Question about Black & Decker Steam Xpress AS250 Iron with Auto Shut-off
How do I remove the cover to change the cord - Black & Decker Steam Xpress AS250 Iron with Auto Shut-off
I need to repair a damaged fabric cover on my euro pro steam iron. the fabric cord cover is frayed and the rubber steam cord gets extremely hot where the fabric is frayed.
You will need to obtain a completely new power cord kit from the manufacturer. If you are not familiar with doing electrical repairs, you may want to have a technician do it. Insulation on the power cord is important for several reasons; especially a method to keep you safe from a fire, electrical burn, shock, etc.
Jan 14, 2018 | Irons
Replace cord in Rowenta Iron
0) Unplug the iron.
1) Remove the (2 or more) screws holding the plastic bottom plate (that the iron stands up on).
The screws are likely to be #20 Torx "Security" screws -- for which you will need a special bit for your nut/screwdriver. A kit of various sizes of Torx security bits will cost you about $10.
2) Remove the plastic cord-holder assembly from the iron.
2a) If the cord-holder is held in place with screws (you are in luck!), simply unscrew them. If you see no screws, then it is being held in place by several (probably 4) plastic tabs that you must simultaneously release. This makes the job much more fiddly. Use a small/medium blade screwdriver to carefully bend and hold each of the plastic tabs out of the way of the latches. You'll need one screwdriver per tab/latch! Take care not to break the tabs...
2b) Carefully wiggle/pull/work the cord-holder assembly out of the iron taking care not to bend the pins of the integral plug (inside the iron) that are seated in the cord-holder socket. Basically, with the iron resting on its metal surface, pull/pry/wiggle the cord-holder straight upward until the cord-holder (socket) pulls free of the (3 or more) stiff wires that function as a "plug".
3) Note that there are 2 crimp-on connectors attaching the 2 wires of the cord to the rest of the wires in the iron. Take a photo of the wires and jot down notes of which wires are connected together. NOTE: One of the cord wires is "neutral" and is attached to the wider spade at the plug end of the cord. Typically the "neutral" wire is marked with a white stripe or ridge down length of the cord. Don't mix up the "neutral" wire and the "hot" wire when you re-connect them in a later step!
4) Cut off the crimp-on connectors and separate all the wires.
5) Remove the cord from the system of zig-zagging "strain-relief" notches that hold the cord securely in place. You may have to remove a small plastic clip first.
6) Cut off 6 inches of the cord. (Or supply a new cord, if the cord has been shortened too much in previous repairs.) This eliminates the broken section wire within the cord. You may use an ohm meter to verify that both wires have a low resistance again (less than 1 ohm).
7) Route the cord back into the "strain-relief" notches in the cord-holder. Don't forget the plastic clip (if there was one)...
8) Strip all wires, exposing about 3/8" of copper on each.
9) Referring to your notes and photo, re-connect all wires using proper-sized plastic wire-nuts for secure connections.
10) Re-attach the cord-holder to the iron body. Make sure you line up the stiff wire pins with the cord-holder socket. Push the cord-holder into place and secure it (via screws or snap-in-place plastic tabs).
11) Replace the plastic cover, taking care to position the wire-nuts and wires to allow it to drop into place without forcing it. Secure the cover with screws.
12) Plug in the iron and test it out!
Mar 23, 2014 | Rowenta Irons
Replace cord
yes you can change it or you can also take some repair.
Jan 19, 2014 | Panasonic NIA56NR NI-A56NR Iron
My Iron is not working since last 3 or 4 days, I Been with like 8 or 9 months, the cable is not working the red light and yelllow light don't turn on...No idea what is the problem, please try to help me...
The warranty on an iron is usually one year, but that may not cover the cord, which seems to be your trouble. If the cord is intact, both wires, at least one of the lights should come on - even if the iron still refuses to get hot. Remove the rear cover and check for continuity from the socket to the connections in the iron.
Mar 31, 2011 | Irons
Display light does not stay on when I begin to iron; The #1 acrylic flashes off and on when the light is on.
Depending on the models, most irons only have the light on when its heating up and when the thermostart switches off it cut off power and hence the light goes off.
Jan 13, 2011 | Black & Decker D2030 Iron
No power from cord. I want to replace the cord.
In replacing the cord, you have to remove the screw that holds the back cover and unscrew the damaged cord from the heater terminal. Insert the new cord on the rubber insulator and screw it to the heater terminal.
Nov 04, 2010 | Euro-Pro Shark GI490 Iron
How to change the cord of the iron ?
Remove the back plate where the cord attaches to the iron... there are 4 screws visible and another 2 screws hidden under the two rubber feet...These are joined together by a rubber strip and can be removed by prying up and out with a small pry.... once the cover is removed you will see where to take the old cord off and replace it with a new one..
May 23, 2010 | Euro-Pro Shark GI490 Iron
D2030 Iron: Iron keeps shutting off...like auto-shut off is al...
OK... quick disclaimer. Me = not responsible if you break your iron, set something on fire or electrocute yourself. If you're not sure what you're doing, find a qualified person to help or trash the iron. Getting hurt isn't worh a $40 iron.
That said, mine had the same issue... in my case, was a break in the cord.
Before you do anything that follows, don't forget to drain the iron. You'll have a big mess if you don't. :)
Accessing the cord connections requires a security screwdriver. You can buy one at a hardware or electronics repair store. OR if you're chep like me, make one yourself by using a Dremel with a cutoff wheel to cut a notch in a thinner blade, flat blade screwdriver. Any cheap flatblade screwdriver will do (eye protection recommended since you'll be grinding metal).
Unscrew the two screws in the back. Once removed, the colored plastic cover can be removed by inserting a screwdriver near the tabs that hold the cover in place and prying a bit.
Removing the inner cover is a little trickier.
The handle under the power indicator light (the red one) has an upper and lower section. Squeeze the lower portion of the handle directly beneath the light pretty firmly. You'll notice a slight separation between the back section and the handle. The back section is what you'll remove. I removed mine by squeezing the handle and pulling the power cord straight backward (I know that sounds odd, but it was the easiest way to get some leverage, plus it's already broken, remember???) Don't pull super hard, but firmly enough to separate the back panel from the back of the iron.
Once the back cover is removed, it's a pretty simple cord change. As there are a few more wires than some people are accustomed to, I recommend writing down the wire combos so you can reattach everything as it was.
If you have difficulty removing the crimped wire nuts (the plastic covers), you can use a pair of pliers to squeeze opposite the crimp and they'll open up enough to allow the wires to slide out.
From there, reassemble... opposite of the disassembly order.
Mine worked perfectly after this quick fix. Hope yours does too. Good luck and be safe!
May 18, 2010 | Black & Decker D2030 Iron
Iron cuts off in the middle of ironing
It is probably an intermittent cord connection next to the strain relief. You can simply remove the back cover, cut the cord, pull the remaining cord (approx 6-8") and reconnect it. You can also order part # RS-DE 245954 the whole cord assembly including the circuit board for about $25.
Apr 17, 2010 | Rowenta Irons
Power Cord
Manufacturers are getting more and more clever about hiding screws which allow covers to be removed. Probably has to do with product liability.
Anyway, look for a brand or settings insignia that can be removed - like a thin aluminum plate. Screws are sometimes hidden underneath. If the cover is a gauge for a control, be very careful not to damage it when you remove it. You will want to put it back.
May 26, 2008 | Euro-Pro G1490 Continuous Iron
Black & Decker Steam Xpress AS250 Iron with Auto Shut-off Logo
29 people viewed this question
Top Black & Decker Irons Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
