Question about Sony PFM-42B1 42 in. HD-Ready Plasma Television
Dark Shaded Rectangle in the middle
My Sony PFM 42B1 shows dark shaded rectangle in the middle of the screen.  It doesn't happen if I use Component Input.  However, if I use it happens when I use S video.
  • Anonymous Mar 23, 2014
    screen has a wave like pattern on it which is palpable when we touch the screen and also when the tv is on. when we look at the screen at an angle it looks like a white shade
  • Anonymous Mar 25, 2014
    my sony tv type kdl32s300e gives dark shades on the screen. What can i do to solve that problem
Posted on Feb 22, 2008
Check the settings for the input and make sure captioning is not on....text mode does this on mine, figured it out after hours of pulling hair out...
Posted on Dec 09, 2007
Zenith SL2773W problem
The dark rectangle appears because you have the closed captions on and set to TEXT. Closed captions set to CC1 puts the words on the screen and TEXT puts a black box on the screen. Go into the menu, navigate to the page with closed captions and set your captions to OFF.
Aug 12, 2007 | Zenith C27A24T 27" TV
Vizio 55" Inconsistant Dark Screen
you have to open the back cover to check weather the screen back light need replacement. usually if the lamp is almost black in color it needs replacement. the backlight is covered with metal shield installed at the upper portion and lower portion of the panel of the tv.
Nov 01, 2012 | Vizio VF Televison & Video
Samsung LN-T4661F with black shaded area.
The back light is beginning to fail, thats why it goes shaded but you can still the picture on one side, do a google search for back lights for your make and model, there a few how to's to help you with changing the back light.
Feb 17, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
An online manual for a sony pfm 42b1
Click Sony Support and download required manual for PFM-42B1
Hope this info will help you.
Dec 27, 2009 | Sony PFM-42B1 42 in. HD-Ready Plasma...
I have a 42" Sony Plasma Model# PFM-42B1 was watching tv when picture went out. Red standby light keeps flashing. Was told to unplug for 5 hours then plug back in & count how many times it blinks,...
There are a number reasons why this might happen:
  • The backlight has gone (Find a dark place and shine a torch into the screen and see if you can see an image in the background, if you see an image then the backlight has gone) - Needs a new backlight (Engineer to remove and fit) or have a new panel fitted.
  • The panel has died - Need a new panel
  • A cable has worked itself loose or is broken
  • The inverter has gone - Need new inverter
  • The driver board is faulty
Oct 01, 2009 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Monitor acer lcd AL1717a
Looks like you have a burned lamp.
Most LCDs have a lamp that lights the screen's image.
If you see the image, but its too need a lamp replacement.
Please rate this answer if its useful
Jun 18, 2009 | Acer AL1715 17" LCD Monitor
Sony pfm 42b1 negative picture
I have a Sony PFM-42v1 and it does the same thing, look in your tv menu for picture inversion, usually under screen saver. What it actually does is reduce the chance of screen burnin. By reversing the image it sort of resets the hot areas, brightest colours and the cooler areas being dark colours, switches them around ( negative ). This cools the hot spots and heats up the cold spots.
There should be a option to turn it off, mine and I guess yours as a default is ON, mine has the ON, timer and OFF options.
Hope this helps, please let me know if you need more info.
Mar 08, 2009 | Sony PFM-42V1 42 in. HD-Ready Plasma...
Dark Translucent Rectangle appears in front of picture
Go into the customer menu and find the "closed captions" heading. Within the closed caption you will find "TEXT". If you turn off closed captions or the text, whichever you menu lets you do, your rectangle will go away. Hope this helps
Dec 21, 2008 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
Sony PFM-42B1 42 in. HD-Ready Plasma Television Logo
158 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
