Question about Cooling System for Ford Fiesta
I sow boiled water in the spark plug. Is this normal?
I have ford fiesta 2005, 1.2cc. Before a month a go the radiator expansion tank was replaced.
    New Friend:
If you are seeing boiling water around the spark plug I would first check to see if you have a head gasket that needs replaced. If you have antifreeze leaking from a head gasket that would be an easy place for it to pool.
Posted on Dec 28, 2013
Overflow to water container not functioning model no 2650
This expansion tank is only when coolant builds up so musch temperature and pressure that it needs to release, so it relieves itself from the radiator into the expansion tank.
Then, when coolant returns back to normal operating temperature, the pressurized air contracts, forming a negative pressure or vacuum, sucking the now-cooler coolant mix back in to the radiator and cooling system.
So if your water is not getting to the bottle at all, even when engine is boiling, check the outlet and overflow line for blockages, the stem-valve in the bottle is moving, pressure/water leaks in the cooling system venting water or steam.
Also check radiator cap is correct for the car model and operating.
Nov 20, 2017 | Cars & Trucks
What is the best way to refill a sealed radiator unit for 1998 ford f150
When engine cold, Unscrew the radiator cap on the expansion bottle and top up the coolant level to the minimum level marker, then replace the radiator cap.
Nov 22, 2015 | 1998 Ford Contour
Triton v10
Begin with the basics....
INSPECT COOLANT LEVEL,
Low ????,PRESSURE TEST SYSTEM,
PRESSURE TEST RADIATOR/EXPANSION TANK CAP,
INSPECT DRIVE BELT(s),
INSPECT COOLANT HOSES,
INSPECT HEATER HOSES,
INSPECT BYPASS/MISC. COOLANT HOSES/PIPES,
TEST THERMOSTAT OPERATION,
INSPECT RADIATOR COOLING FAN(s)/CLUTCH OPERATION,
INSPECT CONDENSER/AUXILARY COOLING FAN(s) OPERATION(s)
INSPECT RADIATOR & CONDENSER FOR DEBRI,
OBSERVE COOLANT TEMPERATURE GAUGE OPERATION,
Jul 07, 2014 | Ford Excursion Cars & Trucks
1990 BMW 525i 2.5L engine overheats after rplaceing water pump, stermostat,fan clucth,radiator
There's trapped air in the cooling system.
  • You need to remove the bleeder screw on top of the radiator when adding water to the expansion tank.
  • With the engine running, pour water into the expansion tank till you see air go out through the bleeder screw's hole.
  • Just keep adding water until no more air bubbles come out then just put the screw back in place.
  • Then fill the expansion tank to it's normal level/line.
May 07, 2014 | 1990 BMW 525i
1.3 1998 ford fiesta runs fine on tick over but missfires when under accelaration
usually a secondary ignition problem(coil pack, spark plug cables).
Apr 13, 2013 | Cars & Trucks
Water flowing out of radiator when idling 93 nissan terrano v6 petrol auto trans
If the coolant was hot when you noticed water coming out the radiator, that is normal from the heat expansion of the coolant. That is why there are coolant overflow tanks-also called coolant expansion tanks.
When refilling coolant, always top up the radiator, and fill the overflow tank to at least the cold mark level (about half-way up on the tank). With cap off, run engine till the thermostat opens- upper radiator hose will become hot-then shut off engine, add coolant to radiator as needed, replace cap. This method of filling will help to expel any trapped air in the system. Oh, and remember to set your heater controls on high when filling coolant, so the heater core and lines also circulate and expel air.
Check the seal on the radiator cap that it is still good. The cap seal is important to seal the coolant system, as it is a closed system under about 15 psi of pressure. The reason to pressurize the system is that the pressure will raise the boiling point of the coolant by about 10 degrees- important when you consider how hot the coolant has to be when running. OK, enough tutorial-I don't think you have a problem with the water pump! G'd luck, reeve.
Nov 22, 2012 | 1993 Nissan Pathfinder
The car was overheating i checked all hoses and replaced the thermostat the radiator it still is ovrheating and the water is boiling in the overflow tank
Answer could be a faulty thermostat,or it could be a sign that your head gasket is about to blow ,or last of all your timing could be out of sync.
Answer 2 from Inventus: It means your cooling system is funtioning properly. In a system having a coolant recovery tank, coolant in the radiator is always up to the brim, hot or cold. There is negligible or no air space. When coolant in the radiator expands sufficiently due to warming from the engine, it will squeeze past the pressure cap's bottom seal and flow into the recovery tank. (If no provision for such expansion was present, the expansion would rupture the radiator or your hoses.) Only coolant within the radiator is under pressure, and because of this pressure (together with the elevated boiling point that the "anti-freeze" permits), it normally does not boil. But once past the pressure cap's bottom seal, the overflow is at atmospheric pressure and therefore boils.
This boiling is usually unnoticed after a short, i.e., local, trip because the cooler coolant already in the recovery tank quenches it. But after some highway driving the influx of more hot overflow heats up all the coolant in the recovery tank to the (unpressurized, i.e., "natural") boiling point.
As the engine cools when shut off, the contracting coolant in the radiator sucks back coolant from the recovery tank. Fluid in the recovery tank should never be below the "full hot" or "full cold" marks, lest air be sucked in.
-- BETTER ANSWER ==
Your cooling fans are not turning on. It is not normal for your overflow tank to boil like that. It is true that your radiator is overflowing into the reserve tank, but that means yourr adiaotor is boiling. Check for blown fuses or relays for your cooling fans. IF theya re fine. run your engine for about 15 minutes and drive. When you temp level is at normal operating temp open your hood with the engine runing and see if your fans are on. If they are, then you may have a bad thermostat or a plugged radiator, or a bad water pump. If the fans are not on, get your cooling fan switch replaced if your car has one. Check your temp sending sensor
Oct 30, 2011 | Cars & Trucks
Radiator overheating volvo 940GL 1997 model
have u replaced the thermostat? also have it checked for a leaking engine cylinder head gasket.
May 27, 2009 | 1994 Volvo 940
Ford fiesta radiator cap.... where is it?
the radiator expansion tank will be located in the top left or right corner of the bonnet bay and should have a yellow cap.
please rate this advice.
Dec 08, 2008 | 1993 Ford Festiva
Cooling System for Ford Fiesta Logo
80 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
