Question about Electrolux W4180N
When we start auto on the display appears error 019 master comm
    New Friend:
Same problem with our machine also, error 019, Anyone can help us to assist fix this problem. thanks
Posted on Mar 06, 2014
Please, how can I solve the fault code 19, Master COMM. On my Electrolux W4240H washing machine. All the engineer u contacted didn't get it. Please, help.
Error code 19, MASTER COMM.
Communication with superior system has been broken. The cause can be an error in the network connections, damaged cable, defective monitoring system, etc.
Action: • Contact the supplier of the monitoring system for possible causes of the monitoring system not communicating.
Dado
Aug 20, 2015 | Electrolux Washing Machines
How can I fix the error code 019 E on my Eloctrolux washing mashine W355H
You probably need a new board, but why not call the local parts supplier and tell the guy you're getting an 019 and he should be able to get you started. Just every now and then you may get around, but more than likely your will need to replace the board.
Mar 24, 2015 | Electrolux Washing Machines
4250N
Action:
Dado
Jan 07, 2014 | Electrolux Washing Machines
My washer was not totally draining on the spin cycle so I figured there was some blockage. I took off the pump and cleaned out the catch all which had coins, barrettes, hair and muck. I cleaned it all...
This is Error 205 details if it helps,
105. (01101001) Comms Error Time Out
These faults are reported when the Display Module detects an error in the communications between the Display Module and the Motor Control Module.
Primary Source: Display Module.
Action: Replace Display Module.
Secondary Source: Motor Control Module.
Action: Replace Motor Control Module.
Tertiary Source: Rotor Position Sensor
Action: Replace Rotor position Sensor. If this corrects the fault refit the
original Display Module and/or Motor Control Module.
Dec 13, 2013 | Fisher Paykel Fisher & Paykel AquaSmart...
I have error codes flashing on my thermostat..it is an american standard model the manual for the therm. has ACOT900AC43UA on front..says to find addedum 18-HD32D2-1/69-2009 for codes i cannot find it...
Error codes from American Standard Pub 18-HD32D2-8, which is a one-sheet document that came with my American Standard air-conditioner:
29 = not listed
129 = not listed
80 = HPCO Fault - problem is in outdoor unit - Desscription: High Pressure Monitor Fault (hard lock out, cycle power to reset)
91 = Communication Inactive Fault - problem is in air handler - Descriptions - COMM Bit Master Clock Error, COMM Heat/Cool Demand Error, Serial Motor Communication Inactive Error
91 = Communication Fault - problem is in furnace - Descriptions: Blower motor no COMM response, Inducer motor no COMM response, Loss of heat/cool demand, Loss of clock signal
91 = Communication Fault - problem is in outdoor unit - Descriptions: Loss of Heat/Cool Demand Message (COMM), Loss of Bit Master (Clock Signal)
91 = Communication Fault - Description: Comm line is dead and no bits have been received.
By the way, I do not recommend American Standard. I've had mine 14 months and it just blew up - the entire control panel blew. My advice to you - think about a different brand.
Nancy
Scottsdale, Arizona
Aug 22, 2010 | American Standard Heating & Cooling
Error code on dash display
Take the vehicle to Auto Zone or O'Reilley's auto parts of any local auto parts store that offers to read stored codes for free and they will be able to tell you exactly what codes are showing and what they mean for free. In addition you will be able to by the repair parts while your there.
Jun 21, 2010 | 2006 Volvo V50
What is code 105
Error code 105 means you have a Comms. Error Time out. This means there is a communications error between the display module and the motor controller.Now have you replaced a part in the machine recently?Just looked in my manual and it also says, to rectify this fault you might need to replace the rotor sensor on the motor.Please reply and tell me if the machine became faulty or a part was changed for another fault and then Error 105 started appearing in the display.Hope to hear from you soon.
Jun 04, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Service Error
58.04 error is a processor error. check to make sure the transfer kit is installed correctly. Take it out and put it back in even if it looks like its in good.
