Question about Samsung CLP-660ND - - colour - laser - Legal/ A4 - up to 24 ppm / up to 24 ppm
Error message RIP on display
Will not print jobs has error and cycles between system initializing and warming up
flopez
  • 161 Answers
SOURCE: CLP-510 SPL-C Error message
SPL stands for "Samsung Printer Language". You are using an USB cable that is either too long (above 6 ft.) or too thin (cheap cables).
The reason why the test page prints is because it is a very simple and small page (thinking on kbyte terms). But larger streams of data do not arrive correctly due to attenuation and the error page prints instead.
If it is absolutely necessary to connect beyong 6 ft, you need either a good quality USB cable (try the Belkin brand found at OfficeMax), or connect using a parallel cable.
Posted on Nov 01, 2007
namizhka
  • 148 Answers
SOURCE: Samsung CLP-315
try to do this set of instruction & solution:
  1. Go to Start | Control Panel | Printers And Other Hardware | Printers And Faxes. Double-click the icon for your printer to open the Documents window and clear any pending print jobs by selecting Cancel All Documents from the Printer drop-down menu
  2. Try printing a test page from the printer, not from Windows XP. Most printers have a built-in test function that's activated by holding down one or more buttons while the printer is starting up. Check your printer's user manual for instructions. If this page prints successfully, you know the problem is either with your connection or with the software in your computer.
  3. Check your printer's USB or parallel connection.
  4. Try printing something simple from Windows' Notepad. To open Notepad, go to Start | All Programs | Accessories | Notepad, type a few lines of text in a document, and try printing it. If it successfully prints, the problem is with the software program you originally tried to print from.
  5. Try printing using Windows XP's generic printer driver. Open and run the Add Printer Wizard. When you get to the Install Printer Software screen, select Generic under Manufacturer and Generic/Text Only under Printers (see Figure 2).
  6. Select No for Do You Want To Use This Printer As The Default Printer? (see Figure 3). Click Next.
  7. When prompted on the next screen, tell Windows XP to print a test page. If the page successfully prints, then you probably have a problem with your installed printer driver. Either update or reinstall the driver.
Posted on Sep 16, 2008
  • 3 Answers
SOURCE: Samsung CLP-315 system error
Low heat error comes from the fuser unit, there is a thermostat on the fuser change that and it will work
Posted on Apr 17, 2009
  • 113 Answers
SOURCE: Samsung CLX 3175N has error message: System Error
most likely you got to replace the SMPS (main power board) and fuser.
Posted on Apr 19, 2010
pineworks
  • 4041 Answers
SOURCE: I have a problem with the clp-315. The red light
Hi there
You can try see if this may do it.
Go to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.
In the window that opens (Services) look for "Print Spooler" on the right
Right-click "Print Spooler" and select "Properties".
Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
Make sure the 2 text boxes underneath say "1" in them.
Click Ok until you are back at the Services window, close it and you're good to go.
Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: Automatic
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on May 04, 2010
79 Service error
79.XXXX PRINTER ERROR
  1. Turn off the printer.
  2. Turn on the printer.
  3. Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. (If the message only appears with a certain software program or print job, contact the software vendor for assistance.)
If the message persists, try the following:
