Question about Kitchen Ranges
Ge profile oven model jgs968 won t stay hot
GE JGS968 will reach temp, but then will go off and when reset. will not turn back on. We've replaced the igniter, the gas control valve, and finally the main curcuit board. I will set the temp. and when it beep at set temp. the temp will then steadily go down, because it's turned itself off! Resetting the temp does no good. SOMETIMES, I can reset the temp to a higher setting and it will reach that setting before, once again, it goes off. As we speak, the repairman is removing the NEW circuit board so we can return it for a refund ($260). He sez we're out of options. Do you agree?
    Master:
  • 796 Answers
If it has a thermocouple, replace that. They are cheap and easily available. They wear out after a few years.
Posted on Dec 28, 2013
2 Suggested Answers
vetteman3002
  • 2299 Answers
SOURCE: just installed new control panel
Normally the bake/probe flashing happens when you plug in the probe. If you don't have the probe plugged in, then double check that your wiring connectors are plugged in properly on your new board or that the wires to the probe connector are not shorted. Make sure that the probe is plugged in all the way. Unscrew the retaining nut, then unscrew the two sheet metal screws holding the housing in place, then give the probe connection a gentle tug to ensure that it is still properly connected.
Posted on Dec 22, 2010
Oven won't keep temp.
I would try another control board. I have gotten 2 new ones before that were bad right out of the box! It happens all the time.
Dec 27, 2013 | GE Profile JGS968 Gas Kitchen Range
My jgs968 oven won't light. It stays at 100. The burners and broiler work
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
m,b,m
Jun 24, 2010 | GE Profile JGS968 Gas Kitchen Range
Oven won't light GE floor range profile model
heatman101
hgdhgd
Dec 19, 2009 | GE Profile JGS968 Gas Kitchen Range
No Bake; everything else works
Hi, When you put the oven on bake, can you see the ignitor glowing but get no flame?
Sound like the ignitor might be getting weak and not opening the gas valve. Please let me know if this sounds like the problem.
It is common for the ignitor to go bad. Even if it glows, it can be bad.
Please let me know if I can assist you further.
Vic
May 31, 2009 | GE Profile JGS968 Gas Kitchen Range
Most likely a bad bake igniter wb13t10045 cant guaruntee thats the problem but I'd start there.
Jan 28, 2009 | GE Profile JGS968 Gas Kitchen Range
Glass door GE JGS968
youlls need to remove the door forom the unit and disassemble the outer door glass, not a major deal, al ittle patience will get it done if oyou would like to know how to do it exaclty youll need to send me the model number so i can look it up for a part diagram..
Jan 15, 2009 | GE Profile JGS968 Gas Kitchen Range
Oven is not working
check your oven ignitor very common prob.
Dec 19, 2007 | GE Profile JGS968 Gas Kitchen Range
Ge profile JGS968 fan comes on no ignition on gas bake convection bake and roast . Only broiler works otherwise themp always read 100 Degress
natural gas or propane? is this a brand new stove? or did this just start happening? is the gas shut off at the oven turned on? there are saftey features that shut off the gas so you dont get hurt. be carfull
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Dec 09, 2007 | GE Profile JGS968 Gas Kitchen Range
Kitchen Ranges Logo
70 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