If that doesn't work, take it to a service technician. It will probably have something to do with the connector from the Low Voltage Power Supply to the DC Controller, bad power supply or bad DC Controller.
Nov 05, 2007 | HP LaserJet 5200tn Printer
Help with HP d135 all in one printer,scanner, fax
HP Error Codes
These error codes apply to many HP & Panafax machines
001 recording paper jam
002 recording paper jam
010 no recording paper
014 print cartridge is not attached
015 out of ink
017 wrong paper size
030 document misfeed
031 document jammed or exceeds maximum length (2 meters)
039 during dialing, STOP was pressed
041 out of toner
045 no toner cartridge
060 a cover or door is open
061 a cover or door is open
063 jam access cover is open
316 clean the ink station overflow tray and encoder strip on inkjet models
400 during initial handshake, RX station did not respond; comm error
403 no polling capability at remote side
404 during initial handshake a comm error occurred
405 during initial handshake a comm error occurred
406 password mismatch
407 no confirmation from the RX station for the previous page sent
408 remote side confirmation of previous page is illegible
409 remote side confirmation of previous page is illegible
411 polling password does not match
412 no data from the transmitting side
414 polling password does not match
415 polling transmission error
416 received data has too many errors
417 received data has too many errors
418 received data has too many errors
419 received data has too many errors
420 machine enters RX mode but receives no command from TX side (not a fax calling)
422 interface is not compatible
427 interface is not compatible
430 comm error occurred while receiving
434 comm error occurred while receiving
436 received data has too many errors
456 memory overflow on confidential document or relay request
490 received data has too many errors
492 comm error occurred while receiving
493 comm error occurred while receiving
494 comm error occurred while receiving
495 telephone line disconnected
540 comm error occurred while transmitting
541 comm error occurred while transmitting
542 comm error occurred while transmitting
543 comm error occurred while transmitting
544 comm error occurred while transmitting
550 telephone line disconnected
552 comm error occurred while receiving
553 comm error occurred while receiving
554 comm error occurred while receiving
555 comm error occurred while receiving
580 sub-address TX to a unit without sub-address function
581 sub-address TX to a unit without sub-address function
601 ADF misfeed
623 no document was on the ADF
630 redial unsuccessful (busy line or no response)
634 redial unsuccessful (busy line or no response)
631 during dailing, STOP was pressed
638 power failure occurred during the communication
640 telephone off hook after comm is completed
870 memory overflow while storing TX documents
879 memory overflow while storing RX documents
975 DRAM parity error (document info in memory is lost, very common, also clean encoder strip)
HP 200/300 and similar models GPM (printer assembly) failure: When the inkjet carriage is homed on the right side of the unit, the spring pointing toward the rear of the unit passes under 2 "actuators" that appear to be identical (mounted vertically, L-shaped). Under heavy usage, the lower end of these actuators is worn away. To remove the actuators for inspection, carefully rotate the paper pickup feed wheels while pulling upward on the L-shaped actuator (compare the 2 actuators, or compare them with actuators from a comparable machine that is in working order).
Many HP and Panasonic inkjet models are comparable and parts can be ordered from Matsushita.
If there is an encoder strip (scale) in inkjet models, clean it to correct a wide variety of problems (HP 900, OfficeJet, Panafax UF321). The encoder strip resembles a narrow piece of cellophane tape, and can be found behind and above the silver bar on which the printhead rides. Easily broken ... use caution when cleaning with a cotton swab dampened with water or rubbing alcohol. When dirty from overspray, the strip can cause all types of problems.
In the Maintenance Mode of HP and Panasonic machines there is a wealth of information. For example, print out the function parameter list to get the lifetime TX/RX/PRINT counts (usually option 3 instead of option 6 in the following example for the HP 200).
