Question about Jenn-Air JCD2389G Side by Side Refrigerator
Jcd2389ges Jenn-Aire - ice gate on door is malfunctioning
Jcd2389ges Jenn-Aire - ice door has stopped working. when we push the switch on the door dispenser it makes a grinding sound and very little ice comes out or none at all. the grinding stops when we open the freezer door. it looks like the gate on the ice chute in the door has come loose and is dangling in the opening.
  • 1314 Answers
SOURCE: jenn air jcd2389g side by side refrigerator water leak
sounds like a leak where your incoming water line hooks to the water valves might just need to tighten the coupling or a mouse has chewed through one or both of the lines access the lines on the back and watch while some one gets water out the door to locate the leak
Posted on Feb 11, 2008
SOURCE: Jenn Air JCD2389GES ice dispenser problem
my ice maker is not making ice.
Posted on Mar 26, 2008
  • 42 Answers
SOURCE: jenn air Mdl#jcd2389ges Very slow water dispenser
You will probably find that if you have a water filter in your model refrigerator that is is clogged. Replace the filter and voila, good flow again. You probably also have small or hollow or chip ice cubes as well, if your filter is clogged.
To save the cost of the filter you would need to check to make sure you are getting strong water flow to the solenoid valve located in the bottom rear of your refrigerator.
I hope I helped, supertechks
Posted on Mar 28, 2008
  • 1122 Answers
SOURCE: Flap on ice dispenser does not open
what make and model?-mike
Posted on Oct 27, 2008
  • 28 Answers
SOURCE: I have a jenn air JCD2389GES. Every day I'm
The condensate drain may not be draining into the pan under the fridge or it may have a leak or could even be not connected to the condensate pan in the evaporator.
Another possibility is that your condenser might be dirty or plugged causing the suction line going to the compressor to freeze up and then thaw leaving puddles under the fridge. Clean the condenser (the coil under or behind the fridge) and it should stop.
Over stocking the freezer will cause this as well. If you cover the air return in the freezer the evaporator will freeze up and the suction line will freeze back to the compressor.
Posted on Jul 09, 2009
I have a jenn-air jcd2389ges. The hole in the door where the ice comes down into your cup is broken. i believe the foam piece is busted
Here is a kit of the most likely parts that you are talking about=> 12001991 Ice Dispenser Solenoid and Door Kit Just disconnect the power and turn water off before beginning to ddisassemble the fispenser components seen here=> JCD2389GES Dispenser Components
1. Unplug the refrigerator power cord.
2. Remove the overflow grille from the housing.
3. Unsnap front cover at the bottom of the housing.
(using a flat blade screwdriver, and tape or pad, twist the screw driver, or pry out the bottom trim using the molded slots in the bottom of the trim panel).
4. Disconnect the front cover switch harness connector and set the cover aside.
5. Disconnect the power wire harness connector (BL/BK and W wires)
6. Disconnect the flapper door heater wire harness connector (if one is present).
7. Release the dispenser microswitch retainers and slide the switches off of their locator pins. Carefully handle the switches so they do not come apart.
8. Disconnect the wires from the terminals of the lamp holder.
9. Remove the two 1/4. hex head screws from the control bracket and remove the control bracket.
10. Remove the 1/4. hex head screw to remove the water fitting (fill spout) from the water dispenser lever.
11. Unsnap the ice guide and remove it from the ice dispenser lever.
12. Remove the air pot by sliding the rear of the air pot out of the slot molded to the dispenser housing and slip the linkage out of the flapper door mechanism assembly.
13. Unsnap the flapper door and remove it from the ice dispenser lever. While you remove the flapper door, carefully guide the flapper door heater wire and connector over the door mechanism assembly.
14. Remove the 1/4. hex head screw securing the dispenser levers pivot retainer to the dispenser housing and remove the retainer.
15. Remove the water dispenser lever.
16. Remove the ice dispenser lever by maneuvering it around the door mechanism assembly.
17. Pull the pin from the door mechanism assembly and remove the spring and mechanism assembly.
18. Reassemble in reverse order.
Need Help let me know, Thanks Sea Breeze
Jul 02, 2012 | Jenn-Air JCD2389G Side by Side...
Jen Aire Fridge ice maker fingers are below the
This one you have to take out the ice maker and run hot water from the kitchen sink into the tray to get the ice out. need model number if you want detail explaination how to. or just use a hair dryer that will work to!!! if fingers dont rotate after defrost ice then the gears are stripped, replace ice maker
Mar 27, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Jenn air jcd2389ges door not closing. My 5 year
it may be no hlp at all
but ive seen this a few times your problem sounds similar
check the soda milk door sometimes that gets jamed and will prevent the door from closing
Oct 08, 2009 | Jenn-Air JCD2389G Side by Side...
My fridge made a horrible grinding noise. When it
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Jul 08, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
Towards the bottom of the freezer is the water diversion tray for when it defrosts. It is usually made of glass but may not be. Lift that up an see if it is blocked by frozen water ice blocking the cold air vent that recirculates and also feeds into your refrigerator.
If this doesn't help wait long enough and one of the other experts on the site will help you. If it does solve your problem I wouldn't be too surprised as I've seen this so many times.
Well, regards and good luck,
Worldvet
Jun 02, 2008 | Jenn-Air JCB2280HES Side by Side...
You could have a layer of solid ice at the bottom of your icetray. Remove icetray. Remove any ice in bottom. Reinstall. Be careful there is a connection on the rear of the icetray, you may have to turn it to get it to mesh correctly. Fill with ice and it should work fine. Good Luck.
Feb 24, 2008 | Jenn-Air JCD2295K Stainless Steel Side by...
Ice Maker Making Noise
sounds like a noisy ice maker, is it making ice? about $100 for new ice maker. ck warr jeen air might warr parts in that unit for2 years
Feb 09, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
76 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
