFF the Router’s access point, so no wireless devices can join the network. Turning off the wireless function of your Router is a great way to secure your network when you are away from home for a long period of time, or don’t want to use the wireless feature of the Router at a certain time.
Select wireless mode from Wireless Mode drop-down menu. Click Apply Changes.
6. Using the Broadcast SSID Feature
Note: This advanced feature should be employed by advanced users only. For security, you can choose not to broadcast your network’s SSID. Doing so will keep your network name hidden from computers that are scanning for the presence of wireless networks. To turn off the broadcast of the SSID, remove the check mark from the box next to Broadcast SSID, and then click Apply Changes.
The change is immediate. Each computer now needs to be set to connect to your specific SSID; an SSID of ANY will no longer be accepted. Refer to the documentation of your wireless network adapter for information on making this change
sahil101
Rank:nonexpert_s.gif Apprentice
Rating: 92%, 6 votes open the the console page of the wireless router by typing this ip address on the address bar in the internet explorer.
192.168.1.1
it will open the console page of the router.on the left hand side
u will see an option which says wireless settings.click on
wireless settings.then u need to look for the option which says
wpa security passphrase,just put the passphrase there n
click on apply,ur wireless connx will be secured. Selah :-)
Sep 14, 2008 | Computers & Internet
Router loses connection to Internet
Note : The steps below are applicable only for Belkin routers.
  1. Open an Internet Explorer window on your computer and type in http://192.168.2.1 in the address bar. This will take you to the Belkin router's web based configuration page. If you are not able to open the page click here.
  2. You will get a login page. Leave the password blank. Click Submit .
  3. On the left side of the page, click Channel and SSID below Wireless .
  4. The wireless channel on the Belkin router is set to Auto by defualt. Change the wireless to a static channel. Click Apply Changes .
  5. Click Logout in the top right hand corner.
Note: The wireless card in the computer will automatically detect the change in channel number on the router and will update the channel on the card.
CauseYou are not able to connect wirelessly mainly due to environmental interference. When the wireless channel is set to auto, the router will cycle to though channels when it detects significant interference. When the router changes channel the wireless connection will reset itself and disconnect all wireless clients connected to the router. SummaryWireless signals are prone to interference from cordless phones and electrical appliances (e.g., vacuum cleaners, microwave ovens). This is the reason wireless connections can drop. This article explains how to overcome frequent wireless disconnections by changing the channel number (frequency) on the Belkin router.
Nov 08, 2007 | Belkin (F5D7231-4) Wireless Router
Arris SURFboard Gateway SBG6580 DOCSIS 3.0 Wireless Cable Modem Logo
236 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
jimmy Leo
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