  1. Cycle power.
  2. Reseat or replace the interface cable and cycle power.
  3. Remove the DIMMs one at a time and cycle power.
  4. Try using the parallel interface, if possible.
  5. With the EIO cards removed from the printer perform a cold reset:
    1. Remove any accessory, including the HP Jetdirect card.
    2. Turn off the printer.
    3. Hold down the GO button while turning on the printer.
    4. When the printer displays COLD RESET, release the GO button.
Aug 30, 2012 | HP LaserJet Pro 400 M401DN Laser Printer
My tally 4347 i08 powers on, but stays in the initialization loop. it displays hdw trap, and restarts initialization. how can we stop this
If the 4347-i08 is connected to a computer system when it displays the HDW TRAP error when powered on I would recommend disconnecting the printer from the computer system, then power the printer ON as a free standing printer. If the HDW Error is seen when you power the printer on when it is not connected to a computer system or print server, this indicates there may be a fault with the printer. I believe the "HDW TRAP" error is displayed due to an unhandled error in the printers firmware. There may be a number of causes for this error, if this error is seen when the printer is free standing and not connected to any computer system, It is worth checking the following; Check the print head is correctly seated in the printer and is free to move. Check the paper path to ensure there are no obstructions to paper motion. Check all electrical connections. Check for any thing which may cause a short circuit within the printer, ie loose wires, foreign bodies etc. Check the main logic board connects to the interconnect board and ther are no bent pins etc. If you continue to see the error when the printer is not connected to the computer system, it is likely the printer is relatively new as the model is relatively new therefore should be covered under a warranty in most classes, it may be best to contact your reseller or Dascom, the manufacturer directly. If the printer powers on ok free standing then this indicates there may be a connectivity or data format issue. Try printing a menu print on the printer to see if it is capable of printing. If the printer is connected via the parallel interface either directly to a terminal or to an external print server like a JetDirect, the problem may be caused by bi-directional communication disrupting the printer in an unexpected way. You can disable Bi-Dirctional communication, I believe this will be called Cx-Bid within the extended menu on the 4347. To change this setting; Power the printer on holding down the ONLINE button. When the printer finishes initialising release the ONLINE button Press the button order NEXT on the display (button 4) repeatedly until you see CX-BID on the top line of the display. Press the button under CX-BID to select the option Using button 2 or 3 change this setting to OFF Press button 1 under SET to save the setting. Cycle the power on the printer. On any external print server you may also need to set the parrallel interface to a Uni-Directional type. If the problem is only seen when print jobs are received from the system, check; The driver or device type selected on th host system Ensure the emulation selected on the printer matches the host system, and vice versa. Try printing a plane text file to the printer to see if this will print this will identify if a particular job is causing a disruption. If the printer is replacing a pre existing printer, ensure the menu setting on the 4347 are set up in the same way as the old printer. If the problems continue perhaps if you advise how the printer is connected and to what sort of system and when the error is seen I may be able to offer some additional suggestions. In the meantime I hope this is of some help.
Dec 14, 2011 | Tally Office Equipment & Supplies
Error code : E03E DSI CXIWX is the code we are getting .. can you let me know what that really is or cause it to code that way... only thing we did was change the ribbon..Norm
An ******* or unsupported
instruction was attempted
in the application
program.
1. Cycle Power. Run the print
job again. If the message
appears, load the latest
emulation software.
2. Cycle power. Run the print
appears, record the display
message and send it to your
next higher support facility.
Mar 24, 2011 | Printronix Office Equipment & Supplies
Error : Hard disk full How to free memory in hard drive of IMAGE RUNNER 400S machine
hai
power on the copier, press the 3rd function key of panel board (lick. PRINT or OPTION/IF)
panel display go to printer mode ........ WAIT....
then ......... GO TO SET -UP YES or NO press NO
then ........automatically re boot the system
then.........display PRINT PAGES
CONFICRATION press CONFICRATION
now.......conficration data senting to print that time display CANCEL JOB, RIP, INFO etc.,
press the CANCEL JOB then YES
now .. old data automatically ereased.
then copier OFF / ON
best of luck.
Feb 26, 2011 | Canon imageRUNNER 400S Copier
My Dell M5200 printer says 900 Service and RIP Software. I have restarted it several times and checked the menu - all looks o.k., but it won't print. It sounds like it is going to and then the above...
900 RIP error message is a generic error.
In order to understand when it's coming from you have to give more information.
Does it happen when printer is printing a job from a PC, or when it just stands alone idle?
In first case it's probably a job that is generated by the driver which cannot be properly "digested" by the printer. In this case, press select and return on the OP as soon as you get the secondary code message and write it down. Then call Dell support and tell them about it.
If the printer is getting 900 RIP error when being idle, I'd recommend disconencting it from the network for a couple of days to see if the error appears. If it doesn't, then it's something from the network which is causing the problem. Perform the same procedure of collecting the secondary code and contact Dell.
If it still gives 900 RIP error when disconnecting, then it's one of the hardware part which is causing the problem. It might be an option such as a drawer, or a memory unit, or just a main board. try disconnecting one by one the options and see if the problem goes away. Whenever it comes back, collect the secondary codes.
hope it will help, dont forget to thumbs-up
Nov 15, 2010 | Dell M5200n Laser Printer
Erro code 900.00 service RIP soft ware. What is
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Dell 5310n: error message is 900.00 service RIP software A few of my users were having trouble with a Dell 5310n printer. The error message on the display was error message is 900.00 service RIP software. When printing large data files, such as a PowerPoint presentation, the printer would error out.
