Question about Pioneer Car Audio & Video
Deh3800mp stereo no sound output radio or cd. speakers good. all functions work. what now?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 103 Answers
Most likely a shorted speaker. Disconnect all speaker wires at the radio and try them one at a time. Be sure to have radio off when making connections. The speaker that causes the sound to shut off is the shorted one.
Posted on Dec 29, 2013
KaeZoo
  • 156 Answers
SOURCE: Alpine car cd player has no volume
It's possible that you have a shorted speaker wire. If one of the speaker wires is pinched, grounded or shorted it will cause the deck's internal amplifier to shut down. The easiest way to check is with a multimeter's resistance function. Remove the CD player and unplug it. Set your multimeter for "resistance" or "continuity". Attach the black probe to chassis ground; you can use the black ground wire in the deck's harness, clean dash metal, or the outer ring of your cigarette lighter. Use the red probe to test each of the speaker outputs in the harness: white, gray, green and violet. If you find a speaker wire that shows any continuity with chassis ground, then that's the cause of the problem. A speaker with a damaged voice coil may also cause the deck to shut down. To test this, probe the positive and negative leads of each speaker and test the resistance between them. For example, to test the left front speaker you'd put the red probe on the white wire and the black probe on the white/black wire. Each speaker should read a minimum of 3 ohms of resistance. If you get a lower reading then it might be causing your problem. If you don't find a problem with any of the speaker wires, then chances are the deck's internal amplifier has failed.
Posted on Jun 09, 2007
merle840
  • 113 Answers
SOURCE: Alpine CDA-7873 (Same as CDA-7876 basically)
the blue line from the radio harness does not have power when the cd or aux are being used and the amp is not turning on-wire the remote line from the amp to the red line and your amp will stay on and you will get sound
Posted on Mar 27, 2008
SOURCE: No sound from CQ-1305U car CD/stereo
connect the panasonic power antenna lead to a power wire
that should do it.
Posted on Jul 07, 2008
SOURCE: 2004 Buick Rendezvous No sound coming out stereo
call the dealer
Posted on Aug 21, 2008
starlet4life
  • 89 Answers
SOURCE: No output from speakers in car.
Sounds like a couple speakerwires could be crossed/shortcurciting somewhere...;)
Posted on Oct 01, 2008
Sony CDX-FW570: sound only from one speaker on radio. Both speakers work on CD. Checked that mono/stereo function was on stereo. All wires are connected correctly.
Sounds like a bad unit. If it's still under warranty, contact customer support or call a local electronics repair shop for more information.
May 28, 2014 | Car Audio & Video
Instruction Manual For Jvc
go to google and type in radio model # and should find a manual for you!
Nov 18, 2013 | JVC UX-G210 Micro system, Stereo Sound...
I connected a after market stereo in 2000 yukon the stereo turns on but no sound comes out and the stereo good what might be the problem?
If you got the stereo used the speaker wires might not work. I stereo only puts out sound thru the RCA output using an amplifier.
Aug 18, 2011 | Chevrolet Tahoe Cars & Trucks
I need to locate the position of the booster amplifier in my 2001 Town and Country, Radio and CD works fine but no output from all the speakers
If the radio turns on and functions with no sound, you may try wiring the Car Stereo Antenna Trigger Wire (some times called the power antenna wire...which is Gray/Green from the factory harness or blue/white from most after market harness adapters) to the accessory wire.
Jul 14, 2010 | Car Audio & Video
I have no sound and tried all trouble shooting with reset button and volume controls. Is the radio shot JVC KD-S790
If you try a known good speaker on each of the four outputs of the stereo and you get nothing from any of the outputs, the outputs in the stereo is bad.
May 11, 2010 | JVC AM FM CD DET FACE CAR STEREO
NAKAMICHI CD 45Z
If you are using the speaker out wiring (not RCA) then disconnect all speaker wires. connect only one speaker or use a known good test speaker. Try each of the 4 speaker outputs. If none still do not work, then it sounds like a blown output chip which will need to be replaced.
Oct 27, 2008 | Nakamichi CD-45Z CD Player
Factory Stereo
My stereo system for my 2005 Altima Nissan stopped working and wouldn't eject the CD. The CD has been removed but the CD player doesn't work and want take CD'S. The radio continues to work.
Oct 01, 2008 | 2005 Nissan Altima
No sound through speakers
are you using RCA outputs(the round red and white plugs)? if you are then your amp is not turning on and if you are hooking up speakers to your RCA's (low level) then you will not hear any audio the signal is to low. would need to know more about how you checked the ic power?? one could verify an output ic by hooking up an amp since the RCA audio signal is picked off just before the output. if the low level works but the speakers do not then you have a bad output. anything else an o-scope would be handy.
good luch stereo tech (genesisportland@hotmail.com)
Feb 03, 2008 | Alpine CDE-9881 CD Player
You may have one of this two problems:
One of the speaker wires is grounded to the chassis.
Or your car may have a factory amplifier between the radio and the speakers.
My suggestion is to rewire the speakers lines
Dec 25, 2007 | Panasonic CQ-DP383U CD Player
Car Audio & Video Logo
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
