Removal of startermotor yamahs DT125R - Computers & Internet
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 113 Answers
Phone Yamaha and speak to there service team they should be able to assist or a Bike shop any Bike shop.
Posted on Jan 05, 2014
I have a 99 9.9hp evanrude with omc controls, it will not key start but will pull start any ideas
The yellow-red striped wire is the start signal to the relay.
First be sure the remote control is in NEUTRAL. There is a security preventing starting in gear!
Take a wire from your battery positive post and connect it on the 'command' post on the starter relay ( yellow-red wire).
Does the starter motor turns?
Yes: check on the connector to the remote control. If startermotor runs, check the wire IN the remote-control and so further.
Check also if you have +12V on the ignition key switch.
If the startermotor doesn't run in the first step.
If you don't hear a 'tic' in the relay when powering if, or you don't see small sparks while connecting,replace the relay.
Jumps the relay ( Remove the thick cable to the startermotor and hold it agains the batterypost on the relay. Startermotor runs= replace the relay. Startermotor doesn't run=replace startermotor.
Hope you've understood my explanations and you'll find and report the fault of your engine
Aug 02, 2017 | Boating
My truck keeps cranking over when I take the key out so I have to disconnect the battery an I just can't figure the problem out plz help!!!
check the wiring on the startermotor, should have a large red terminal which will be perminant live 12volt or 24 volt what ever your wagon battery supply is? you can check this with a multimeter. then check a smaller wire to solinoid above this gives a live feed only when key is turned to start position, if voltage on wire then remove from startermotor make sure you dont earth it out on body causing a short. if still turning over on its own its the startermotor faulty, if stops look for starter relay or key switch faulty.
Jan 29, 2013 | Cars & Trucks
Wiring diagram for a dt125r
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Wiring diagram for 2000 Yamaha dt125r Google Search
Yamaha Motorcycle Wiring Diagrams
Yamaha DT125RE 2005 Service Manual
OEM parts for Yamaha
YAMAHA DT125R Owner Manual
Jun 09, 2012 | 2000 Yamaha DT 125 R
Test the ac output generator on a Yamaha DT125R
Hi, Jezz for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one.
1991 Yamaha DT125R Charging system failure Fixxit
http://racetechelectric.com/files/pdf/rte_troubleshooting_flow_chart.pdf
Jan 28, 2012 | Yamaha Motorcycles
1984 XS 400 L Maxim: yamah maxim 400 dies when put into gear with clutc...
I assume you have checked the kickstand switch disconect and see if still happens replace if needed.
May 17, 2010 | 1984 Yamaha XS 400 L Maxim
Polaris 2006 fusion 700 - Intermittent starting
I think on a worn startermotor.
To be sure, give a little knock on the startermotor end when it won't start. If then it's good starter, then its the startermotor.
If still not good, replace your battery.
Mar 30, 2017 | Winter Sports
Remove the key cylinder on my 2001 Yamah VStar Motorcycle The keys were lost in our house fire.
You should be able to take the title or proof of ownership to your local Yamaha dealership and they will cut new keys for you. Why go through the hassle of removing the cylinder?
Nov 23, 2009 | 2001 Yamaha V Star Custom
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