HP 200 ram clear
Press # dial dial dial dial * 6 start
Exit the maintenance mode by pressing 9 9 9 start
[Note: to print function parameter list substitute 3 for 6 in the line above]
[Note: to execute a self-test substitute 0 for 6]
[Note: to set parameters 000-999, substitute 1 for 6]
[Note: to test modem/tones, substitute 4, 5, or 7 for 6]
[The TX/RX/COPY counter is item 061 on function parameter list]
HP 300/310 ram clear
Press function 7 dial dial dial dial * 6 start
HP 700 ram clear
Press and hold stop and menu for a few seconds
Press 7 0 0
Press up-arrow key 4 times until display reads 09 memory clear
Press start
Bad line card: replace 2 transistors, 1 diode, and 1 chip. Transistors BS170 (NTE490) @ Q1; 2N3906 @Q3. Diode 1N4148 ar CR2 (next to 2N3906). Chip 74LS14 (74HC14) at U5 (near BS170).
HP 900 ram clear (same as Panasonic UF-321/322)
Press menu 7 dial dial dial dial * 6 start
Press up-arrow key until the display reads shipment set then press start
The display will read reset counter
Select yes or no then press start
HP 900 disassembly tips (proceed with caution and at your own risk). To remove the operation panel cover: face the rear of the unit, place your thumbs in the outside edges of the document feed path, lift up on the thin edge of the cover while pulling the cover toward you. This should release "snaps" located at the outer edges of the document feed path. Facing the front of the machine, lift the cover up and toward you, then disconnect a cable attached to a board on the rear of the operation panel. To access the document feed mechanism, remove a white plastic retainer in the upper right hand corner of the ADF cover, disconnect the ground strap on the right side of the cover, and slide the cover slightly to the right until it is unhinged. The cover housing the scanner glass can be lifted off after removing several screws, popping two "snaps" at the rear corners, and then carefully popping two more snaps at the front corners of the cover. At this point you would be able to clean one scanner mirror and the ADF sensors & rollers. If you need to remove the line card, you'll have to remove the remaining covers, one screw located at the front of the power supply, four screws that hold the printer assembly in place, one screw at the right rear corner of the scanner assembly, pop two snaps at the front corners of the scanner assembly (remove a long white plastic retainer at the left front corner of the scanner assembly). After gently lifting the scanner assembly upward, the printer assembly can be removed to reveal the line card. During reassembly, be sure to check the positioning of the print paper detect sensor (the spring comes off the sensor and you get an out-of-paper error). Another observation we've made is that on some (but not all) HP 900's, there is a metal retaining clip on the left end of the paper pickup roller's shaft. Apparently the plastic lever (retainer or lock) on the left end of the axle doesn't always hold the mechanism in place in the event of a multi-feed that jams the machine, and at some point in production of the machines a metal clip was added to hold the plastil retainer firmly in place.
HP 900 set number of rings to answer (default is 2)
Press menu 7 dial dial dial dial * 1 start
Press 4 5 start clear
Enter the number of rings desired then press start stop stop
HP Office Jet / LX
For a full ram clear, press and hold * and 1 while turning the power on.
Hold the keys down for a few seconds after the display reads self test please wait then release the keys
For a partial ram clear, press * and 4 while turning the power on.
For the Diagnostics Mode hold * and 7 while turning the power on. Afterwards, new menu items will be found on the display including diagnostics. Turn the unit off afterwards to dump the diagnostic menu selection.
The original Office Jet/LX will print a scanner calibration chart/instructions.
If the modem fails, remove it. Reinstall and test.
Clear Paper Jam: Remove RX tray, press load/eject and paper should load part way; press load/eject a second time and the page should be ejected. If the page ejects ok, then it's not necessarily a mechanical problem, in which case you should clean the encoder strip and sensor. If the page does not load properly, it is probably a mechanical failure. Laserjet paper is slick on one side and may not load properly. Recycled cartridges spray excess ink on the encoder strip
Nov 04, 2007 | HP OfficeJet D135 All-In-One InkJet...
Electrolux W4180N Logo
156 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