Per Dell's recommendation I configured the virtual printer to not spool the print jobs and send them directly to the printer. This seems to have corrected the issue so far.
Since I have HP printers on the same print server and none of them have had any kind of issue printing the same large files, I starting to think that the problem is due to either bad printer hardware or print drivers from Dell.
http://itadmindev.blogspot.com/2008/07/dell-5310n-error-message-is-90000.html
Feb 03, 2010 | Dell 5310n Laser Printer
Erro code "900.00 service RIP Soft ware. What is this?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is what I foudn working on the same problem....
Lexmark C510 not printing - message 900 service RIP software
Hi, This error could be due to several things, the most common one is that whatever is being sent from the computer is not being recognized by the printer causing the 900 Rip Soft Error. You can try to reset the printer and try sending the print job again. If the error persisted. Then the problem could be a hardware problem with the System Board.
Jan 13, 2010 | Lexmark C510 Laser Printer
Solid orange light and blinking green lights
To check the light Pattern of your printer
Click on Light and Error HP Laser jet 1012 Printer
Check the error details from the above link
Condition of the printer Action/Description Ready
The printer is ready to print. No action is necessary. Processing
The printer is receiving or processing data. Wait for the job to print. Processing...(job name) Ready LED is blinking.
This message is displayed while the printer is processing a current job, but has not begun to pick pages. Processing...(job name) From Tray XX Ready LED is blinking.
This message comes up for any job, once the printer starts to pick paper. Manual Feed or Continuable Error
The printer is attempting to Manual feed, media is not loaded in the paper tray, media loaded is the wrong size or type. Verify that the correct media is loaded.
Press and release the GO button to continue printing. Out of memory
The printer is out of memory. The page you are printing might be too complex for the printers memory capacity. Try lowering the resolution. See Understanding print quality settings for more information. Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Printer initialization
A printer initialization is taking place. No action is necessary. Fatal error
All lights are on.
  • Unplug the printer for 30 minutes, and then plug it back in.
  • If the printer still has an error, contact HP Support.
All lights are off.
  • Verify that the printer is turned on.
  • Make sure that there is power.
  • Unplug both ends of the power cord, and plug them back in.
Job Cancel
All the LEDs cycle. Canceling...(job name)
The Job Cancel button was pressed and the job is aborted. Power ON
All the LEDs cycle. Checking Paper Path and Checking Printer
This only occurs at power up. Cleaning mode/Engine test
A cleaning page or engine test page is printing.
All the LEDs cycle. Cleaning Page prints
Wait until the cleaning page is finished printing and the printer is in Ready mode. This could take up to two minutes.
Wait until the engine test page is finished printing and the printer is in Ready mode. Clearing Event Log
All the LEDs cycle.
This will happen automatically during an NVRAM Init and a cold reset. No message will be displayed. No Action is Necessary. Power On
Initializing
This occurs when the product is powered on and coming out of EDOS. No Action is Necessary.
Jan 03, 2010 | HP LaserJet 1012 Printer
I have a lexmark t644 printer and have an error code of 900.44 any ideas on how to fix this
  1. If the printer is currently displaying a 900 RIP Software error, power off the printer and leave it powered off for 20 seconds or more. Doing this will clear the printer's memory.
  2. While the printer is off, clear any pending print jobs from the computer or the network queue. This will prevent any corrupted print jobs from being sent to the printer again when it is powered back on.
  3. Power the printer back on.
  4. If the printer goes to the Ready status, try printing again.
  5. If the 900 RIP Software error returns when the printer is powered up or when you try to print, there is a problem with either the printer, the communication cable connecting the printer to the computer, or with the print job itself. Follow the directions below to check each of these components.
    • If the error appears every time you power on the printer, regardless of whether you send a print job or not, the likely source of the problem is the printer or an option installed on the printer.
    • If the error appears only when you send print jobs to the printer, the likely source of the problem is the computer, a setting on the printer, or one of the communication cables.
Nov 17, 2008 | Lexmark T644 Laser Printer
Samsung CLP-660ND - - colour - laser - Legal/ A4 - up to 24 ppm  / up to 24 ppm  Logo
161 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
