Question about Whirlpool Inglis IP4400 Washer
Inglis heavy duty super capacity washer makes grinding noise during spin cycle
Making a grinding noise during spin cycle
4 Suggested Answers
robocop
  • 90 Answers
SOURCE: Whirpool lsq9244eqo fills and drains but does not spin or agitate
It sounds like the agitator gripping teeth are worn out. To check this, take the agitator cap off with a strong knife or flat-head screw driver, pull the cap off and check the plastice teeth and four plastic hooks that grab the teeth. If they are worn out, then you will have to replace the agitator. To replace it, you will see a nut that is between the circlular teeth. Unscrew the nut and pull the agitator up hard.
Posted on Jan 19, 2009
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care Heavy Duty Washer will not spin
It sounds like you have a broken motor coupling. This is a very inexpensive and simple repair.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Posted on Jul 23, 2009
oldTech2332
  • 2341 Answers
SOURCE: I have the Whirlpool Ultimate
sounds to me like the motor coupling is broken,this youtube video will show you how to replace it
http://youtu.be/9K1KHEogf3c
Posted on Jul 22, 2011
Grinding noise before spin cycle
Good Morning John,
I see that you are hearing a grinding noise before the spin cycle in your Frigidaire washer, model# GLET1031CS0. A certain amount of "grinding" or gear sounds are normal in a heavy-duty washer. If you notice that the grinding sound appears to be getting louder, I suggest contacting either the manufacturer or your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
Mar 16, 2014 | Frigidaire Washing Machines
Heavy duty super capacity plus
You dont. If it is making noise drum bearings or idler needs replaced
Nov 03, 2013 | Kenmore 24032\24036 Top Load Washer
Jan 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Squeaking/grinding/rattle noise during wash and spin
That sounds like a clutch problem - probably just worn and need replacement. Will definitely need to pull to find exact fault.
Regards
Nov 16, 2008 | Washing Machines
Won't spin or agitate
coupling.between motor and gearcase.
Nov 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 80 Series Heavy Duty Super Capacity Plus
that is a whirpool source washer suspect wire underneath console may be where connector from wall plug connects underneath ckd all wires around timer possible power loss has been problem from the first but try to some action going again first good luck
May 21, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool Inglis IP4400 Washer Logo
142 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
