Question about GE Profile JGS968 Gas Kitchen Range
Oven won't keep temp.
Our oven will go on and reach desired temp. THEN it turns itself off and after we reset the temp, it still won't go back on. We've replaced the igniter, the gas control valve, and finally the main circuit board. None of these fixes worked. The repair guy is just now removing the new main circuit board so that we can return it for a ($260) refund. He sez that we are out of options, except to replace the whole range with a new one! Do you agree? Thanks for your help!
  • Pat Meacham
    Pat Meacham Dec 27, 2013
    AND we replace the temp sensor. I forgot to add that to my original post.
    Top Expert:
  • GE Master
  • 9,472 Answers
I would try another control board. I have gotten 2 new ones before that were bad right out of the box! It happens all the time.
Posted on Dec 28, 2013
Testimonial: "Thanks for your answer. How do you know when the control board is bad? . . . . Is there a test? Another detail that might be important. . .we converted it to LP when we installed it."
4 Suggested Answers
  • 23 Answers
SOURCE: The oven of GE Profile range simply stopped igniting
If it is a ge it would have a glow bar ignitor, either a flat rectangle shaped or a round ignitor. That is want the problem is 95% of the time. It is pretty easy to do. The floor of the stove will come right out and it probably has two screws in the back corners you can see. Remove them and the floor will lift out and you can see the burner and the ignitor.
Posted on Jun 20, 2009
  • 715 Answers
SOURCE: I have a GE XL True Temp gas range/oven. None of
your stove must be plugged in for the auto-pilot to work .do you hear a ticking noise when you turn on a burner?
Posted on Oct 07, 2009
vijaydangwal
  • 137 Answers
SOURCE: My gas range's oven piezo-electric igniter is not working.
it must be a problem of spark distribution try to remove the spark plug from your piezo electric igniter and clean it throughly it must work otherwise it will have to be replaced
Posted on Feb 25, 2010
Ge profile oven model jgs968 won t stay hot
If it has a thermocouple, replace that. They are cheap and easily available. They wear out after a few years.
Dec 27, 2013 | Kitchen Ranges
Dacor Oven Thermostate problem
The replacement temp sensor could be defective.
Mar 03, 2017 | Dacor Ovens
Oven will not reach desired temperature and slight gas smell
Just had same problem it was nice it waited until christmas dinner, all i did to resolve the problem was switch the upper broiler igniter with the lower one for the oven. I tuned on the oven & it fired right up i never use the broiler on my oven so itll buy me some time. So if you can get the broiler to light try that but i did have the same low temp. & the smell of gas. Good Luck
Jul 29, 2010 | KitchenAid KGRT607 Gas Kitchen Range
I have a GE Hotpoint flat top stove model # RB787WC1WW and the oven will sometimes shut off by itself. Is there a sensor that shuts it down when it reaches desired heat. It will sometimes turn on if you...
That is what the oven elements are suppose to do. When it gets to temp the thermostat cuts the elements off and as it cools they will heat back up. if it cuts off and wont heat back up its probably the thermostat
Mar 08, 2010 | Hotpoint RB787 Electric Kitchen Range
The oven pre heats to desired temp and then loses
SOUNDS LIKE THE TERMOSTAT IS FAULTY REPLACE IT AND YOUR OVEN SHOULD WORK FINE.
Nov 09, 2009 | Thermador SMW272 Electric Double Oven
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
Oven Temp
After it drops temperature, how do you get it back to the desired degrees? It sounds like the thermostat isn't keeping up.
Nov 15, 2007 | Whirlpool RBS245PDS Electric Single Oven
Oven shuts off by itself
When your oven reaches the desired temp. it shuts down then turns back on again after it cools down a couple of degrees and cycles like this during the complete baking cycle. If your ignitor or oven valve is getting weak it would cause this symptom.
Oct 31, 2007 | GE JGRP20 Gas Single Oven
GE Profile JGS968 Gas Kitchen Range Logo
66 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
