Question about HP Photosmart 2610 All-In-One InkJet Printer
Black printing morphs into red after black ink cartridge installation
I just changed the black ink cartridge in my HP Photosmart 2610.  When I attempt to print a plain black/white document, the ink color first appears almost black, then morphs into a brick red (like the red and black mixed).  Alignment test came out fine after the ink cartridge installation.
I did get a decent print by choosing "print in grayscale" and "use only black cartridge," but can't get the printer to continue printing this way (default) without specifically changing this setting.  What is my printer doing to me?
A secondary question would be:  Is the printer set to always use the color cartridge for some reason, even though I'm printing black/white documents?
  • nuckle Sep 02, 2008
    my printer is printing red i have changed the black cartridge
    but it still printes red the test came out fine
  • HP Master
  • 691 Answers
Your printer creates it's black by using ALL the colours together. This effectively gives a very dark purple rather than black.
It sounds like you have a colour cart that is drying up or may be struggling to get enough air into the cartridge. Make sure you have removed any tape over the vent holes if you are using compatible inks. If not then try running a couple cleaning cycles via the button panel/driver.
If you alter the settings in the driver by going into START - PRINTERS AND FAXES and then right click on your 2610 and select PROPERTIES - the changes you make in here will be set as the default settings for each print job.
Posted on Oct 17, 2007
What color and black and white cartridges should I use for a HP Photosmart 1115 printer?
It looks like your Photosmart 1115 printer uses an HP45 black ink cartridge and an HP78 tri-color cartridge. Some HP printers will accept re-manufactured ink carts, while other HP printers will not...just so you know. I've always bought genuine HP ink cartridges on eBay to save $$$.
Jun 23, 2014 | HP Photosmart 2610 All-In-One InkJet...
My hp photosmart 5514 won't print. I put in new ink-black and color- and it goes through the motions, but the page is empty
I just had this exact problem on my HP 5514. Black won't print after running out of black ink. New cartridge no good.
I tried everything-no good. I suspected the pinholes in the printhead were clogged with dried ink because I didn't change cartridge in time.
The fix that worked perfectly was when I hacksaw top off old black cartridge & removed all foam wicks so now I had a funnel(can see clear thru). I installed the cartridge & filled it with alcohol, printed page & did head clean; then printed few more pages. Problem cleared almost immediately. I then soaked up extra alcohol inside cartridge with paper towel. Removed modified cartridge & installed good one. I guess this could be done for colors as well. I don't know if this is a proper procedure, but it sure worked well for me.
Oct 05, 2012 | HP Photosmart 5514 e-All-in-One -...
I replaced my black ink cartridge with a refilled from office max and it will not print in black. Why?
Most HP cartridges have what's called an ACCUM chip, which doesn't care about the actual ink level, it counts how many milliliters (or droplets) have gone through the head to determine when it's "empty" and therefore refilling doesn't do anything, the accum still says the cartridge is empty.
Mar 05, 2011 | HP Photosmart 2610 All-In-One InkJet...
You need to clean the nozzles of the ink cartridge by dabbing on a wet paper towel folded many times, after the water you dab on a dry area to see if there's a solid black line. If it's a refilled cartridge it could be just worn out, they're only good for about 2 refills.
Jan 18, 2010 | HP Photosmart 2610 All-In-One InkJet...
Hp 2610 will not print black even with new cartridge. HELP
Try cleaning the gold contacts on cart first, with distilled water. Let dry and try again.
If not, try this one
1.Try placing sheet of black text on copy board, and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK
May 24, 2009 | HP Photosmart 2610 All-In-One InkJet...
Howdo i refill my ink cartridges
Here are two links with refill instructions.
for the black cartridge, and
for the color one.
Hope that helps!
May 03, 2009 | HP Photosmart 2610 All-In-One InkJet...
HP 2610 is saying to change black ink cartridge
Make sure you have removed the tape from the printhead on the cartridge. If you have sone this, then you can try turning the printer off and on a couple of times and see if this helps. You may need to press the OK button
Jan 01, 2009 | HP Photosmart 2610 All-In-One InkJet...
I cannot get my new black print cartridge to align properly. I am using the HP Photosmart 2610 all-in-one device.
I bought a new ink cartridge which will print well. But the alignment still does not work for some reason. The printer screen says to "check the device instructions" whatever that means. i am willing to continue to use the printer as is unless you have a simple solution. Thanks Gerald Lord
Jul 28, 2008 | HP Photosmart 2610 All-In-One InkJet...
HP Photosmart 2610 All-In-One InkJet Printer Logo
309 people viewed this question
Ben Johnson
