Question about Pool & Spa
How do I drain my pool? pump model c48l2pa105c5
  • 3,103 Answers
Either use a hose pump on a plate or open the drainplug if so equipted.. you can also drain with a siphon hose if it is uphill to downhill..otherwise a pump is needed..
Posted on Jan 11, 2014
2 Suggested Answers
MOTORWIZJ
  • 1383 Answers
SOURCE: I have a A.O. Smith
hayward ?? good chance the impeller is broke or it could be plugged with trash make sure you pump basket has no cracks , see picture on how 2 remove your pump .find your local pool pump motor repair guy and ask him how 2 take better care of your pump.. he can save you thousands of dollhair$ over the years .. jay pump guy longwood Florida9_30_2011_7_43_54_pm.gif
Posted on Sep 30, 2011
Can the pool overflow from rain?
A pool will over flow in the rain, the pool pump is only for circulating water not for draining overflow , you can go to a local pool supply and buy a pump to hook to a garden hose and drain it partially, be aware that the pump runs on electric power and you want to be careful not to drain the pool below the skimmer level or you will end up replacing the pool pump motor
Dec 11, 2014 | Jandy Pool & Spa
What setting do you put it on to drain the pool for plaster repair
There is usually a setting on the handle that says "Drain" but if not you can always use the Backwash setting to get all the water out of the pool or at least most of it.
Rod
US Parts Center
May 12, 2014 | Hayward SAND FILTER, PRO SERIES
How do i winterize my pool pump?
That should do it, just check for a 2nd drain plug on the pump housing. Depending on make and model the pump will have 1 or 2 drain plugs. Make sure both are out, if applicable. And don't forget to drain your filter and heater and any other components.
Jan 13, 2013 | Century Pool & Spa
I have a A.O. Smith pool pump (Model #C48L2PA105C5 & Serial #04609FM) and there is no suction at all
Sep 23, 2011 | AO Smith Pool Pump Motor Hayward Swimming...
I just had a new Hayward s244s sand filter put in and now am having problems draining water from my pool. For some reason I can't get it to drain past the skimmer level. Suggestions?
What are you using to drain the pool? A sand pool filter is not the best option for draining. You need a submersible pump for that. Why are you draining the pool? The filter should be used to filter water, not drain. It is possible, but not efficient.
May 21, 2011 | Hayward SAND FILTER, PRO SERIES
I thought this was a salt filter. Can I just buy the pump and connect it-- salt has already been put in the pool
Hope you enjoy saltwater sports. You can drain some of the water to weaken the salt content. The filter will work just fine but you now need to use chlorine like the rest of us.
Jun 20, 2010 | Intex Krystal Clear Model 635 Pool Filter...
My pump is coding salt level too high. Any
Drain water and add fresh. There is no other way to lower salt concentrations.
Jul 31, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Using a hayward vari-flo valve model SP 710x32
Do not drain a vinyl liner pool mor than half way....ever... If you have a fiberglass, or gunite pool it is important to pull the hydrostatic plug under the main drain cover. If you live down a hill, or where there is a high water table, the water pressure underground can lift the empty pool out of the ground (more common in fiberglass pools). If you have a sand or DE filter switch the valve to waste. make sure that you have the skimmer turned off, and the pump is only sucking from the pool main drain (spa drain closed also), and turn the pump on. Make sure the waste hose is far enough away so you dont add any hydrostatic pressure.
Mar 27, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
