Question about Irwin Miter Saw Laser Guide Attachment 3061001
How can I make it fit?
I purchased an Irwin Law Laser Guide because I was told by the Lowe's sales person that it fit all miter saws.
When I opened the package there is a notice warning, "The Laser guide is not recommeded for saws containing interlocking arbors, bolt arbors and arbors other than 5/8".
This critical information should be on the out side.
Do I now have a paper weight or do I have any options?
Im hopeing you saved your receipt , Because they only work in low light areas anyway . I bought one a while back and I cant see it most of the time.......go get your money back !!
Posted on May 30, 2009
Instructions on replacing a 10 inch makita 2400b miter saw with an irwin replacement blade - comes with spacers but not sure what goes where
the spacers are used to make the hole in the blade fit snugly on the shaft
replace the blade in the same way that it was taken off
all you have to do is mount the blade with the arrow facing the direction of rotation
Jun 17, 2017 | Makita Saws
How to I fix a Ryobi Miter Saw Blade Guard which is not retracting?
Sound like a piece of wood may have driven the arm up which operates the guard, if you remove the screws holding the guard support plate to the saw you should be able to remove the guard assembly, the arm can then be re-bent down on the end so that it meets the angled plate on the back of the guard and pushes the guard through the entire stroke, the other reason could be a damaged guard, when the centre screw is removed the plates can be removed from the guard, note how the spring and plates are assembled prior to dismantling, check the inside centre of the perspex guard and ensure the 4 protrusions which engage with the drive plate haven't broken off, if sow the guard will need to be replaced, this may now be an obsolete part , if so purchase a Makita guard as they are the same
Jul 18, 2015 | Ryobi 10 In Miter Saw With Laser
My saw won't run when I press the switch trigger.
First, check the outlet it's plugged into.
Power cords can go open, try holding the trigger (careful), and bend the power cord near the plug, and near the saw.
Trigger switches can go out.
saw motors can go out.
Jun 08, 2015 | Ryobi 10 In Miter Saw With Laser
Laser doesn't come on, batteries new
I have the same problem. I have 2 ,1 on each of my daily chop saws. I have had them for about 10 years so I will just buy a new one. For the record a few times I had a wood chips blocking the lens.
Good luck
Nigel.
Apr 09, 2013 | Irwin Miter Saw Laser Guide Attachment...
Batteries for 3061001
The Irwin laser guides I've worked on take three LR44 button batteries.
Feb 13, 2012 | Irwin Miter Saw Laser Guide Attachment...
Lazer not working after batterys replaced
Mine did the same thing. I think it's a bad contact situation. I ended cleaning all the contact springs in the battery compartments and also putting a small dab of silicon on each battery before re-fitting the cover plate. This made sure the batteries were nice and snug in their housings. Make sure the batteries all have have the positive symbol (+) upwards when you refit them. You can also check the centrifugal switch. This is located under a triangular plastic cover. If you hold the batteries in place with your thumb, you can gently push the tiny weight against its contact and the laser should light up. DON'T LOOK DIRECTLY INTO THE LASER WHILE YOU DO THIS!!! This worked for me but I can't give any guarantees but, hey, what have you got to lose? Good luck.
Jan 01, 2009 | Irwin Miter Saw Laser Guide Attachment...
Irwin laser light for miter saws
The way it works is when it spins the spring part touches the other conductor. I had this problem but slightly and very carefully bent/moved the straight conductor toward the spring without them touching and has worked perfectly ever since with a visible line even in sunlight. If you unscrew the cover there will be a black plastic piece underneath, take that off and that is where the straight and spring conductors are. Be sure to put the plastic triangle back on and the cover screwed back on.
Dec 02, 2008 | Irwin Miter Saw Laser Guide Attachment...
I just purchased a Hitachi C12LSH. The blade hits the guard in the cutting trough. How do you move the saw blade to center it?
you should be able to adjust blade up a little bit, you only want blade to cut through tile bout 1/4 inch ,should be big knob you lossen to lift up motor and blade good luck
Aug 02, 2008 | Irwin Miter Saw Laser Guide Attachment...
RYOBI TS254 change saw blade???
should have blade lock button remove blade with proper size wrench reinstall new blade in reverse remember some of these the loosening of the blade will be clockwise so if nut dont come loose try clockwise to loosen good luck
Apr 22, 2008 | Irwin Miter Saw Laser Guide Attachment...
Fitting a craftsmans 12" compound saw
Theres no fix here-if you want a laser, you'll need to get one that will fit the Craftsman.
Dec 02, 2007 | Irwin Miter Saw Laser Guide Attachment...
Irwin Miter Saw Laser Guide Attachment 3061001 Logo
439 people viewed this question
Top Irwin Saws Experts
Tom Chichester
ray gallant
Are you an Irwin Saw Expert? Answer questions, earn points and help others
