Question about Garden
Will not move from high gear
Stuck in high gear . drivetrain will not disengage
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Last time I looked a leaf blower didn't have gears... So a proper model number would help diagnise your problem
Posted on Dec 30, 2013
How do i troubleshoot a transfer case problem?
When was the last time the 1995 transfer case was serviced? First change the oil, It is possible for the transfer chain to jump teeth when the tensioner is not adjusted correctly. Do not engage any 4WD functions until further investigation is done. Also disengage front hub locks(free). Never operate 4WD on pavement, Damage to drivetrain and premature tire wear will occur. Buy a Chilton manual for the Jeep for detailed maint. procedures. The transfer case is very expensive
Jun 13, 2017 | Jeep Wrangler Cars & Trucks
How do i disengae from four wheel drive
At best as I know the 2005 Prado is all time 4WD vehicle.
Is the engine running ? Can you shift the gears ?
May be something is broken in the drive train...
As a suggestion you can go home by locking the centre differential, proceeding at low speed and checking for noises .
Pls. let me know if it helps...
Apr 27, 2014 | 2005 Toyota LandCruiser Prado
Changing gears
Hi, Dave and the usual suspects are:
1. Clutch not disengaging.
2. Bent shift shaft.
3. Shift fork bent or seized.
4. Gear seized on the shaft.
5. Gear positioning lever binding.
6. Shift return spring weak or broken.
7. Shift return spring pin loose
8. Shift mechanism arm spring is broken.
9. Shift mechanism arm is broken.
10. Shift drum is broken.
For more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r3-forums.com/forum/522-drivetrain/14065-shifting-issues-thread-problems-your-shifts.html
Gear shifting problem
OEM parts for Yamaha
Gears stuck up shifting
My Motorcycle can shift up or down anymore Is the problem bent shift lever
Mar 09, 2014 | Yamaha Motorcycles
2003 ford transit turbo manual gearbox, stuck in 2nd gear, cant start
does the clutch push normally or is the linkage broken not disengaging clutch, and then does shifter move around or locked and wont move, loose linkage in shifter or gears are jammed inside transmission and something went, if shifter wont move at all then trans is jammed inside and needs repair.
Jun 09, 2012 | Ford Transit Cars & Trucks
03 Tiburon 5 speed stuck in 1st gear
Sounds like either the shift linkage is out of adjustment or damage to the shifting forks of the transmission.
Apr 03, 2012 | Transmission & Drivetrain for Hyundai...
RIDING LAWN MOWER STUCK IN GEAR
Have someone to rock you while you attempt to move gear shift. Hopefully it is only stuck between gears and will disengage. Your grease in gearbox may have become hard causing problems. If you wash the gearbox with water when hot (after mowing) You may have created moisture in gearbox causing major damage to transmission.
Mar 19, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
